Memory {#40004) module question
I have a written a large routine, and the memory map tells me I am running out of space, (760 longs left).
I looked at the propeller memory card (#40004), the application ideas sections says, execute code from external memory
Is it possible to execute blocks/snippets Of code stored on the module? I looked at the related object on the object exchange
and it appears That it may be possible, but I am not sure. My ideal situation would be to call a pub from the memory module
and have the propeller execute the code as it is received from the memory module. If this is possible, does anyone have
a simple example of How This is done, that they are willing to share?
My alternative solution is to simply add another prop and connect it serially. I know this
Would work, but its more expensive and I wouldn't get to play with the memory module.
Thank you in advance for any help.
Larry
Larry
Larry,
You didn't mention if you're using C or Spin. I think it's easier to run large programs with C but it's also possible to do this with Spin.
Can you give us more information about your project? Sometimes some of the data can be stored externally and pulled in as needed.
One of my large projects is a robot remote with a touch screen. I was running out of memory but I was able to move all the text to the various menus to the SD card which greatly reduced the size of the code on the chip.
There are some threads about how to load Spin methods from a SD card I'll find the links and add them to this thread in a bit.
There are lots of tricks to making use of the space in the Propeller. Brad's Spin Tool (BST) removes unused methods. localroger has done some cool stuff showing how to use the same object multiple times with a program without having the object take up much space.
If you wanted to post your code, one of us may see ways you reduced its size.
Be doing some testing. My program is entirely in Spin. I could not attach my file to this posting,I got an error
message "578kb exceeds the limit of 488kb".
The sd card looks like a cheaper Alternative to the memory card or the additional prop.
Larry
Binary files to it. I used windows explorer to verify that they were there. I double checked the sd pin assignments. All looked okay but this is the result I got:
Could not open test1.bin
test1.bin returned a value of 0
Could not open test2.bin
test2.bin returned a value of 0
Could not open test3.bin
test3.bin returned a value of 0
I then tried some old sd card test programs which use the fat0 driver. I could write
And read okay to the card.
I then tried modifying the code using the fat0 driver, I got the same result.
I am stuck, any suggestions would be greatly appreciated.
Larry
Apparently the newer driver performs some additional checks one the SD card and if it sees a problem it won't mount the card.
I've had to reformat several of my SD cards before they would work properly with the new driver. I had to use the long formatting method, if I tried using "quick format" the card still wouldn't work with the new driver.
In other words it's a feature not a bug (or at least that's what I was told).
I can still write and read test data using fat0 (kyes object) If it wasn’t for bad luck with this project, I wouldn’t have any.
My next effort is find another sd card and give it a try.
I looked at your link of projects, very very impressive, after looking at your accomplishments, I considered throwing away all my propeller stuff and taking up golf
Larry
I tried three separate cards. I formatted each card again using the slow method. Each card worked okay on simple
write read tests using the"SD-MMC_FATEngine.spin” driver. Each card failed when I ran the overlay.spin program using the fsrw driver.
I am now formatting the card at 16kb to see if that will help.
I did find one error, I was reading safe_spi_c3.spin and on line 92 I found this
Statement:
This is a compatibility wrapper, and requires that the pins be
both consecutive, and in the order DO CLK DI CS.
return start_explicit( basepin, basepin+1, basepin+2, basepin+3 )
I had this backward in my program, I corrected it, but still no luck.
Larry
I noticed you are using two different drivers. Kyes Fat_Engine and FSRW.
Kyes Fat_Engine works fine for SD cards using Fat16 and Fat32. Depending on your Version of FSRW you might have trouble to use SD cards > 2GigaByte. The older Versions of FSRW do not support SD cards > 2GigaByte.
Since you wrote about not having the sysdep object I guess you have just FSRW included in Dave Hein's zip.
So download FSRW (2.6?) from the obex.
sysdep is the object to adjust pin settings to met your board design.
run the demos to verify FSRW can access your SD cards.
REPLACE fsrw in Daves zip with the newer version of fsrw.
try again.
Kye's Fat_Engine is way more sophisticated as FSRW. It supports Sub directories and a lot of other things FSRW does NOT support.
But it is also WAY slower. @Lonesock and @Rockiki(?) did a real great job with a fast SD card access without directory support.
just my 2 cents
Enjoy
to work with fullduplexserial. I wired my board as described in “sdspiqasm” using the 20k pullup
resistors described and making sure they were on all six pins. I tried running “fsrw_speed” and got this:
Mounting.
Returned from start
-13
I did note that the fsrw object says “ This object provides FAT16 file read/write access on a block device”.
As suggested by others, I was using a 2GB sd card, but it was formatted At 32kb. The problem now became,
windows would not allow formatting a 2GB card at 16kb. I took an 8GB card and formatted it for 16kb.
