Turning on LEDs remotely with xbee — Parallax Forums
DavidNymanDavidNyman Posts: 52
edited 2014-09-18 18:27 in Accessories
I've got a project where I need to turn on or off three LEDs in another room. I've downloaded the circuits from Parallax Simple_Byte_Rx.BS2 and Simple_Byte_Tx.bS2 and got them up and running with two Xbee S1 radios. I can turn on the LED just as the program is designed to do. Here's my problem:
I'm not versed well enough with xbees yet to have much luck modifying the code. At first it looked like simple cut and paste to add a few LEDs, but I learned very quickly it wasn't that easy.
On the base (Tx), I have three normally open momentary pushbuttons tied to PIN 0, PIN 1, PIN 2. The inputs are pulled low with a 2.2k resistor to ground and the switches are tied to +5 effectively bring the input high when the button is pressed, otherwise the circuit is wired just as the program shows.
The remote (Rx), has three LEDs, Red, Yellow and Green tied to PIN 0, PIN 1 and PIN 2 through 220 ohm resistors. The rest of the circuit is wired just as the program for the receiver shows.
On the receiver, the buzzer isn't needed and I haven't included it on my breadboard mockups.
Can anyone help me add control over two more LEDs?
Here's the initial programs as downloaded from Parallax:
' Simple_Byte_Tx.bs2
' Sends the state of pushbutton every 250mSec
' {$STAMP BS2}
' {$PBASIC 2.5}
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T9600 CON 84
#CASE BS2SX, BS2P
T9600 CON 240
#CASE BS2PX
T9600 CON 396
#ENDSELECT
' ***************** Variables, Constants and Pins
Baud CON T9600 ' Set baud rate
Rx CON 15 ' XBee DOUT
Tx CON 14 ' XBee DIN
PB PIN 0 ' Pushbutton
State VAR Bit
' ***************** Main Loop
DO
State = PB ' Read pushbutton
SEROUT Tx, Baud,[State] ' Send pushbutton value as byte
PAUSE 250 ' short delay
LOOP
' Simple_Byte_Rx.bs2
' Receives byte value (0/1) to control LED and buzzer
' {$STAMP BS2}
' {$PBASIC 2.5}
#SELECT $STAMP
T9600 CON 84
#CASE BS2SX, BS2P
T9600 CON 240
#CASE BS2PX
T9600 CON 396
#ENDSELECT
Baud CON T9600 ' Set Baud rate
State VAR Bit
Led PIN 0
Buzzer PIN 5
DO
SERIN Rx, Baud, [State] ' Wait for byte and accept
IF State = 1 THEN ' Based on value,
HIGH LED ' if 1, Turn on LED
FREQOUT Buzzer,200,3000 ' Sound buzzer
ELSE
LOW LED ' if 0, turn off LED
ENDIF
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
#SELECT $STAMP
T9600 CON 84
#CASE BS2SX, BS2P
T9600 CON 240
#CASE BS2PX
T9600 CON 396
#ENDSELECT
State VAR Bit
DO
LOOP
    edited 2014-09-13 16:46
    Hi, David.
    I've seen this Subject languish for several hours with nary a response.
    If nobody gets around to it in the next few days then I'll jump in.
  • DavidNymanDavidNyman Posts: 52
    edited 2014-09-13 17:33
    I'm getting closer. I realized that I would need some data flow control to pull this off. I started looking at "Manual_Polling_Base.BS2 and Polling_Remote.BS2 and got some inspiration. With a few cut and pastes, I came up with what is printed below. The circuit is up and working great between the remote and base as long as I run the Base terminal program to control my LEDs on the Remote. I need to remove the terminal usage and change to 3 buttons wired to PIN 0, PIN 1 & PIN 2.
    Here's where I'm at currently:
    ' Manual_Polling_Base.bs2
    ' This program:
    ' - Configures XBee for fast AT Command Mode
    ' - Using DEBUG Window, User can control Remote
    ' - R-RedLED, Y-YellowLED and G-GreenLED.
