Is it possible to run the Propeller Mini with 5v?
JohnR2010
I have a project that requires more current than the 5v, 1a output of the propeller mini will source. I already have a 5v 3a source for my project and I would like to know if it is possible to not use the 6.5 to 12vDC Vin port of the propeller mini and just hook up my existing 5v to the 5 Vdc regulated output pin of the propeller mini? From looking at the schematics of the mini It looks like that will feed the internal 3.3 volt regulator and therefore power the propeller just fine.
I'm trying to eliminate the need for another 6.5v power source.
If you have a regulated 5V supply you should be able to connect that to the 5V pin on the Mini. I will double check that the regulator used can tolerate that.
By the way, this is how the BASIC Stamp Modules work. You can power them from VIN or VDD.
Thanks Chris let me know if your find-out otherwise. I just placed an order for a couple of units and I was going to try it but I thought I would ask and see if there were any concerns.
Yep saw the same thing in the schematic. The drawing didn't match the parts list. I was thinking the parts list on the second page was correct but not sure. Thanks for looking into it!!
http://forums.parallax.com/showthread.php/152334-Prop-Mini-power-supply
The current schematic (Rev A version 1.2 1/28/2014) lists VR1 as an LM2940 in the BoM, but on the diagram it's shown as M24512. According to the BoM, VR2 is supposed to be a 3.3 volt LM2940, but it's shown as the 5 volt version on the diagram.
As listed in the BoM, an M24512 is the eeprom. However, the schematic diagram shows a 24LC256 eeprom. I thought the Propeller Mini was supposed to have a 64KB eeprom, what is actually used?
Basically the latest published schematic shows 2 (two) different eeprom chips but only 1 (one) regulator in the diagram, whereas the BoM lists one eeprom and two regulators. It seems the revised version 1.2 of the schematic added more errors than it fixed.
Thanks Rick for pointing me to the previous post on this. I read through all three pages and saw suggestions from driving the Vin pin with 5v (far bellow the recommend voltage) to doing what I want to do by connecting 5v to the v-out pin. I would still very much like Chris to make a recommendation as I didn't see a definite answer. David Betz said he did this and it worked fine. David also asked if this could be done with the 3.3v v-out pin I have that same question.
Chris I have two questions now:
1) If I want to drive my prop mini with an external regulated 5v power supply is it okay to connect it to the 5v v-out pin of the prop mini (no connection on Vin pin)?
2) If I want to drive my prop mini with an external regulated 3.3v power supply is it okay to connect it to the 3.3 v-out pin (no connection on 5v v-out or Vin pins)?
If your interested I'm going to use the Prop Min to drive Digi's xBee ZB SMT chip with a ZigBee Home Automation library I have written in SPIN.
Here is a screen shot of the PCB I'm working on:
Link to my ZigBee Home Automation post on your forum: http://forums.parallax.com/showthread.php/157233-Propeller-to-SmartThings-%28communicating-with-the-ZigBee-HA-public-profile%29
Thanks!
It turns out I am not in Rocklin today. I took a couple days off. However, I am not going to leave you hanging. David Carrier should be in the office today and can get access to the complete internal information on the Prop Mini from our network. He can post a definitive answer for you. I am going to link your last questions post to him right now and then will follow up in a bit to see if he has been able to answer it. If not I will drive down to Rocklin today and get the information myself. :thumb:
Regard the original question of whether you can power the Propeller Mini's Vin pin with 5 VDC, it should work, but it will leave the 5-volt regulator in full dropout, so the power consumption will be a littler higher than normal. You can also connect the 5-volt supply to the 5V pin to power the Propeller Mini. It may leak some power into the Vin pin, so I recommend leaving the Vin pin unconnected.
— David Carrier
Parallax Inc.
Sorry, that is not totally correct. Please read my post #9. The current schematic diagram shows VR1 as an M24512 and VR2 as a 5 volt LM2940.
However, the BoM is correct according to your post, listing the part numbers for VR1 as an LM2940-5.0 and VR2 as an LM2937-3.3
You should probably double check that the diagram and BoM in the new schematic agree.
I meant to say and link to the original schematic, which wasn't too far off. I don't know what the v1.2 schematic was going for with the M24512 part number on VR1, since it is an EEPROM.
Speaking of the EEPROM, I just notice that the schematic says that it is a 24LC256, but there is a good chance that it is an M24512. I'll check on that and update it if necessary.
— David Carrier
Parallax Inc.
Edit: It is an M24512. That will be corrected on the updated schematic, too.
Edit: The schematic is now up: http://www.parallax.com/sites/default/files/downloads/32150-Propeller-Mini-RevA-Schematic-v1.3.pdf
Unlike what Loupey seems to think, many of us still like to know what we are getting when we spend our hard earned money.
