I need help to update ps2 controller bascom avr
need help about bascom avr code for test ps2 controller working
i need to led at porta.0 on when i press any button from ps2 controller
this code must be do this
but not working ???
' Project: PlayStationII Wireless (or wired) controller reader
' Version: v1.0
' Created: 2010-03-27
' By: Glen Aidukas (C)Bahbots.com
' Credits: Original help from Eddy Wright on the PS2 protocol
' Description:
' PS2 Shockwave controller wiring and PSI data reading
' _____________________________
' | |1 2 3||4 5 6||7 8 9| | <-- Male connector of controller
' \___________________________/
' Pin Color Function Notes
' 1 GREEN MISO Data In
' 2 WHITE MOSI Command out
' 3 VIBRATE +9V
' 4 BLACK GND
' 5 RED VCC 3.3V-5V
' 6 BLUE SS Select
' 7 YELLOW SCK Clock
' 8 N/C N/C
' 9 ACK N/C
' This code was tested and working with a wireless PlayStationII controller
$regfile = "m32Def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 16
$framesize = 48
$baud = 38400
'=====[ Dimension and initialize variables ]====================================
Dim Ps2_cmd(2) As Byte ' init cmd sent to PS2 controller
Dim Ps2_data(7) As Byte ' hold returned data from PS2 controller
Dim I As Byte ' General purpose variables
Ddra = &B11111111 'port a outpur
Porta = &B00000000
'------------------------ 'porta = 0
Ps2_miso Alias Pinb.0 : Ddrb.0 = 0 ' data in
Ps2_mosi Alias Portb.1 : Ddrb.1 = 1 ' data out
Ps2_ss Alias Portb.2 : Ddrb.2 = 1 ' Select
Ps2_sck Alias Portb.3 : Ddrb.3 = 1 ' Clock
Ps2_miso = 1 ' turn on internal pull up resister
Ps2_cmd(1) = &H01 ' Start Command
Ps2_cmd(2) = &H42 ' Request Data
Do
Gosub Ps2_read ' read the PS controller data
If Ps2_data(2).0 = 222 Or Ps2_data(2).0 = 222 Then
Porta.0 = 1
Waitms 250
End If
Loop
'=====[ Read the PS2 controller data ]==========================================
Ps2_read:
Ps2_ss = 0 ' assert select line
Shiftout Ps2_mosi , Ps2_sck , Ps2_cmd(1) , 2 , 8 , 20 ' send start command
Shiftout Ps2_mosi , Ps2_sck , Ps2_cmd(2) , 2 , 8 , 20 ' send request data cmd
For I = 1 To 7
Shiftin Ps2_miso , Ps2_sck , Ps2_data(i) , 2 , 8 , 20 ' read in data
Next I
Ps2_ss = 1 ' release select line
Return
but not working ???
Do Gosub Ps2_read ' read the PS controller data If Ps2_data(2).0 = 222 Or Ps2_data(2).0 = 222 Then Porta.0 = 1 Waitms 250 End If Loop
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59
This forum supports other microcontrollers and programming languages.