    ' - Address changed to a constant.
    ' - Accepts an acknowledgement value
    ' - Requires 802.15.4 XBee (Series 1)
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
    T9600 CON 84
    #CASE BS2SX, BS2P
    T9600 CON 240
    #CASE BS2PX
    T9600 CON 396
    #ENDSELECT
    Green_button PIN 0
    Red_button PIN 1
    Yellow_button PIN 2
    Rx PIN 15 ' XBee DOUT
    Tx PIN 14 ' XBee DIN
    DataOut VAR Word ' Frequency to send
    DL_Addr CON $2 ' Destination address for data
    DataIn VAR Byte ' General variable for data
    Light VAR Word ' Returned light level
    ' ***************** Configure XBee in AT Command Mode
    PAUSE 500
    DEBUG CLS,"Configuring XBee..."
    PAUSE 3000 ' Guard time
    SEROUT Tx,Baud,["+++"] ' Command Mode Sequence
    PAUSE 2000 ' Guard time
    SEROUT Tx,Baud,["ATGT 3,MY 0",CR] ' Set low guard time and Base address
    SEROUT TX,Baud,["ATCN",CR] ' Exit Command Mode
    DO
    GOSUB Config_XBee ' Set DL address of XBee
    DEBUG CR,"Choose Action:",CR,
    "R - Red LED",CR,
    "G - Green LED",CR,
    "Y - Yellow LED",CR,
    DEBUGIN DataIn ' Accept choice
    SELECT DataIn ' LED control, get state and send
    CASE "G","l"
    DEBUG CR,"Enter LED State (0/1):"
    DEBUGIN DEC DataOut ' Accept user data
    DEBUG "Sending Data!",CR
    SEROUT Tx,Baud,["G",CR,CR] ' Send G
    SEROUT Tx,Baud,[DEC DataOut,CR,CR] ' Send LED state
    GOSUB CheckAck ' Get Acknowledgement
    GOTO Done
    CASE "R","l"
    SEROUT Tx,Baud,["R",CR,CR] ' Send L
    GOTO Done
    CASE "Y","l"
    SEROUT Tx,Baud,["Y",CR,CR] ' Send L
    GOTO Done
    ENDSELECT
    Timeout:
    DEBUG "No data received",CR
    Done:
    PAUSE 2000
    LOOP
    Config_XBee:
    ' Configure XBee for destination node address
    PAUSE 10 ' Short guard time
    SEROUT Tx,Baud,["+++"] ' Command Mode sequence
    SEROUT TX,Baud,["ATDL ", HEX DL_Addr,CR] ' Set Destination Node Address
    SEROUT Tx,Baud,["ATCN",CR] ' Exit Command Mode
    RETURN
    CheckAck:
    SERIN Rx,Baud,1000,CheckTimeout,[DEC dataIn] ' Accept incoming byte
    IF dataIn = 1 THEN ' If 1, then ack'd
    DEBUG BELL,"OK - Ack Received!",CR
    ELSE ' If received, but not "1", problem
    DEBUG "Bad Ack!",CR
    ENDIF
    RETURN
    CheckTimeout:
    DEBUG "No ack received!",CR ' If nothing recieved
    RETURN
    ' Polling_Remote.bs2
    ' This program accepts a character and values:
    ' - G & 0 or 1 to control state of LED
    ' - R & 0 or 1 to control state of LED
    ' - Y & 0 or 1 to control state of LED
    ' Return acknowledgements or value to Base
    ' Requires 802.15.4 XBee (Series 1)
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
    T9600 CON 84
    #CASE BS2SX, BS2P
    T9600 CON 240
    #CASE BS2PX
    T9600 CON 396
    #ENDSELECT
    '****************** Variable, Constants and Pins
    Baud CON T9600
    GLED PIN 7
    YLed PIN 6
    RLED PIN 5
    'Servo PIN 12
    RTS PIN 11 ' XBee RTS
