Op-Amp: Voltage follower, negative input, positive output? — Parallax Forums
xanatosxanatos Posts: 1,120
edited 2014-10-04 02:24 in General Discussion
Hi folks,
I need to measure a very high impedance (50k) voltage source that will be in the range of 0 to -5Vdc, using an ADC (probably an MCP3202/4 or similar).
I want to buffer the input since the ADC will significantly load the source, so I want to use an op-amp in a voltage follower configuration to give me - maybe - a few microamps of current drain and not load the source.
Problem is that it's a negative voltage I'm measuring.
So if I use the op-amp in inverting mode with a split supply, will I get 0 to +5V with a 0 to -5V input? Or am I barking up the wrong tree here?
Dave
    edited 2014-09-26 15:27
    Dave,
    Connect your voltage source to the amp's negative input through a resistor of value R. The output is also connected to to the negative input thorugh a resistor of value R. The positive input is grounded. The output voltage will be the negative of the input, andf the input impedance will be R.
    If R can't be made high enough to satisfy your impedance requirements, you can precede the inverter with a non-inverting follower.
    edited 2014-09-26 16:09
    xanatos wrote: »
    Hi folks,
    Dave
    Phil has basically answered this but please note, 50k is NOT "very high impedance" :)
    If you want to have a single supply opamp rather than negative rails you can bias the positive input and with the right resistors it will amplify the difference so you are putting the opamp's differential inputs to good use. It's also unlikely that the source is 50k but more like a few hundred ohms at most but it is specified for 50k loading, this figure being important because you don't want to affect the DC level.
  • pjvpjv Posts: 1,903
    edited 2014-09-26 17:01
    Hi xantos;
    There you received good advice, but .........
    If you are not looking for high precision, and are satisfied with a per cent or so, then you could always skip the external A/D and the op amp, and go straight to a Prop SigmaDelta A/D which will handle negative voltages just fine. All you need is a small capacitor and two resistors connected to two Prop pins, and you're done. The software to do this (about 6 or 8 lines of assembler) is probably also simpler than what you would need to interface to an external chip.
    Cheers,
    Peter (pjv)
  • xanatosxanatos Posts: 1,120
    edited 2014-09-26 17:11
    I do need some fair amount of precision, so I don't mind the ADC/op-amp combo, plus I'm having fun designing this :)
    As for the output impedance not being 50k... I designed that piece myself. The output impedance is exactly 50k, it's the last leg of a 300.050M voltage divider measuring a -30kv supply. I have 0.1mA available across that last 50k resistor, and any resistance across that under about 10M shows on the output... although I may be wanting more precision than is really necessary, I need to have very precise data collection initially.
    I'll post some schematics soon, being called to dinner :)
  • DomanikDomanik Posts: 233
    edited 2014-09-26 17:42
    Following are schematics for Phil's post using an LT1001 (non-rail-to-rail opamp)
    The simulations were made with Linear Techs free tool LTSpice:
    1) Using VCC & VSS at +5V and -5V. Note the current through R-SRC and the drop caused between R-Sig and VSRC. Also note the VOUT is clamped at +4V and mid is +2V not +2.5V if it was inverting accurately.
    2) Added a buffer opamp and the R-Sig & R-SRC track except now the clamp at -4V on VSRC. Notice the R-src current has dropped from 20 micro amps to a few nano amps. Now the clamping of the output at +4V can be seen clearly on the output.
    3) VCC and VSS are bumped up to +7V and -7V. This cleans up the output and will present an accurate voltage to the ADC input. If opamp you select won't go rail to rail the overhead will throw off the readings. It also has some to do with load (20k is better than 1K) If the only VCC you have is +5V it could be a problem and you might need to scale your measured voltages.
    Dom...
    PS: It should work to tie a 30K to a +4V precision reference and monitor the connection at the 30K-300Meg. Then use very low leakage clamp diodes to ground and VCC to protect the opamp input. Just use a single rail opamp as a follower to your ADC and you're done. +1V to +4V equals -30KV to 0V swing and you can use the +5V and no negative supply.
    1024 x 732 - 74K
    1024 x 736 - 82K
    1024 x 734 - 78K
    edited 2014-09-26 19:23
    xanatos wrote: »
    Well in that case you know the characteristics of your circuit then you can either compensate with gain or use a real differential opamp configuration using two opamps. But personally I would just use a single supply rail and bias it so that 0V in was half the ADC reference, that way you measure either polarity as long as you have enough usable resolution.