I tried running “fsrw_speed” again and Got the same results. In order to validate my hardware I wrote, then read
some test data to the sd card using the "SD-MMC_FATEngine.spin" driver. The tests were okay.
Here is fsrw_speed program modified for full duplex serial that I used:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 obj debug: "fullduplexserial" sdfat: "fsrw" var byte tbuf[20] byte bigbuf[8192] pub go | x debug.start(31,30,0000,19200) x := \start debug.str(string("Returned from start", 13)) debug.dec(x) debug.tx(13) pub start | r, sta, bytes 'debug.start(12) debug.str(string("Mounting.", 13)) sdfat.mount(0) 'this sets pin 0 as the basepin' fsrw sets the other pins in order starting at 0 debug.str(string("Mounted.", 13)) debug.str(string("Dir: ", 13)) sdfat.opendir repeat while 0 == sdfat.nextfile(@tbuf) debug.str(@tbuf) debug.tx(13) debug.str(string("That's the dir", 13)) debug.tx(13) sta := cnt r := sdfat.popen(string("speed.txt"), "w") repeat 256 sdfat.pwrite(@bigbuf, 8192) sdfat.pclose r := cnt - sta debug.str(string("Writing 2M took ")) debug.dec(r) debug.tx(13) sta := cnt r := sdfat.popen(string("speed.txt"), "r") repeat 256 sdfat.pread(@bigbuf, 8192) sdfat.pclose r := cnt - sta debug.str(string("Reading 2M took ")) debug.dec(r) debug.tx(13) debug.str(string("That's, all, folks! 3", 13))I have tried everything, I would really welcome any additional suggestion
Larry
This may not make any difference in your case, but I've had all kinds of problems with the Quickstart + Memory board that were solved by using an external power brick. It seems like the USB +5V current is not really enough sometimes, and the Quickstart doesn't have the best PCB power layout with 0.01" traces. One of the USB ports on my Mac Mini has gone bad by using boards that are too power hungry. Sometimes my Windows 7 PC will simply reset if I plug in a hungry USB board that doesn't have an external power supply.
First of all you need Version 2.6 not 1.6(?) of FSRW.
Second: I am confused by 'sdspiqasm' - what is it and where it comes from?
FSRW and demo should only use 'sysdep' and 'save_spi'
else
I can not find error code -13 in FSRW. Is it maybe -23? That would be 'NO TWO FATS'.
Reading your post carefully I guess that you changed the default cluster size of your SD cards while formatting in windows?
You should not do things like that at all.
SD cards up to 2 GB use FAT16 file system by default. Bigger ones need FAT32 also by default, when you buy them.
The difference is how the content of the card is accessed by the driver. FAT16 addresses BYTES. So with a word pointer you end up at 2 GB and then is end.
SD cards > 2 GB address the content by SECTORS of 512 bytes. Thus the same word pointer now reaches up to a Terrabyte.
BOTH - Fat_Engine and FSRW 2.6 can read SD cards > 2 GB (SDHC) without problem as they come from any store without any reformatting.
The cluster size should be 32K (is default)
@jazzed has another point.
Feeding the board thru USB has many problems. One is that you can not really switch your board OFF.
So the SD card still is active, and stuck in the last sequence. While working with my 4 SD card RAISD board I often struggled with this.
You rerun your program, and the program is even OK, but it does not run. The SD card got stuck. (not resetting , since powered)
Solution:
Either remove power for a minute before your test run or remove the SD card and put it back. I learned that the hard way. And removing power includes removing USB connection.
Them SD cards are finicky. They need very low power to stay 'alive' in their state machine. Way less as if active and reading or writing.
Take a new not mangled with SD card. Scandisc or so. size does not matter.
Get FSRW running as described in download from obex, Look at the html files.
Since Kye's Fat_Engine works your board should be OK.
well - some suggestions, at least.
Enjoy!
I had downloaded so many fsrw files that it became
Unmanageable. I erased everything I had downloaded and started again.
I downloaded fsrw version 2.6 and its associated files. I had a minor glitch in that
Fsrw.spin would not compile. It was looking for an object named
“sysdep.spin” and not finding it. I found a file named “sysdep_demo_ser.spin” which
Was part of fsrw download. I renamed it “sysdep.spin”
To my amazement I was able to successfully run test.spin (part of the download) and all was okay.
I then copied fsrw version 2.6 and its associated files to the folder containing the new download of overlay.spin.
I opened and saved a binary file of test1,test2, and test3 to the sd
Card. I installed the sd card on my board and tried running overlay.spin. The
Result was the same:
I visited my local walmart to purchase some new 2gb sd cards, unfortunately they
Were out of stock. So I am on hold until I can acquire some new sd cards.
I will post when I have the results with the new sd card
Larry
