All caps
RDL2004
Why can't I use CAPS in the title?
Is this some quirk in the forum software or a problem with Firefox? I've tried on both Windows and Linux, it's same on both.
No, I will not try Internet Explorer.
ALL CAPS doesn't work - only the first letter stays capitalized.
ALL works, 3 letter acronyms only?
CAPS works, so nope, more than 3 letters is fine.
ALL C reverts to only the first letter capitalized.
A L L C A P S doesn't work - only the first letter stays capitalized.
This is weird, it seems to work for other people and I think even I have done it before.
Today I noticed that I no longer have any of the advanced editing controls - the buttons for font, color, inserting quotes, images, etc. When I post a reply to a thread, I don't have a button to "Go Advanced" either.
I have no idea what's going on, I completely rebooted this Linux computer and it hasn't changed anything. I'm having the same issues on a Windows 7 computer also.
I just noticed that the caps sometimes "stick" when previewing and reposting, but not always.
edit (more experimenting): maybe Phil is right and the filter is based on some percentage or other rule that limits the amount of caps.
DEFCON22 LIMITED quantity - worked
DEFCON22 LIMITED QUANTITY - didn't work
DefCon22 Limited Quantity - worked
DEFCON22 LIMITED Quantity - worked
DEFCON22 LIMITED QUantity - worked
DEFCON22 LIMITED QUAntity - worked
DEFCON22 LIMITED QUANtity - worked
DEFCON22 LIMITED QUANTity - worked
DEFCON22 LIMITED QUANTIty - worked
DEFCON22 LIMITED QUANTITy - worked
DEFCON22 LIMITED QUANTITy - worked again
DeFcOn22 LiMiTeD QuAnTiTy - worked
Looks like as long as there is one letter that's not a cap, all is good?
If this is actually the way it's supposed to work and is consistent, I'd have to say it's a pretty confusing "feature".
Still haven't found out why my editing buttons are gone.
In my opinion, Parallax needs to turn this off. It should not be used because it changes what I actually type, with no warning that it's being done or explantion of why it's done. Enough caps can still be used to defeat it's intended purpose anyway, which pretty much makes it less than useless.
I wasted quite a bit of time trying to figure out what was wrong, including rebooting computers and re-installing software.
If anyone is wondering, this all started when I posted a thread a week or so ago titled RTL-SDR, and couldn't figure out what was happening to the capitalization. I almost deleted it after I couldn't fix it because it just didn't look right.
Hopefully those who can affect such changes are listening with sympathetic ears (or eyes, as the case may be). I cannot even see the current setting. What I posted was from my own website.
Now if I can just get my edit buttons back
Well duh.
I didn't have JavaScript enabled for parallax.com. I'm actually surprised at how well things were working even without it enabled. I have parallax.com whitelisted on my other computers, but this is a fresh install of Linux Mint, and I forgot. Now that it's turned on, I have edit buttons again. Yay!
Too bad there hasn't been any official response about the all caps problem though.
My response was official. We do have a setting that affects that feature. I'll tell you what, I will see if I can get someone who has access to the feature to follow-up on my reply. Stay tuned.
In the future; there will be a Forums upgrade. Before that day arrives a team of Parallaxians will discuss all things Forums, so we can make an organized plan of how we wish to move forward. We will include this topic and make a decision at that time.
The limit is set for transforming strings of capital characters 6 or more into lower-case characters. This limit was set in the hopes to prevent shouting, but also allow acronyms and initializations of a specific size with the Parallax product 'The BASIC Stamp microcontroller' in mind. We're sorry if the limit causes problems when discussing legitimate products, services, and other initializations of considerable string length; yes there are ways of circumventing the limits, there usually are, but that does not warrant immediate removal of the limitation.
It will be considered though, and so will abuse of the limitation such as making forum's topics with names specifically designed to circumvent the forums' feature.
Thank you for your input.
