windows 7 64 bit - questions — Parallax Forums
twm47099twm47099 Posts: 867
edited 2014-09-09 08:09 in General Discussion
I am going to have to get a new computer. Currently I am an XP (32 bit) user, and I've been shopping for a Windows 7 tower/mini tower. Looking at Dell my choice is Windows 7 Pro 64 bit. Looking at HP I can get either Windows 7 home or pro (both 64 bit).
Two questions: 1. Is there anything special about Windows 7 pro?
2. Does 64 bit OS mean I have to replace all my current 32 bit software (things like adobe Lightroom, Corel Paint Shop Pro, games, LT Spice, etc? Or can I still run them on the 64 bit system?
Tom
    edited 2014-09-07 20:27
    Many 32-bit apps will work, but not all, depending on how old they are. Most software publishers provide a list of supported features. Microsoft at one time had a Win7 upgrade advisor that would scan your machine looking for incompatible software and drivers, but with Win8 now out, I'm not sure if they still have it. Obviously, you don't need to worry about incompatible drivers, as you're getting a whole new machine.
    Games are iffy anyway, because they often depend on the video card you have. You may need to verify the card on the machine you want supports all the OpenGL/etc features needed by your games. If not you'll need to upgrade the card, which is an added expense.
    Win 7 Pro is nice, so if the price is similar, I'd opt for it. There are some advantages, and Microsoft provides a comparison to see if the added features are worth it to you. For example, Pro supports an XP emulation mode that can be handy for very old software. If it were me, I'd get a machine with Pro on it.
    edited 2014-09-07 20:33
    I think the Pro version gives you more network options. I had XP Pro and I could access any file on any computer on my home network but with 7 Home, I haven't been able to get this to work again. DropBox has eliminated this problem since I can access DropBox from any of my computers so I just keep shared files there.
    As Gordon said, some of your old software might work but don't count on it.
  • xanaduxanadu Posts: 3,347
    edited 2014-09-07 20:37
    Can you post the full specs of the two computers in question?
    Pro vs regular - http://en.wikipedia.org/wiki/Windows_7_editions
    edited 2014-09-07 20:41
    Gordon, you don't need Pro to run the XP mode, it's a download.
    7 Pro from Dell is usually a good deal because it comes with a Windows 8 license as well. I don't think HP is doing that with their home premium computers.
    edited 2014-09-07 20:47
    xanadu wrote: »
    Well, not according to Microsoft (see "Before you begin"):
    http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
    but maybe they've updated it since this page was published, and they didn't come back to correct it. As noted on the page it might download and install on Home, but not properly run.
    edited 2014-09-07 20:50
    One more thing, the best thing to do with your software is Google it. Google the software name, version and Windows 7 64 bit. For example, Adobe Lightroom 3 windows 7 64 bit.
    There are a couple scenarios you will see:
    1. Vendor says they do not support Windows 7 64 bit because they do not want to support it, however the software will run just fine.
    2. Vendor says they do not support Windows 7 64 bit, but the software will run in compatibility mode.
    3. Software will not run no matter what. (XP Mode)
    Don't forget to check your printers and devices too.
    edited 2014-09-07 21:08
    When viewing vendor info about compatibility note that most only list the earliest version that will run under Win7, with the assumption that all later versions were developed with Win7 in mind.
    As you have at least one Corel product in your list, you can cross-check here:
    http://www.corel.com/corel/pages/index.jsp?pgid=800577
    You'll find it curious that Corel doesn't actually make a distinction between running 32- or 64-bit Windows 7, either because they didn't know to, or didn't think they should have. The earliest tested version of PSP is X3, which is actually fairly old as software goes. They're up to X7 now.
    Do note that even the latest versions of many software packages are still 32-bit applications. Corel WordPerfect is (and likely always will be) a 32-bit app; the latest Corel Draw is available in a 64-bit version. Microsoft Office 2013, which only runs in Win7 or later, has both 32- and 64-bit installs, though always defaults to 32-bit, even on a 64-bit system. You have to tell it otherwise when you install.
    Adobe packages several of their programs in both 32- and 64-bit versions. That's the case for more recent editions of Lightroom, for example. In some instances you can install both versions, and use whatever one best fits the third-part add-ins you have. I use the 64-bit version of Photoshop almost exclusively, though there are some plugins that won't work with it, and I have to fall back to the 32-bit version.
    edited 2014-09-07 21:25
    I may be wrong. I know a lot of hardware that is geared toward x32 Home Premium doesn't support virtualization so that would make sense.
