LED bulbs
RDL2004
In my most recent order from Newegg I added one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16803105029
It puts out some nice light, very even and the color is fine. Note that its only 35 watt equivalent and non-dimmable though.
I got it on sale for $6.95 now today I see it's $3.95 (and 99 cents shipping), not quite an erco deal, but still a good price. I think I'll order a few more. Maybe I'll buy one of their 55 watt equivalent while I'm at it and see if I can make those go on sale too.
All my LED bulbs continue to work. I've been very happy with them. The little Phillips bulb in the fixture where incandescent bulbs would burn out every few months has easily paid for itself many times over. I just finished revamping my closet workbench/lab and added a couple of the Cree daylight bulbs in there. I used daylight in there because it blends with the fluorescent lamp I have over the bench. Everywhere else I've gone with warm white.
And some of those bulbs are sold under the store brand (like Lowes, Home Depot, Walmart, etc.)...
And those stores only have a 90 day return policy!
So ask how exactly you can return them if they break in say 1 year! (Say:It says on the package distributed by your store, so they should be returned here!)
For the record, the Rosewill bulb from Newegg has only a 2 year warranty (based on 4 hrs per day usage)and the Cree bulbs have a 10 year warranty (based on 6 hrs per day). The packaging of the Rosewill bulb does not say how they will cover the item, just gives a web address and a "support" e-mail. The Cree packaging basically says send the bulb back with "proof of purchase", receipt and your name and address and they will refund or replace at their option. I guess you have to cover the return shipping yourself. The "proof of purchase" is the UPC bar code from the package. I wonder what happens if you threw it away. I kept mine just in case.
http://www.amazon.com/Cree-9-5-Watt-White-2700K-Light/dp/B00BYG7O8A/ref=sr_1_2?ie=UTF8&qid=1411186518&sr=8-2&keywords=cree+led+bulb
or this:
http://www.amazon.com/Cree-9-Watt-Daylight-Dimmable-1-Pack/dp/B00BXFP0SS/ref=sr_1_3?ie=UTF8&qid=1411186518&sr=8-3&keywords=cree+led+bulb
And compare them to your current led bulbs, you will see the huge difference, along with 10 year warranty...
If you really want led light that is super pleasing, then go for this. It is damn expensive, but believe me, it really has amazing light.
http://www.digikey.com/product-detail/en/LMH020-0850-40G9-00001TW/LMH020-0850-40G9-00001TW-ND/3748278
you will need matching driver for it:
http://www.digikey.com/product-detail/en/LMD125-0018-C440-1010000/LMD125-0018-C440-1010000-ND/3131792
generic drivers WON'T WORK, or you need linear power supply.
AND you'll need matching heatsink:
http://www.nuventix.com/downlight-led-heatsink-48/
I actually have the Rosewill cheapy in the lamp where I am right now. It's about 16 inches away and as far as I'm concerned the quality of light is more than acceptable.
http://forums.parallax.com/showthread.php/157471-Another-American-company-soon-to-be-no-more....?p=1294007&viewfull=1#post1294007
Can I ask the same here? Do you plan to control LED bulbs with prop or stamp?
I found these flat plastic Phillips LED "bulbs" that have pretty good light at Home Depot. They are also dimmable, they were $8. But so far all the LED bulbsare either too green or not enough amber.
Why do you ask?
I posted a link to a good buy on an item that is electronic in nature and relatively modern technology. Quite similar to probably many hundreds of other posts here.
Because it seems you apply a different standard to yourself than to select others.
And yes, erco posts are valuable.
And yes, I'm also interested interested in LED light.
And yes, I find myself shining a spotlight on officiousness ever since I learned the meaning of the word. (Its a cool word, when you think about it. The kind word one wishes one didn't have to employ)
And yes, some things should just be ignored. Probably shouldn't have brought it up.
Google has partnered with Cree and FIRST to make these bulbs available at low cost to FIRST teams so that they can use them for fundraising.
