Installing Basic stamp editor software on a Mac
Hello,
I am new to microcontroller programming.
I just got a Basic Stamp microcontroller and I have a Macbook Pro with OS X 10.0.2
Please can someone assist me on how to install the Basic Stamp editor on my Macbook Pro.
Can the editor be installed directly on OS X 10.9.2?...or do have to get a virtual machine with Windows OS and install the editor on there..?
Please wait for someone more Mac-savvy than I to comment on using the Mac version vs. the Windows virtual machine version. Help generally arrives pretty quickly on this forum.
I checked out the links.
My Macbook runs OS X 10.9.2 though....the link says it the Basic Stamp editor software will not run on OS X 10.7 and later versions
Did you try this download?
http://www.muratnkonar.com/otherstuff/macbs2-experimental/downloads.shtml
It is supposed to support 10.7 (Lion) and newer. Version 3.0.6. (From the Parallax page erco linked to).
I installed MacBS2 with PBasic v 2.5
Currently, the Debug terminal cannot take/receive input data from the keyboard.
I am new to micro controller programming.
Thanks.
http://www.furrysoft.de/?page=goserial
set baudList to {1200, 2400, 4800, 4800, 9600, 19200, 38400, 57600, 115200, 230400} set baudRate to (choose from list baudList default items {38400}) tell application "Terminal" set serialDevices to (do shell script "ls /dev/cu*") set theDeviceList to (paragraphs of serialDevices) as list set theDevice to (choose from list theDeviceList) do script "screen " & theDevice & " " & baudRate display dialog "To quit your terminal session type <ctrl-a> then <ctrl-\\>" end tellhttp://freeware.the-meiers.org/
You can switch between MacBS2 and the terminal window, but you have to disconnect on the terminal each time you want to load a new program into the Stamp. That is, if you are using the BASIC Stamp debug port both for programming and for debugging within your application program.
:nerd:
Any words of encouragement? Has anyone successfully used a newer Mac with MacBS2 lately? Is there some special kind of USB to serial connector I need to be using. I am using the same cable that I used when it worked on a Windows box.
to top line position in code. Also have to reboot my iMac almost every time I want to pull off BoeBot for trying out new code. The MacBS2 loses access to Serial Port until I reboot. Any ideas on that problem? Seems like I saw a reference to this problem last year.
