ActivityBot tutorials with a PropBOE?
David Betz
Can the ActivityBot tutorials be used with a robot that has a PropBOE rather than an ActivityBoard? Are the two similar enough? If not, are there instructions somewhere describing what needs to be changed to use a PropBOE in place of an ActivityBoard? I was under the impression that the ActivityBoard was basically just a stripped down PropBOE. Is that true?
I'm not sure what other differences there are which would cause you trouble when using a PropBOE instead of an ActivityBoard.
AB uses P12-P17 for servos while the BOE uses P14-P19
AB ADC is P18-P21 while BOE ADC is P28-P29 (Same as EEPROM)
P20 and P21 of the BOE are used for the Microphone.
AB uses ADC124S021 while BOE uses AD7993-1
AB uses FT231X while BOE uses FT232R
AB uses LD29150PT50R while BOE uses LM3478
Breadboard connections (P0-P15), MicroSD (P22-P25), Audio (P26-P27), EEPROM (P28-P29), and Serial to PC (P30-P31) are all the same.