I think that any post that encourages conservation of energy or other resources has a place in the general forum, and low prices for led bulbs certainly qualifies for that.
I would encourage everyone to switch to led lighting where possible, and would suggest marking the light with the install date to track how long they last. The majority of the cfl's I have replaced have on average lasted as long as promised, and the led bulbs are all still working, although they have not been in use long enough to see if they live up to their promises.
Color Quality- I purchases orange theatre lighting gels, and put a bit over the LED. The patio flood light is the cold blue that attracts every bug for 100 yards. With the orange gel, almost no bugs. Apperantly (via wikipedia) all bugs see blue light, fewer see yellow light, and very few see red or infrared. But red is also difficult for humans, so I stepped back from red and up from yellow.
I had extra so I also did the same to the warm white exterior light in other locations. Very few bugs.
Can anybody verify these results?
Color temperature is often an issue with public outdoor lighting. Apparently many communities object to night time light which is perceived as being "too blue". There is also research that indicates that blue colored light suppresses the human biological clock causing sleep distubances, which may be a good reason to avoid it in home use.
The US Department of Energy has available the "Model Specification for LED Roadway Luminaires, (docx link) published in July 2014. In it they recommend a correlated color temperature of 4100K, which is considerably different from the 6000-6500K bulbs often sold as daylight. A Philips publication (pdf link) states that "In many countries warmer variants are used for urban and pedestrian walkways, while the cooler temperatures are used for roads and expressways, depending on local preference".
Tom
OK, I called CREE. They said that since it was in the 90 day Home Depot return period, I should have returned it to HD. I told the representative that I did try, but HD said that since it was used and had worked a few days that I had to deal with CREE. The rep made a comment about how do you find a bulb defective w/o using it; we both laughed and she said they will be sending a replacement. She also said that the package will have instructions for sending back the defective bulb (so don't throw it out). I was hoping they would say that since maybe they will do an autopsy to find out why it failed and what to upgrade in version 2.
Tom
Sounds promising. http://www.digitaltrends.com/home/new-acandescent-lighting-technology-just-efficient-led-also-considerably-cheaper/
From FinallyBulbs Web site..
That looks interesting, but they have mercury in them and are only 55 lumens/watt, no better than current CREE bulbs that Home Depot sells for under $10. Newer LED bulbs are over 100 lumens/watt and will eventually be cheap. I have many LED bulbs in my house, mostly BR40 size from various manufacturers, and I can't see any different between them and an equivalent incandescent. Other than the price (BR40 bulbs are only $13 now at Costco) I'm quite happy with them.
Good reviews - I bought 3 pkgs (6 bulbs)
http://www.homedepot.com/p/Philips-60W-Equivalent-Soft-White-2700K-A19-LED-Light-Bulb-2-Pack-455576/205815532
http://www.usa.philips.com/c-p/046677455507/led-bulb
Prices sure are dropping. I got a notice from FIRST last week that they are no longer going to sell the Cree bulbs to FIRST teams. The retail prices have dropped so much that their prices, while still less expensive, are not competitive enough with the big box stores.
These new Philips bulbs are rated at 10,000 hours versus 20,000 for more expensive bulbs but at $2.49 a pop you get for the price of the CREE original bulbs (if dimming isn't important to you).
These things rock, at $2 for 7 watt / 60 watt incandescent equivalent, you can't beat 'em with a stick. (or your wife will complain about the broken lamp).
I've stuck with the Cree as I've usually been able to find them on sale at HD far below the cost of Phillips. Last year I got a 6-pack for $29 IIRC.
Not sure how good the newer ones are, though I've read conflicting reviews.
http://www.gizmag.com/new-cree-led-bulb/34462/
Here's a neat NewEgg special if you've got any kids: http://images10.newegg.com/productimage/A654_130789212698849264MiEehzCVVc.jpg
