Does Ultrasound echo?
I have a robot the uses one ultrasound sensor and to infrared sensors to navigate (he has tactile sensors too in case the others miss something). I didn't go with two ultrasounds because I thought they might interfere with each other, From the looks of this http://grathio.com/2011/08/meet-the-tacit-project-its-sonar-for-the-blind/ that would not be the case.
Using a multiple ultrasonic array would generally try to avoid this creating a muddle by firing only one sensor at a time and allow for the signal to decay before firing another.
I suppose one could amuse themselves by firing all the array at the same time and then attempt to interpret the data.