    I'll test it, I don't have a lot of experience with "non-pro" versions. It probably still shouldn't be a determining factor since there are so many other ways to run XP.
  • twm47099twm47099 Posts: 867
    edited 2014-09-07 21:35
    xanadu wrote: »
    Thanks for the link. Regarding the full specs, I haven't gotten that far yet. I will get microsoft office (home and student with Word, Excel, Powerpoint and some Note software. It doesn't have Outlook, but I've never used that on any of my home computers.) Right now I'm thinking 8G Ram and a 1T hard drive. Is that considered sufficient? My XP computers have 3G Ram which has been ok. I always seem to run low on disk space, but I only have an 80G C-drive and a second built in of 300 G. (by the way, this raises a totaly unrelated question that I'll ask at the end of this post.)
    I'll need some USB 2 and want some USB3 ports. The Dell has 6 USB3 ports, but don't mention USB2. I've read that USB3 ports can connect to USB2 devices. Is that correct?
    I will get a DVD burner. I'm not sure about video card or monitor yet,
    Any other suggestions?
    Now for the unrelated question.
    Because of the small C drive on my XP computers, I have used the second drive to install most of my programs, including the photo software, turbo tax, games, SimpleIDE, PropTool, etc. I use Norton Ghost to make images of both the C and second drive. In my recent problem it appeared that I either had a virus or the XP OS got corrupted. I did restore C using the Ghost image I had made a few months ago, and copied more recent files I had backed up a couple of weeks ago (after doing a virus scan of the backups.) Things seem to be working ok now. Question - is using the large second drive for programs (other than OS and office) a reasonable thing to do or is there some (potential) problem that I setting myself up for?
    Should I get a second internal drive for the new computer and do the same thing.
    Thanks for all your help
    Tom
    edited 2014-09-07 22:16
    8GB RAM and 1TB hard drive is okay for general multitasking and file storage. I see that you image drives using ghost. Imaging a 1TB drive using Ghost will take a lot longer than you're used to.
    You have to be careful with specs, CPU, video and the form factor of the PC play big roles too.
    USB 2.0 works on USB 3.0 ports, there have been a lot of reports of the USB 3.0 chipset doesn't play nice with some USB 2.0 devices. It always comes down to a transitory period where you find out. You could always add USB 2.0 via the PCI bus (pay attention to form factor here).
    Using more than one drive has pros and cons. With both drives on the same drive controller there is a marginal increase in performance by putting frequently accessed files on separate drives than the OS. Another good example for two drives is video editing. If you have your raw video files on one drive, and encode them to another drive you gain a little performance there.
    Cons of two drives... I guess you have increased heat and power consumption. Some new computers may not even have a spot for you to mount it. It's another part to fail, but that shouldn't matter if you backup.
    If I were to have two drives I would do a RAID 1. Are you familiar with RAID?
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-09-07 22:28
    Games are generally not an issue on Windows 7. I have the Pro 64 bit version and all of the over 50 games in my Steam library run fine. Some are 10 year old games and others are very recent. Just make sure you get a video card that's good enough. I'd recommend an Nvidia 500 series or better with 1 GB of RAM.
    Consider getting an SSD for your boot drive. Nothing else will make as dramatic a difference in how fast the computer responds. Prices are reasonable these days and you don't need more than 120-256 GB. Crucial and Samsung are good brands. Use the SSD for Windows and install your most frequently used software and games on it, put everything else on a second data drive. Make sure you back up both.
    I don't much like Dell, HP is okay I guess. I actually prefer to assemble my own.
    edited 2014-09-07 22:57
    Rick, 50 Steam games, really? If you want to add me I'm "Xvv"
    TWM, Rick brings up a couple good points. SSD performance and build your own PC. He also mentioned he doesn't like Dell. I don't blame anyone for not liking certain brands, and when it comes to workstations, towers, PCs, etc there have been some "bad" brands.
    Sony VIAO and their RAID 0 as a default system configuration on their website.. They were usually Western Digital brand, decent MTBF and typical 1yr warranty. I don't think it would have mattered. That line of PCs probably started a lot of the data recovery places we know today.