    @Donamik: I did a quick LTSpice as well but got called to "breakfast" :)
    edited 2014-09-27 09:19
    Hi all,
    Dinner & breakfast all set :) I really haven't got any issue with having a negative and positive voltage source on this project. It's a complete one-off of my own design so I can pretty much design and build it however. I'll probably have at a minimum available to me + & - 5vcd, + & -12vdc, +24vdc, so I can use a non rail-to-rail op-amp with plenty of headroom if my signal in will only go to -5, and my signal out going to +5. The only thing I really haven't got a choice in the matter with is that variable 0 to -30kv supply, since negative voltage is required in this case.
    Thanks for all the SPICE work and the ideas.
    I've attached a sort-of schematic/block diagram of what I'm doing - the voltage divider shows directly, as well as the moment when - after I had sketched the section - I realized "oh yeah, it's going to be a NEGATIVE voltage", and started thinking about a voltage follower in inverting configuration.
    For those who are interested, this is a system to monitor the voltage and current, as well as temperature and vacuum pressure, inside a small deuterium fusion chamber, and display the data on a video overlay on a screen that displays the actual fusion plasma so I don't have to x-ray my eyeballs every time I want to see the plasma configuration :)
    I'll post more when I'm done,
    Dave
    1000 x 701 - 130K
    edited 2014-09-27 10:51
    Dave,
    If you connect one end of your 50K to +5V you can eliminate the opamp. Your 0V to -30KV will have a range of 0V to +5V. This can be fed directly into the ADC. The input leakage of the the MCP3202 is negligible at 1na (0.001% of 100ua). Since the ADC ties the VREF and VDD to one pin the reading will be affected the stability of the power supply. For example if the VDD is 4.5V the readings (0V to 5V) will be off by 10%.
    On another note the high side current monitor looks like it's connected to ground. There are some great devices that will measure small high side currents and level shift it down to low voltage ADC inputs.
    Looks like an interesting project,
    Dom..
    edited 2014-09-27 12:29
    Domanik wrote: »
    Dave,
    Dom..
    Why didn't I think of that? :) Yes - instead of grounding that 50k, just put it to +5v. At -30kv, I'll have 0v, and at 0v I'll have +5 - it'll be inverted but it'll work - am I thinking correctly about this? I can just do some simple math to convert.
    I read that the MCP3202 actually does have some loading since it has to charge a capacitor to sample, but I guess that only kicks in if the sample rate is high. Is that your understanding? Of course, I'll test all of this out on a breadboard anyway, but I want to be sure I have it all straight in my head first.
    Indeed the high side of the current monitor is connected to ground (which will be at full output effectively +30kv above the supply side. ) This allows me to monitor current without the hassles of having anything touching the nasty supply side of this thing (that's going to be about 65mA at 30kv... it would hurt :) ) That should mean that I'll not see more than about a single volt above ground potential on my current metering side. What sort of devices are you referring to for measuring small high-side currents?
    Thanks for the ideas and feedback,
    Dave
    edited 2014-09-27 13:50
    Dave,
    When you fire up the PS it will take awhile to stabilize and the ADC input should track nicely. At 30KV and 300meg you have a constant current source of 100ua charging the 10pf cap. To slew from 5V to 0V takes 21us-- it's a linear slope not the typical RC curve you'd see with a resistor cap. It should work just fine for tracking.
    The overall inaccuracies will creep in because of: 1) how close to 0V can you measure 2) the 1% resistors 3) the fluctuations in the VREF-VDD. If you want to do better than 2% you'll need to calibrate by measuring the 300meg & 50K resistors to LT 0.1% or measure the 30KV accurately and use math to correct. Large value resistors also have stability problems-- new ones should be "burned in" under load for 60 hours. I haven't had experience with high voltages together with large resistors (just 10G at 10V to get down into picoamp measurements to 1%).
    You can Google "high side current monitor". But if one side is "ground" as described you won't need it. Looks like you're measuring current by the voltage drop thru 10ohms at 65ma = 650mv -- so your system ground is referenced to ZERO volts and your power supply is approximately 30,000.65 volts.
    You must have a whopper of a power supply. 30,000V X 65ma / 85% eff. = 2,300 watts Wow-- .
    Dom..
    edited 2014-09-27 14:44
    Yes, the supply frightens me. As well it should! It's fed from two separate 20A circuits in my house.
    As for measurement accuracy, I have a good HV probe that "should" be accurate, although it was probably last calibrated shortly before the last ice age (ie., 1989 :) ) So I will be checking with that and making corrections in my software.
