C Code for GPS
NWCCTV
Just wondering if anyone has any SimpleIDE code for the PMB 648 GPS Module. I have some Spin code and I suppose I could attempt to convert it if necessary but I think I would still need a library for it, correct? I doubt Parallax will be doing anything for it since it has been replaced but if anyone knows where I could start I would appreciate some advice.
The PAM-7Q GPS Module does have GPS code that runs in SimpleIDE:
https://www.parallax.com/product/28509
I'm wondering if it would work without changes on the PMB-648.
I used spin2cpp to translate a GPSPropeller spin project that was developed from I.K
I'm sure it is something simple but not sure what!!!
Ah, you may need to reset the Project Options in SimpleIDE (requires being in Project View)... Board type should be for your particular propeller board (Activity Board? Seems that Activity Board SDXMMC does NOT work, here!). And, you'll need to reset the Memory Model to LMM or CMM or even any other one model once you'v changed the board type.
As soon as I did the above, re-compiling worked without issue...
dgately