    I don't have anything against HP when it comes to workstations, but their online server configuration sucks when it comes to storage. Dell DRAC is so much better than HP iLO too. I work remotely so this kind of stuff matters a lot to me. I'm not sure if it trickles down into the PC market. I do know that with Dell you're getting a business class PC (because they don't have Win 7 for home anymore). That means way less preloaded software, if that matters. Since the HP is going to have Win 7 Home Premium on it, I also bet it's loaded with all kinds of software that's going to make you want to fresh install.
    We're left with assemble your own, and these days it couldn't be easier. I don't like building PCs, but I don't like pre-configured PCs either, and often save money by building. Would you consider building it yourself?
    edited 2014-09-07 23:24
    twm74099
    xanadu
    I love the casual way you guys bandy these numbers around. That's HUGE. Speaking as a guy whose first ever computer had 16 kilobyte of RAM and only audio cassette tape for storage.
    Still, now a days such specifications are chump change so you may as well throw it in there for any kind of normal PC work. Normally I can throw such a machine together from spare parts hanging around the office.
    Only two slightly meaningful comments here:
    1) Put your OS on an SSD. A 128GB SSD will cost as much as that tera byte drive but my SSDs are the best upgrades I ever made to any machines. As RDL2004 says the improvement is dramatic.
    2) I would never by a DELL or whatever ready made PC tower. It's so cheap and easy to assemble your own machine and get just what you want.
    3) We can never say anything is "sufficient" unless you say what you want to do with the machine. I would have a very hard time filling up a tera byte drive (This PC I'm typing on only has 128GB SSD and that is only half full). You however may have many times that much data, who knows?
    Edit: Yeah, yeah, that was three comments.
    edited 2014-09-08 01:59
    I don't think it's right to say the only slightly meaningful thing includes an SSD and white box PC. You just have to choose a pre-built system carefully. There are also a lot of factors in building it yourself.
    Those Dell Optiplex Win 7 Pro come with next business day onsite hardware replacement. If you build your own PC, Heater shows up to fix it! Trust me, by time he leaves you're going to wish the thing didn't break!
    edited 2014-09-08 02:50
    Make bl**dy certain they use the largest possible RAM modules.
    Most vendors will shaft you by installing many small modules, so that you'll have to toss out one or more when upgrading later.
    Second the 'Two drives' setup.
    But if the big one is a Hybrid (Spinning platters of rust + SSD baked into one) it won't exactly hurt performance.
    edited 2014-09-08 05:12
    xanadu,
    No, Heater says: "Learn how to fix it yourself Which you probably have done all ready having built the thing.
    Hey I'm not such bad company.
    Certainly for work I buy ready made PC's with service agreements.
    For home, well, I have never actually bought a PC or a laptop. My machines have been salvaged or built from spare parts or even new parts. PC's are such horrible things I can't bring myself to buy them new.
    I certainly don't want to pay the Windows tax no matter how small it is.
    Anyway despite the service level agreements on office PC's I had not noticed that the hassle they cause when they fail and the rate at which they do it is any less that the DIY stuff.
    edited 2014-09-08 06:14
    I can confirm that Corel PSP X3 runs on W764, it runs as a 32-bit app. I also have PSP X6 on another W764 machine and it has the option of installing as either a 32-bit or 64-bit app or both. The reason one might want to install the 32-bit version is if you have any plug-ins for PSP that don't yet support 64-bit.
    Check out the Dell outlet store at http://www.dell.com/outlet
    You can sometimes find really good deals there, I have two precision laptops and two printers that were all purchased as refurbs that have been in daily use for 5 years or so now. I also purchased a Precision workstation that was raising ECC error codes on boot. They replaced the mobo and RAM, that did not resolve the issue, they asked if I would be OK with just shipping me a NEW machine, can't say I was unhappy about that! Ended up with a fairly loaded brand new T7400 for half price. I did lose a DIMM and the hard drive in the past year, but the machine is usually running 24/7 so I don't think that is out of the norm for failures.
    I also have a dell server that was purchased new that has been in constant use for around 7 years with no issues.
    I agree with Heater that building one can be fun and sometimes save a few bucks. I used to do that in younger days, but now I usually don't have the time or patience and just need to get something up and running and go with off the shelf machines.
    C.W.