    Freq VAR Word ' Received frequency for buzzer
    GState VAR Bit ' Received state of green LED
    RState VAR Bit ' Received state FOR red LED
    YState VAR Bit ' Received state for yellow LED
    DataIn VAR Byte ' General byte data
    Light VAR Word ' Measured light level
    Position VAR Word ' Received servo position
    My_Addr CON $2 ' Set address of node, modify as desired, $1-$FFFE
    ' ***************** Configure XBee to use RTS and set Address
    Position = 750
    PAUSE 500
    DEBUG CLS,"Configuring XBee...",CR
    SEROUT Tx,Baud,["ATD6 1",CR] ' Enable RTS
    SEROUT Tx,Baud,["ATMY ", HEX My_Addr,CR] ' Set node address
    SEROUT Tx,Baud,["ATDL 0,CN",CR] ' Set destination address of Base
    ' & Exit Command Mode
    DO
    GOSUB AcceptData
    GOSUB Control
    LOOP
    AcceptData:
    SERIN Rx\RTS,Baud,10,Timeout,[DataIn] ' Accept byte
    SELECT DataIn
    CASE "G" ' G to control Green LED
    SERIN Rx\RTS,Baud,1000,Timeout,[DEC GState] ' Accept LED state
    PAUSE 200 ' Give Base time to set up
    SEROUT Tx,Baud,[CR,DEC 1,CR] ' Return acknowledgment
    CASE "R" ' R to control Red LED
    SERIN Rx\RTS,Baud,1000,Timeout,[DEC RState] ' Accept buzzer frequency
    CASE "Y" ' Y to control Yellow LED
    SERIN Rx\RTS,Baud,1000,Timeout,[DEC YState]' Accept position
    PAUSE 200
    ENDSELECT
    Timeout:
    RETURN
    Control:
    IF GState = 1 THEN ' Control LED based on state
    HIGH GLED
    ELSE
    LOW GLED
    ENDIF
    IF YState = 1 THEN ' Control Buzzer based on Freq
    HIGH YLed
    ELSE
    LOW YLed
    PAUSE 100
    ENDIF
    IF RState = 1 THEN ' Control Buzzer based on Freq
    HIGH RLed
    ELSE
    LOW RLed
    PAUSE 100
    ENDIF
    RETURN
  • GenetixGenetix Posts: 1,775
    edited 2014-09-13 23:38
    Hello David,
    In PBASIC there are several variables that control the input and output of the BS2. IN0, IN1, and IN2 tell you what the input states of Pins 0, 1, and 2 are. INA tells that states of Pin 0-3, so you only need the line State = INA. There are similar variables for output as well. The BS2 pins start out as inputs so you would need change pins to outputs and this is done using the DIR variable. DIRA = %0111 will change Pin 0, 1, and 2 to output. Then you could add the line OUTA = State.
    Look up DIR, IN, and OUT in the Basic Stamp Manual.
    http://www.parallax.com/downloads/basic-stamp-manual
    That should get you started. You should write a simple test program though to test each of your switches and LEDs so you know they work before you start modifying programs.
    DEBUG ? IN0 ' Print the value of Pin 0 on the screen
    High 0 ' Turn on LED
    PAUSE 500 ' Wait for 1/2 second
    Low 0 ' Turn off LED
    Good Luck!
    edited 2014-09-14 08:43
    Well, after a long night, Here's the finished code. It's working great. I can set the remote unit in the kitchen and run it from the garage.
    Time for the happy dance.
    Thanks very much for the help.
