Problem with XBee communications stalling after a while
Hello,
I have an issue with the Xbee communication.
I exchange data between 2 Xbees in API mode that are connected to propeller boards (C3 boards) but I don't understand why the communication stops after a while.
For testing purpose I am running a repeat loop on both sender and receiver sides. So both propellers are sending and receiving simultaneously.
The protocol that I use for XBee is DigiMesh.
If anyone has a hint I would appreciate
My code is below:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
XB_Rx = 0
XB_Tx = 1
XB_Baud = 9600
TX_PIN = 2
BAUD = 19_200
VAR
Byte dataSet[120],_RxData[105], DigOffset, Inputbyte, Stringptr[200], mot[105]
Long _SrcAddr16, _RxLen, _RxValue, MY_Addr,stack[200], _srcAddr64_upper, _srcAddr64_lower
Byte _RxFlag,_RxIdent, _RSSIDec, _RxOpt, _RxFrameID, _RxCmd[3], _Status, _FrameID, _API_Ready, _RSSI, _RxOptions
Byte dataIn[255], PacketOut[105], PacketPtr
long _RxADC[6], _RxDig, _RxBit[8], _Temp2
Byte srcAddy[8]
''Bytes needed for TxStatus packet
Byte _RxRetries,_RxDeliveryStatus,_RxDiscoveryStatus
''Bytes needed for normal Rx
Byte _RxChkSum
OBJ
XB : "FullDuplexSerial"
pst : "Parallax Serial Terminal"
ASCI
Pub main | ptr,a
pst.Start(115200)
XB.start(XB_Rx, XB_Tx, 0, XB_Baud)
mot[0]:= "d"
mot[1]:= "a"
mot[2]:= "m"
mot[3]:= "i"
mot[4]:= "e"
mot[5]:= "n"
mot[6]:= 0
Stringptr[0] := "d"
Stringptr[1] := "a"
Stringptr[2] := "m"
Stringptr[3] := "i"
Stringptr[4] := "e"
Stringptr[5] := "n"
Stringptr[6] := 0
repeat
XB.RxFlush
API_str($00000000, $0000FFFF, @stringptr)
pst.str(string("String Sent!"))
API_Rx
waitcnt(clkfreq*2+cnt)
API_Query(String("DB"))
pst.str(string("receive debut!"))
API_Rx
pst.Str(String(pst#NL, "RxIdent est:"))
pst.Hex(_RxIdent,2)
pst.Str(String(pst#NL,"le RSSI est", pst#NL))
pst.Dec(_RxValue)
if(stringCompareCS(@_RxData,@mot) == 0)
API_Str(_srcAddr64_upper, _srcAddr64_lower, @Stringptr)
waitcnt(clkfreq+cnt)
API_Rx
coucou := dataIn
pst.Dec(coucou)
else
pst.str(string(pst#NL, "La comparaison n'est pas bonne", pst#NL))
Pub API_Query (cmd)| Length, chars, csum
Sends AT command in API mode to query a parameter value.
Should also be used to set network identifier.
Data is returned as an AT response as a string.