    Edit: I would also suggest going with the Pro version of Windows, it does offers more networking options regarding remote access, etc.
    edited 2014-09-08 07:32
    xanadu wrote: »
    Thanks everyone for the comments and advice. I did look at Dell and added an SSD. Then the magic happened. It seems with a Dell once you add an SDD (125G) you have to start with a more expensive computer and to add a HDD to that you need a even more expensive computer. I see the attraction for building your own system.
    @xanadu
    At one time I knew what the different RAIDs did. After I had some problems with a nasty virus on a previous computer and found my auto recovery points were also contaminated, I didn't like anything that made an automatic image on a backup drive. I preferred to do it manually after I did everything I could to make sure the original was clean (I realize that's not a 100% thing).
    But I don't recall what the different RAID types are and the advantages/disadvantages are and would appreciate comments /recommendations.
    Thanks again
    Tom
    edited 2014-09-08 08:20
    Take a look at some of the newer mini computers and "barebone" systems that are available such as the Intel NUC, etc. You still have to add a few parts yourself (SSD and memory usually) and install an OS, but they're not that hard to set up. You might have to rely on external USB drives for storage with some of these due to their very small size (many are meant to attach directly to the back of a monitor or TV), and the video could be a limitation in some cases if you're into heavy duty gaming.
    http://www.newegg.com/Barebone-Mini-Computers/Category/ID-3?name=Barebones-Mini-PCs
    edited 2014-09-08 08:45
    One core difference between Win 7 64 bit and 32 bit is running of unsigned drivers. The 64 bit OS won't run them without being in some special testing mode. For some of your hardware, this could be a problem as unsigned drivers are common with low end or cheaper devices. My video capture device suffered from this and it took me a long time picking through some other drivers to find a signed library to substitute. And that one does not have the same capture quality performance the unsigned one did.
    IMHO, Window 7 32 bit is a lot more like XP where it comes to running older, off beat things. If you have this use case, the 32 bit OS could make good sense. I'm actually going to upgrade my old XP machine to the 32 bit OS, for this reason, along with some legacy hacks I keep around for those times I want / need to work with older hardware.
    Otherwise, get the 64 bit version. Win 7 64 is a great OS. I run some really big stuff on it, and I find it performs very nicely.
    edited 2014-09-08 10:59
    Heater. wrote: »
    (8GMB RAM and 1TB hard drive) I love the casual way you guys bandy these numbers around. That's HUGE. Speaking as a guy whose first ever computer had 16 kilobyte of RAM and only audio cassette tape for storage.
    In my world 8GB RAM and 1TB storage is barely enough to even start the software, let alone load a project and process it. I'm up to 24GB RAM, two processors, and 2TB, and on one drive I'm down to my last 60 GB.
    I also started with a TRS80 with the same RAM and storage, but is that relevant for what we use computers for today? I didn't, and couldn't, use my Trash-80 for editing video and rendering CG. I imagine text-centric applications like Word and Excel are perfect contenders for a machine with 4 or 8GB, as would be many business-oriented graphics. Rendering HD cinematics consumes a lot of resources, but I realize this is not a terribly common use case. The happy thing about is a machine with the required specs isn't all that expensive these days.
    edited 2014-09-08 11:32
    Well, Gordon, for sure if you if you are working with video you need a lot of space. In all directions. No way am I suggesting an 8 bit machine with 64K of RAM will pull it off.
    Mind you, I would expect the software to at least start with a few megs of RAM. I can't imagine that anyone has written a single app that needs a terabyte for it's executable code.
    Like I said, we cannot say if any machine is sufficient until we know what it is expected to do.
    edited 2014-09-08 11:47
    It seems like the two most demanding things that people do on PCs these days are games and video editing. Video apparently requires lots of RAM, fast processors and big disk drives. Games require actual dedicated graphics cards, but since most are designed to also run on consoles with minimal changes, processor speed and RAM are not as much of a limitation.
    edited 2014-09-08 16:05
    Heater. wrote: »
    twm74099
    xanadu
    My first computer was a COSMAC ELF (I think it had 4 or 8 Kb.)
    My second (pre MSDOS) computer had 16 kB user ram and used 52 Kb 5-inch floppies.
    My first MSDOS computer had a 10Mb drive. As I added software I started having problems when it got 60% full. I don't remember the Ram, but I do remember the joy of waiting while overlays swapped in and out. Photo editing of 5Mpixel scans was very slow. Because of hardwired BIOS, I couldn't up grade the drive.
