Issues receiving serial commands
A lot of the code I've been finding online for sending and receiving data is using spin code.
I have a c project I'm working on in which I need to send and receive data to a python program over usb.
Here's my code. Does anyone know why it's not working?
Here's my python I run immediately after loading c code into ram using simpleide
Output
#include <stdio.h>
#include <string.h>
#include <propeller.h>
#include <simpletools.h>
int main(void)
// Wait some time
waitcnt((CLKFREQ+CNT)*5);
char buffer[300];
int buflen = 300;
serial *term;
simpleterm_close();
term = serial_open(31,30,0,57600);
writeStr(term,"give_data\r");
getStr(buffer, buflen);
waitcnt((CLKFREQ+CNT)*2);
writeStr(term,"Data received.\r");
return 0;
import time
import serial
print "Communicating with propeller over COM4"
s = serial.Serial(
port='COM4',\
baudrate=57600,\
parity=serial.PARITY_NONE,\
stopbits=serial.STOPBITS_ONE,\
bytesize=serial.EIGHTBITS,\
timeout=0)
while True:
data = s.read(9999)
if len(data) > 0:
print 'Received:'+ data
if "give_data" in data:
print "Sending data to the propeller..."
s.write("Here is some data\r")
time.sleep(1)
s.close()
Output
C:\Users\mike\Desktop>python scom.py Communicating with propeller over COM4 Received:give_data Sending data to the propeller... _
If I use the parallax serial terminal I can use C read functions like scanf, but I need to get python working.
Same result running this on a linux host
#include <stdio.h> #include <string.h> #include <propeller.h> #include <simpletools.h> int main(void) { // Wait some time waitcnt(CLKFREQ*3 + CNT); char buffer[300]; int buflen = 300; serial *term; simpleterm_close(); term = serial_open(31, 30, 0, 115200); writeStr(term, "give_data\r"); readStr(term, buffer, buflen); waitcnt(CLKFREQ*2 + CNT); writeStr(term, "Data received ["); writeStr(term, buffer); writeStr(term, "]\r"); return 0; }terminal output: Your delays look slightly off but shouldn't have an effect on the transfer as such. You could try a simple loopback first where the prop simply echos the incoming data.#include <stdio.h> #include <string.h> #include <propeller.h> #include <simpletools.h> #include <simpletext.h> #include "fdserial.h" int main(void) { // Wait some time pause(3000); char buffer[300]; int buflen = 300; serial *term; simpleterm_close(); term = fdserial_open(31,30,0,57600); writeStr(term,"give_data\r"); readStr(term,buffer, buflen); writeStr(term,"Data received.\r"); return 0; }[code]
C:\Users\mike\Desktop>python kuronekotest.py
Received:give_data
Received:Hn,
