For those making your own PCBs
idbruce
Occassionally there is various chatter in the forum about making PCBs. I am curious just how many people dabble with it and what they prefer, so I am starting a poll.
The first set is an etch-at-home (PulsarProFX system) PCB for a Propeller mini; the second set is my IronMac shield for the DEFCON 22 badge. Both boards designed with DipTrace. IronMac shield was sent to GoldPhoenixPCB. It is a mix of SMD and through-hole.
Good to hear from you.
Yea, sending gerbers to the fab shop would most likely be photographic, unless they specifically stated they would be routed. If the boards were cut on a router, it would be obvious to you.
I have heard the word "stencil" tossed around a little. What is the stencil for?
It does not surprise me that you occasionally make simple boards yourself. I would imagine that you hate waiting just like me and want to test your ideas as soon as possible. I think Phil got tired of waiting and the mess of the photographic process, so he went with the router.
I also think that if you had my tools, you would be creating boards all the time, just for trial runs, before sending them to the fab shop. I rarely use the tools at the moment, but I do have several boards to make, so that should change. At the present time, I have everything necessary to make some fairly nice prototypes, minus the solder mask, silk screen, and plated through holes, but I plan to investigate solutions to the remaining problems as time goes by.
EDIT: On second thought, it almost looks like the shield was routed, but perhaps that is just the look of the fiberglass
So far all of the circuit boards I've made used Toner Transfer method.
I like the idea of SMT and have made one board using Toner Transfer method and SMT resistors.
In the very near future, I'll be attempting to use photographic process, more than likely by a fab shop.
I'm attempting to get familiar with DipTrace.
I think SMT is the now and future, but my eyes are not getting any younger.
gg
The stencil helps you get solder paste onto the SMD pads and nowhere else. Manually applying paste is for the birds! In DipTrace there is a Gerber layer called Paste (I think Eagle calls it Cream) that is just for the SMD parts. You secure the stencil to the board (Rick built a little jig that helps) and squeegee the paste. Lift the stencil carefully and then start placing parts. Rick and I built 10 IronMac shields for DEFCON 22 in just a couple hours -- and that was with a lot of goofing off and drinking beer as we worked. Using a stencil definitely speeds up home production of PCBs.
Discovery
@garyg : I used OrCad, Altium Designer, Eagle and Diptrace is by far the best one (Altium is nice but $$$$). I hate Eagle and I don't know how people can use it, for me it is counterintuitive!
@CuriousOne&all : I would like to see your custom made PCB!