    Here's how it turned out:
    ' Desktop transmitter.bs2
    ' 14 Sept 2014
    ' This program:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    T9600 CON 84
    Green_button PIN 0
    Red_button PIN 1
    Yellow_button PIN 2
    PAUSE 500
    ' ***************** Main Loop***********************************
    DO
    IF IN0 = 1 THEN GOSUB Green_Push_Button ELSE GOSUB Green_Off
    IF IN1 = 1 THEN GOSUB Yellow_Push_Button ELSE GOSUB Yellow_Off
    IF IN2 = 1 THEN GOSUB Red_Push_Button ELSE GOSUB Red_Off
    LOOP
    '*******************Subroutines*********************************
    Green_Off:
    DataOut = 0
    PAUSE 200
    RETURN
    Green_Push_Button:
    DataOut = 1
    PAUSE 200
    RETURN
    Red_Off:
    DataOut = 0
    SEROUT Tx,Baud,["R",CR,CR] ' Send R
    PAUSE 200
    RETURN
    Red_Push_Button:
    DataOut = 1
    RETURN
    Yellow_Off:
    DataOut = 0
    SEROUT Tx,Baud,["Y",CR,CR] ' Send Y
    PAUSE 200
    RETURN
    Yellow_Push_Button:
    DataOut = 1
    RETURN
    Timeout:
    Config_XBee:
    RETURN
    CheckAck:
    DEBUG "Bad Ack!",CR
    ENDIF
    RETURN
    CheckTimeout:
    RETURN
    ' Wall Light.bs2
    ' 14 Sept 2014
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    T9600 CON 84
    Baud CON T9600
    GLED PIN 7
    YLed PIN 6
    RLED PIN 5
    DO
    GOSUB AcceptData
    GOSUB Control
    LOOP
    AcceptData:
    SELECT DataIn
    SERIN Rx\RTS,Baud,1000,Timeout,[DEC GState] ' Accept Green LED state
    CASE "R" ' R to control Red LED state
    SERIN Rx\RTS,Baud,1000,Timeout,[DEC RState] ' Accept Red LED state
    SERIN Rx\RTS,Baud,1000,Timeout,[DEC YState] ' Accept Yellow LED state
    PAUSE 200
    ENDSELECT
    Timeout:
    RETURN
    Control:
    IF GState = 1 THEN ' Control Green LED based on state
    HIGH GLED
    LOW YLed
    LOW RLed
    ENDIF
    IF YState = 1 THEN ' Control Yellow LED based on state
    HIGH YLed
    LOW GLed
    LOW RLed
    ENDIF
    IF RState = 1 THEN ' Control Red LED based on state
    HIGH RLed
    LOW GLed
    LOW YLed
    ENDIF
    'DEBUG CLS
    'DEBUG "GState = ", DEC GState,CR
    'DEBUG "YState = ", DEC YState,CR
    'DEBUG "RState = ", DEC RState
    RETURN
    edited 2014-09-14 10:26
    DavidNyman wrote: »
    What help?
    You did it all, dude.
    I guess that you noticed that you needed to come up with a value for "DataOut" when the input was not 1.
    (That could be boiled way way down, but as long as you're dancing it's good.)
    edited 2014-09-15 08:41
    I apologize David, I did not see your thread until this morning and by then you had it solved. It's great to see that you kept going and solved your issue. If you need help again, please don't hesitate to post. I do usually check the forums on the weekends, but this weekend I was unable to.
    Thanks everyone. Somehow posting the problem made me look at it more closely and eventually figure out an answer. A learning experience in itself!
    I've changed the program a little in that now the base unit latches the input from the three buttons. I added three LEDs to the base unit for indication as to which LED is illuminated on the remote. One challenge has been finding yellow LEDs that are somewhat bright. Even the so called super bright yellow don't come close to the red and green ones used in the project for brightness.
    I learned a little too late about a hand held controller that was briefly available on Kickstarter. Now that the finished "favor" project is delivered to the new owner I'd like to eventually turn the circuit and program into something like this:
    http://quantumri.com/Q4.html
    I've emailed this company several times to inquire about purchasing one of these controllers. I never get a response so now it's time to build my own.