XB.API_Query(string("DL")) ' Query
XB.API_Rx ' accept response
myDL := XB.RxValue ' Get returned value
dataSet[0] := $7E
Length := 4 ' API Ident + FrameID + AT cmd
dataSet[1] := Length >> 8 ' MSB
dataSet[2] := Length ' LSB
dataSet[3] := $08 ' API Ident for AT Command (non queue)
dataSet[4] := $01 ' Frame ID
dataSet[5] := byte[cmd]
dataSet[6] := byte[cmd + 1]
csum := $FF ' Calculate checksum
Repeat chars from 3 to 6
csum := csum - dataSet[chars]
dataSet[7] := csum
Repeat chars from 0 to 7 ' Send data
XB.tx(dataSet[chars])
Pub API_Str(addy64_upper, addy64_lower,donnee)| Length, chars, csum,ptr, stptr, i
Transmit a string to a unit using API mode - 16 bit addressing
XB.API_Str(2,string("Hello number 2")) ' Send data to address 2
TX response of acknowledgement will be returned if FrameID not 0
XB.API_RX
If XB.Status == 0 '0 = Acc, 1 = No Ack
' pst.Str(String(pst#NL))
' pst.str(donnee)
' i := 0
' Repeat (strsize(donnee))
' pst.Hex(donnee[i++],4)
ptr := 0
stptr := 0
dataSet[ptr++] := $7E
Length := strsize(donnee) + 14 ' API Ident + FrameID + API TX cmd +
' AddrHigh + AddrLow + Options
dataSet[ptr++] := Length >> 8 ' Length MSB
dataSet[ptr++] := Length ' Length LSB
dataSet[ptr++] := $10 ' API Ident for 16-bit TX
dataSet[ptr++] := $00 ' Frame ID
dataSet[ptr++] := addy64_upper >>24
dataSet[ptr++] := addy64_upper >>16
dataSet[ptr++] := addy64_upper >>8
dataSet[ptr++] := addy64_lower >>24
dataSet[ptr++] := addy64_lower >>16
dataSet[ptr++] := addy64_lower >>8
dataSet[ptr++] := $FF
dataSet[ptr++] := $FE
dataSet[ptr++] := $00 ' Options '$01 = disable ack,
' $04 = Broadcast PAN ID
Repeat strsize(donnee) ' Add string to packet
dataSet[ptr++] := byte[donnee++]
Repeat chars from 3 to ptr-1
dataSet[ptr] := csum
i := 0
Repeat ptr+1
pst.Hex(dataset[i++],2)
' pst.Str(String(dataSet[i++],pst#NL))
Repeat chars from 0 to ptr
XB.tx(dataSet[chars]) ' Send bytes to XBee
pst.Str(String("message envoy
My code is below:
CON
XB_Rx = 0
XB_Tx = 1
XB_Baud = 9600
TX_PIN = 2
BAUD = 19_200
VAR
Byte srcAddy[8]
Byte _RxChkSum
OBJ
ASCI
Pub main | ptr,a
pst.Start(115200)
mot[0]:= "d"
mot[1]:= "a"
mot[2]:= "m"
mot[3]:= "i"
mot[4]:= "e"
mot[5]:= "n"
mot[6]:= 0
Stringptr[0] := "d"
Stringptr[1] := "a"
Stringptr[2] := "m"
Stringptr[3] := "i"
Stringptr[4] := "e"
Stringptr[5] := "n"
Stringptr[6] := 0
repeat
XB.RxFlush
API_Rx
API_Rx
pst.Hex(_RxIdent,2)
pst.Dec(_RxValue)
API_Rx
coucou := dataIn
pst.Dec(coucou)
else
dataSet[0] := $7E
dataSet[7] := csum
XB.API_RX
' pst.str(donnee)
' i := 0
ptr := 0
stptr := 0
i := 0
Repeat ptr+1
My code is below:
[code]
CON
XB_Rx = 0
XB_Tx = 1
XB_Baud = 9600
TX_PIN = 2
BAUD = 19_200
VAR
Byte srcAddy[8]
Byte _RxChkSum
OBJ
Pub main | ptr,a
pst.Start(115200)
mot[0]:= "d"
mot[1]:= "a"
mot[2]:= "m"
mot[3]:= "i"
mot[4]:= "e"
mot[5]:= "n"
mot[6]:= 0
Stringptr[0] := "d"
Stringptr[1] := "a"
Stringptr[2] := "m"
Stringptr[3] := "i"
Stringptr[4] := "e"
Stringptr[5] := "n"
Stringptr[6] := 0
repeat
XB.RxFlush
API_Rx
API_Rx
pst.Hex(_RxIdent,2)
pst.Dec(_RxValue)
API_Rx
else
dataSet[0] := $7E
dataSet[7] := csum
pst.Str(pst#NL)
pst.Dec(dataSet[5])
pst.Dec(dataSet[6])
XB.API_RX
' pst.str(donnee)
' i := 0
ptr := 0
stptr := 0
i := 0
Repeat ptr+1
Your problem is probably the XB.RxFlush at the beginning of your loop. Your code flushes the buffer, deleting the message that was in it, then sends some stuff, then waits forever for a message that never comes because it already came but you threw it out.
