My SPIN logic is misbehaving
Hi
I'M attempting to get my LCD display to show two different motor speeds.
When I press the P7 touch button, the MOTOR 2 speed should be reduced by 8.
This fairly works.
MOTOR1 should be displaying a value of 1111 on the LCD display, but it displays -1.
The PUB speed LCD should only update if a the button is pressed but the loop continues all the way always.
Any help with resolving this situation would help a lot
This fairly works.
OBJ
LCD : "FullDuplexSerial.spin"
Buttons : "Touch Buttons"
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
TxPin = 8 'TXPIN IS PIN #8 ON THE QUICKSTART BOARD.
VAR
LONG STACK[20]
long sp3
long sp1
long sp2
long flag1
PUB Main
sp1 := 1111
sp2 := 9999
sp3 := 1111
flag1 := 0
Buttons.start(_xinfreq / 6) ' Launch the touch buttons driver sampling 100 times a second
dira[23..16]~~ ' Set the LEDs as outputs
LCD.start(TxPin, TxPin, %1000, 9_600)
WaitCnt(ClkFreq / 100 + Cnt) ' Pause to initialize
LCD.tx(12) ' Clear
LCD.tx(17) ' Turn on backlight
LCD.str(String("Motor1")) ' First line
LCD.tx(13) ' Line feed
LCD.str(String("Motor2")) ' Second line
LCD.tx(212) ' Set quarter note
LCD.tx(220) ' A tone
WaitCnt(ClkFreq * 3 + Cnt) ' Wait 3 seconds
LCD.tx(18) ' Turn off backlight
speed 'speed calls the Speed object to run
PUB Speed
repeat
outa[23..16] := Buttons.State
flag1 :=outa[23]
if flag1 ==1
sp2:= sp2-8
flag1:=0
if sp3<>= sp2 'Only update the LCD if the speed number has changed.
LCD.TX(136) 'Move cursor to line 0, position 8
LCD.Dec(sp3) 'Print Motor1 speed to LCD
LCD.TX(156) 'Move cursor to line1, position 8
LCD.Dec(sp2) 'Print Motor2 speed to LCD
WaitCnt(ClkFreq * 1 + Cnt) ' Wait 1 second
' sp3:= sp2+0 ' sets sp3 equal to current speed number sp2
LCD.tx(220) ' A tone This tells me if this part of the loop was executed.
For code display use [noparse] [/noparse].
Your suggestions worked out very good.
The loop only runs when the pushbutton changes, otherwise it's is skipped.
I was able to add the ' sp3:= sp2+0 ' sets sp3 equal to current speed number sp2
Is updating the sp3 value in the above manner the best way to do that?
It appears to work, but it would seem to me like sp3:=sp2 should also work but it did not seem to work.
When I 1st power up the quickstart and LCD display, my default sp2 and sp3 settings are displayed.
After the 1st button press, the Motor1 and Motor2 displayed numbers are always 8 different.
For this particular application, it really does not matter.
I was using the default settings of sp2 and sp3 as a start.
The end result was exactly what I was looking for.
I'll be using this strategy to control the speed of HB25 motor controllers with a Parallax Keyfob remote.
You made my day.
