multicore conflict happened in using microSD card and fdserial — Parallax Forums
KevinKKKevinKK Posts: 27
edited 2014-09-01 15:37 in Propeller 1
I try to make a project that ActiviryBot can navigate/avoid with a mounted turning Ping))) sensor , play music from microSD card and communicate with Bluetooth. I try to use three additional cogs, however, the playing microSD card cog and bluetooth communication cog just can't run correctly in the same program. When I block either of the two cogs, the problem will not happen.
Does anyone can tell me that the two cogs can't open it simultaneously ?
mult.c
    edited 2014-09-01 15:29
    I think you're trying to access the microSD card routines from two separate cogs at the same time.
    You call SD_mount from the main program and wav_play as well. You're also starting up a separate cog with play_sound which also calls sd_mount and wav_play. You can't do that. You can use locks (semaphores) to prevent both cogs from accessing sd_mount and wav_play at the same time.
    In bt_control, you're using global variable c. As long as you don't use c from another cog, you should be ok. It's better to either use local variables or make up a unique name like bt_control_c that's harder to accidentally use from more than one cog.
  • ElectrodudeElectrodude Posts: 1,685
    I only found the SD card being used in one place. However, you're definitely running out of cogs.
    Here's how your using your cogs:
    cog 0: main
    cog 1: fdserial
    cog 2: play_sound
    cog 3: turn_table
    cog 4: bt_control
    cog 5: sd driver
    cog 6: wav_play streamer
    cog 7: wav_play audio output
    nonexistent cog 8: servos which don't run because there are no more cogs for it
    EDIT: wav_play does sd_mount, but sd_mount is probably smart enough not to have two SD drivers, so this probably doesn't matter.
    Stopping any other cog will let the servos get a cog, which is why the servos only work if you comment out the SD or bluetooth cogs starts.
    Also, you should probably get rid of the curly braces on this line:
    const char techloop[] = {"crazy.wav"};
    The prototypes don't agree. You're putting an array of arrays of chars (an array of strings) into an array of chars (a string). I'm surprised that line compiles.
    EDIT: The prototypes do agree. It's an array of arrays, not an array of pointers to arrays. It will still be less confusing if you get rid of the curly braces.