You'll probably find this method useful. Add it to the XBee object:
Pub API_RxCheck | char, pt ' added by AEM {{ Wait for incoming packet until packet identifer found ($7E), or for empty buffer If empty buffer, return 0 Otherwise, process packet and return 1 XB.API_RXCheck Once data is received, the type of packet can be checked for processing: IF XB.RxData == $ 83 ' message string ... See RxPacket Now for more information }} _RxIdent := $FF dataSet[0] := 0 repeat char := FDSerial.rxcheck while (char <> $7E) and char <> -1 if char == $7E RxPacketNow return 1 return 0It receives a message if there's already stuff in the buffer, but returns immediately if there isn't. You can use it so that your code doesn't just sit forever if it misses a message, so it can do something else (like resend the request) if no message comes.EDIT: got rid of FDSerial4P references
Electrodude, I see your nice API_rxcheck is calling FDSerial4P. Is that the 4 port object? I'd recommend that too, but it does require changes in the XBee object. And I'd recommend larger buffers.
JChris, speaking of the serial port, fullduplexserial.spin has only 16 byte buffers. It is possible to overrun those buffers, unless you add support for flow control, or, what I recommend, increase the size of the receive buffer especially so that it can hold an entire 105 byte packet, or more. You said, For testing purpose I am running a repeat loop on both sender and receiver sides. So both propellers are sending and receiving simultaneously. The protocol that I use for XBee is DigiMesh.
The simultaneous business sounds to me like asking for trouble. I haven't followed the logic of your program carefully, but if they are that intense with activity, may they are interfering with one another happenstance and going to retries. Each packet invokes an ack, or not, and retry. The number of retries is finite, and once used up, the packet is lost. It is possible to lose characters too if the small 16 byte receive buffer is overrun. Not sure how this would cause the lockup, but I'd recommend trying an orderly back and forth between the xbees.
Here is a earlier post of driving an xBee ZB in API mode: http://forums.parallax.com/showthread.php/157233-Propeller-to-SmartThings-%28communicating-with-the-ZigBee-HA-public-profile%29
I know you already have the chips but if you can make the jump over to Digi's ZigBee platform a huge world opens up to you.
I implemented hardware flow control to the xBee by connecting CTS P12, and RTS P16 of xBee to available pins on my propeller. If you use the FullDuplexSerial4port object all you have to do is pass those pins when you start the object. You may also want to hook up a wire to the reset pin of the xBee while your at it. On the xBee ZB you have to reset the xBee when you want to leave the network and join a new one stuff like that.
Thanks for finally giving me an excuse to post this: http://obex.parallax.com/object/763. The version of the 4 port serial driver (Duane Degn's) it comes with has 512 byte buffers, which should be big enough for JChris's problem.
About pcFullDuplexSerial4FC512.spin. Duane and I subsequently had quite a bit of discussion about the 4-port object, and my edits became eventually fullDuplexSerial4port. The buffers sizes are individually configurable as CONstants. Your modified version of the XBee object does compile with that. I haven't exercised it with an XBee, but I'd expect it to be okay; in most respects it is functionally equivalent.
Haven't heard yet if the OP has had success.
[code]
CON
port = 0
XB_Rx = 0
XB_Tx = 1
XB_CTS = 2
XB_RTS = 6
XB_reset = 7
XB_Baud = 9600
TX_PIN = 2
BAUD = 19_200
VAR
Byte srcAddy[8]
Byte _RxChkSum
OBJ
XB : "FullDuplexSerial4portPlus_0v2"
Pub main | ptr,a
pst.Start(115200)
XB.Init
XB.AddPort(port,XB_Rx, XB_Tx,XB_CTS,XB_RTS,XB_reset, 0, XB_Baud)
mot[0]:= "d"
mot[1]:= "a"
mot[2]:= "m"
mot[3]:= "i"
mot[4]:= "e"
mot[5]:= "n"
mot[6]:= 0
Stringptr[0] := "d"
Stringptr[1] := "a"
Stringptr[2] := "m"
Stringptr[3] := "i"
Stringptr[4] := "e"
Stringptr[5] := "n"
Stringptr[6] := 0
repeat
XB.rxflush(port)
API_Rx
API_Rx
pst.Hex(_RxIdent,2)
pst.Dec(_RxValue)
API_Rx
else
dataSet[0] := $7E
dataSet[7] := csum
XB.tx(port,dataSet[chars])
pst.Str(pst#NL)
pst.Dec(dataSet[5])
pst.Dec(dataSet[6])
XB.API_RX
' pst.str(donnee)
' i := 0
ptr := 0
stptr := 0
i := 0
Repeat ptr+1
XB.tx(port,dataSet[chars]) ' Send bytes to XBee