    The next computer was a windows machine with a wonderful 40Mb drive and (I think) 1 Gig Ram. Same problem as the smaller computer because Windows ate up a lot of those resources. Each time I up graded, so did the bloat in Windows, photo software, etc.
    The computer I'm looking at has Windows 7 on it -- Microsoft has all versions of Windows 7 installed, but only activates the one I would be licensed to use. The computer also has Windows 8.1 installed (although that won't be my active OS.) I assume these OS and newer versions of Microsoft Office have not gotten any smaller, either on the drive or in the RAM. In addition my cameras now output 24+ Mpixels, and more of my photo processing is done with multiple layers of 48 bit RGB.
    I guess my questions should have been - With an empty system (except for the OS and office if loaded) how much HDD and Ram is available in a 1T HDD and 8G Ram system.
    thanks
    Tom
    edited 2014-09-08 17:31
    twm47099 wrote: »
    A new, bare machine will use maybe 1/20th (or less) of the drive for core Windows components, but that's a useless number as it's your software and DATA that matters. Working with camera RAW photos takes up a lot of space, particularly if you save different versions of your edited work.
    Windows will use as much RAM as it needs, and the system has, but for ordinary things won't usually require more than say, 2-3G. You'll have plenty for your apps. Office 2013 really doesn't take up all that much space in the scheme of things.
    Though the 1TB main drive is probably enough -- and you can always add a second internal drive later -- if you have the budget, I'd recommend getting maybe 12GB. It's usually cheaper to upgrade now, rather than later. As Gadgetman mentioned earlier, they often populate the RAM in such a way that you will have to replace all the the existing sticks if you want more, and buy your RAM all over again. (Of course you can check that before you buy. If it's a single 8GB stick, or even two 4GB sticks, then that's not so bad.) As desktop computers have a useful life of 3-5+ years, think about where you'll be in a few years time, and try to buy for that.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-09-08 18:03
    IMO, Running any 32 Bit system these days is just not worth the time. You are maxed out at 4GB RAM and no matter how fast your CPU is, if your memory can not keep up your system will still be sluggish. I dropped 32GB in to my Quad Core system back in January. I can render a Blu Ray video in under 20 minutes. It took 2 plus hours before. I am considering bumping up to 64 or even 128 GB. Funny how that is more than double the HDD I had in my first computer.
    edited 2014-09-08 19:45
    NWCCTV wrote: »
    Down memory lane here ... first hard drive I had was the Hard Disk 20 for the Mac 512 -- as in 20MB, not 20GB. The next year I splurged and got a 10MB hard disk card for my Morrow CP/M machine. It had a serious fault that if the power went out, the heads would crash, requiring a reformat. Cheap as it was, the thing used a stepper motor rather than a voice coil to move the heads.
    Funnily enough, I still use an old Win95 machine for my CNC. Its hard drive is all of 1GB. I remember when I first got it, a computer for my son so he could play his favorite game, The Incredible Machine. Seemed like a HUGE drive at the time. This was when I was using Syquest 100MB removable hard disks.
    edited 2014-09-08 20:13
    Gordon, My first experience with computers was when a company I worked for purchased a WYSE system. They about went broke buying it!!!!! These were just dumb terminals with no CPU, just Networked together. I was so infatuated with that system that soon after I bought a 386 ZEOS (remember them?). It had a 40 MB hard drive. Several months later they came out with an 80 MB and I was in heaven!!!! Not long after that another company I had worked for gave me all there old 286's. I spent many hours after work learning to Network them in my garage. Memory on them were on a LARGE expansion card. Fast Forward a couple years and I started my own repair business!!!
    In the pre-PC days many businesses opted for a thin client, rather than go with a "hobby" machine, even the TRS-80 III. My first writing gigs were at companies that used Wang word processors and networked terminals hanging off a VAX. Software then was horrendously expensive, so for my own "serious" machine I went with one of the early Osborne 1s, which came with bundled software, including WordStar. I used it without a printer for the longest time, writing and editing my stories on the Osborne, then when finished transcribing them onto the typewriter. It was floppies all the way, and 90K density at that. I could get quite a few stories on a single disc.
    In many ways I really liked these early days of computing. Everything was frightfully costly -- I remember the day I spent $45 just for a 6' Centronics printer cable -- but you didn't need as much junk to complicate your life. My biggest worry was could my printer ribbon last one more round of shooting it with WD-40 to stretch out the ink!
