Removing rust my mind on Propeller Assembly subroutine call and ret
Timothy D. Swieter
Hi guys -
Long time since I've been around here. Still love the Propeller, just not many projects recently with it so my Propeller assembly part of my mind has rusted over, I think.
I'm patching and updating code that I created for a client. Below is the snippet. Up till now one case was handled for processing data and it was inline with the whole program. But there are now two cases, so I thought it best to break it out to two subroutines. You can see in my example below the general structure of the program. What I am going for is either 'call #Case1Process' or ''call #Case2Process' is executed and when done it returns to ':Addone' line. The structure I have, I believe, doesn't exactly accomplish this, true? That and c and z aren't preserved through sub-routine calls.
When 'call #Case1Process' is executed, the ret is then to the 'call #Case2Process', correct?
I'm looking for suggestions to how this should be structured such that at the end of Case1Process or Case2Process it returns to the same point in the program.
Thanks - Tim
Thanks - Tim
'Two cases of on/off pairs are handled.
' Case 1 - on value is less than or equal to off value
' Case 2 - on value is greater than off value
cmp cdON, cdOFF wc, wz
if_c_or_z call #Case1Process
if_nc_and_nz call #Case2Process
:AddOne add COGtbl, #1 'Add one to the COG table location (long)
theroutine_ret ret 'Sub-routine complete
'Sub-routine to process Case 1 of on/off pair. On <= Off.
Case1Process
Case1Process_ret ret 'Sub-routine execution complete
'Sub-routine to process Case 2 of on/off pair. On > Off.
Case2Process
Case2Process_ret ret 'Sub-routine execution complete
call #CaseProcess :AddOne add CPGtbl,#1 '-------------------------------------------------- CaseProcess cmp cdON, cdOFF wc,wz if_c_or_z jmp #Case1Process Case2Process '......... jmp CaseProcess_Ret Case1Process '......... Case1Process_Ret Case2Process_Ret CaseProcess_Ret retAll three of those ret labels are at the same address, which allows you to make calls to the Case1 or Case2 subroutines directly if some other part of the code needs it.cmp cdON, cdOFF wc, wz if_be call #Case1Process cmp cdON, cdOFF wc, wz if_a call #Case2Processcmp cdOFF, cdON wc ' carry set for On > Off if_nc call #Case1 if_c call #Case2 :AddOne add COGtbl, #1 ' Add one to the COG table location (long) '----------------------------------------------------------------------------------------------------- 'Sub-routine to process Case 1 of on/off pair. On <= Off. '----------------------------------------------------------------------------------------------------- Case1 ' called with carry clear ... Case1_ret jmpret $, #0-0 wc,nr ' Sub-routine execution complete, clear carryCase1 is called with carry clear so we make sure carry stays clear when this sub-routine returns so Case2 isn't called.cmp cdOFF, cdON wc ' carry set for On > Off movs Case1_ret,#:skip2 'write real return to s-field of RET if_nc jmp #Case1 call #Case2 'no need for condition here :skip2I appreciate all the responses. It was helping my mind get back into PASM mode. localroger's response makes complete sense to me now that I've reviewed those sections of the PASM manual.
