colorPal 28380
I use the colorpal_flicker.bs2 to display the colorpal flicker. But I close the basic stamp, the colorpal still flicker,and I can't use the colorpal_sense.bs2, I excute the TCS3200_ColorPal_match, it show unable to locate color sensor output on any serial port. Anyone can help me how to stop the colorPal flicker and i can excute the TCS_3200_ColorPal_match.exe
SEROUT sio, baud, ["= #00"]
PAUSE 1000
SEROUT sio, baud, ["!"]
DO:LOOP
Can you give me more information to solve
Make sure ColorPal in connected to PIN 15
' ========================================================================= ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[ Program Description ]--------------------------------------------- ' -----[ I/O Definitions ]------------------------------------------------- sio PIN 15 ' Serial I/O com pin for ColorPAL. ' -----[ Constants ]------------------------------------------------------- ' Baudrate definitions. Serial I/O must be open-drain. The ColorPAL includes ' a pullup internally. #SELECT $STAMP #CASE BS2, BS2E, BS2PE baud CON 119 + 32768 #CASE BS2SX, BS2P baud CON 327 + 32768 #CASE BS2PX baud CON 536 + 32768 #ENDSELECT ' -----[ Variables ]------------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- ' -----[ Program Code ]---------------------------------------------------- SEROUT sio, baud, SEROUT sio, baud, ["= #00"] PAUSE 1000 SEROUT sio, baud, ["!"]
I find the problem, I set the pause on Reset equal to 1000
and the sensor stop to flicker.
And welcome to the forums.
