Problem with 29124 altimeter module
Hi all
I am starting the module with the following code:
the temperature reading appears to be close but I am getting a barometer reading of 38.71 inches of hg.
I just recently downloaded the altimeter object from obex. the chip itself is the MS5607.
any ideas?
Jim
bar.start(bar#MOBO_B, bar#BACKGROUND) 'pins connected to 4,5 bar.set_altitude(bar.m_from_ft(181700)) 'local altitude is 1817 feetwhere bar represents the obj bar : "29124_altimeter"
any ideas?
Jim
http://learn.parallax.com/KickStart/29124
Or this code?
http://www.parallax.com/downloads/altimeter-driver-and-demo-spin-source-code
Thanks for reply. I went back to obex and down loaded latest version, I got results that worked!
Jim