    This thread has been full of good suggestions... I knew this was the place! Thanks all,
    Dave
    edited 2014-09-27 17:35
    Dave,
    If you had a high voltage DC source (like coming off the input caps of a switching supply) you could:
    1) Hook your resistors across it and measure the HV - mine switchers run at approx. 300V
    2) Measure the 300V exactly; it might be 289.7V for example
    3) Measure the voltage across the 50K. It should be about 50mv.
    4) Now you have enough information to find the ratio of your divider and know the real value of the 100Meg resistors
    Whatever value you get should correlate with your HV probe calibrated. I've seen those HV probes be off by huge amounts, like 20% and the meter input impedance has to be part of the calculation to use them.
    Also a safety concern. Imagine one end of a resistor or wire that is normally close to 0V comes loose and the 300M resistor charges that node up to 30KV. The circuit parasitic capacitance would store the charge at 30KV if it didn't arc. That is until it comes into contact with the circuit or discharges through body contact. The amount of current supplied could be more than the 100ua, it could be more like 3Amps. Two clamp diodes in series would hold the node at -650mv if there's a failure and be out of circuit under normal operation.
    Dom...
    edited 2014-09-27 18:20
    Yes, I like the clamp diode concept. That, and you should see the pair of insulated rubber gloves I have :) You have no idea how far my respect for HV goes. I used to build some fairly big Tesla coils about 20 years ago. The fat, muscular arc I would get at my spark gap with a 15kv NST and a cap made me feel very very ... unsafe. That combined with the knowledge I LATER learned that if an arc from the secondary hits you and the primary coil at the same time, it creates a path for the high current primary to find its way directly into you... I was very fortunate. Now I always isolate my primaries from my secondaries with thick lexan barriers and make sure I'm never anywhere near ground! I used to run secondaries between 400kv and 700kv, so I got some great, loud arc clouds from them. The FCC is probably still looking for me :)
    Dave
    edited 2014-09-27 20:10
    xanatos wrote: »
    Dave
    Check that, thanks for updating us on this cold case, we know what to do now, puncture the lexan barriers, one more big bang, problem solved, case closed.
    Kind Regards,
    Your Friendly Cold-case Closer
    edited 2014-09-28 05:59
    Nice sentiments...
    edited 2014-09-28 23:34
    xanatos wrote: »
    Nice sentiments...
    Just like the thread title, negative input....positive output :)
    Seriously though, stay safe, HV is bad enough without even talking about EHV and serious current (and those FCC types).
    edited 2014-10-02 11:16
    Dave,
    You can eliminate your ADC by using the onboard ADC124S021. Here's a link to the hookup and code to make it happen.
    http://learn.parallax.com/propeller-c-simple-circuits/measure-volts
    The other 3 inputs might be useful for the temp, pressure, etc.
    Dom..
    edited 2014-10-03 09:13
    A bit late to this party, my first observation was what would happen if the last resistor in the 30kV divider opened up. Looks like someone else caught it. Further thoughts though on the safety of this design. Realizing the sketch may not be detailed, my concern would be safety related after seeing the energy levels of this system. I would seriously consider isolation of at least the sampling and ADC side of the circuit. Use power supply modules rated for > 40 kV isolation and optical isolation of the digital result. Maybe consider no ADC all, rather a simple voltage to frequency converter which would only use one isolated signal letting the prop determine the voltage from the frequency (counters etc.). But isolate as much as possible for safety in the even of failure. Alternatively, run the whole acquisition side isolated from the world beyond the HV side with blue-tooth, zigbee or fiber optic to the monitoring and display side.
    Call me paranoid (or why do GE, Siemens, Philips and so many other OEMs go overkill on isolation and grounding in x-ray based system),
    Frank.
    xanatos wrote: »
    Hi all,
    Dave
    edited 2014-10-03 19:28
    Frank,
    What a great idea... Isolate the HV by sending a frequency instead of straight voltage. The Analog Devices AD537 is one such device and operates at 10KHz and quiescent current of 1.2ma. You could run it off a 9V battery that is completely isolated from the low voltage P.S. and the prop should easily work as a counter. Don't know what to use as an isolation barrier; perhaps toroidal coil or there might be opto devices with this kind of isolation or a jar capacitor. This project sounds like fun.. Hopefully Dave will share photos and plans for his fusion reactor -- the goal is 1.2 GIGAWATTS!!!!!!!
    Dom..
    Not quite at this voltage but for isolation I have used micro's with onboard ADC in this case where I convert to asynch data and pump it through an opto. A voltage to frequency is not as accurate or precise as the value itself. However for 40kV that opto could just as easily be a discrete IR LED + phototransistor but certainly any RF isolation would be even better, anything from cheap ASK/FSK transmitters (it only needs to be one way) to Bluetooth (but just plain serial).
