Windows 7 Update won't run - Error 80246002
I tried to manually check for Windows 7 Updates this morning and got this error code: 80246002
I did some research and apparently a MS update is to blame. Over several hours I found several MS community posts and "fixes" but only ended up getting a different error: 80072EE2.
I finally did a restore from late July (using the Windows 7 Backup) and finally was able to get the Update working again.
If you are experiencing this problem, here are a couple of links that might be helpful (or maybe not)...
http://support.microsoft.com/kb/2982791 (see known issues)
http://support.microsoft.com/kb/2993651 (I believe this was issued to replace the one above)
MS Community discussions
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_update/win-7-windows-update-80246002-unable-to-run/2903e560-0c04-4fb6-a03d-6b0b76f2cf40?page=1&tm=1409272162558
DNS server issue??
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_update/windows-update-error-code-80246002-on-every/769867b7-8c94-489b-b353-4cdf79077ea7
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_update/update-error-80246002/7c4077bf-b6d8-4e2d-993a-276d9a5083a2
DNS server issue??
- Google's DNS serverschange the DNS servers to 8.8.8.8 & 8.8.4.4 and it fixed the issue
Microsoft reissues flawed Windows security update with new flaws
http://www.zdnet.com/microsoft-reissues-flawed-windows-security-update-7000033049/
I also compared the "Update History" list with the "Installed Updates" list.
It turns out that they don't always agree and can't be synchronized. In my case, some of the updates in question show up in the history but not installed.
Of course I did restore from a month ago but I don't think that explains all of the differences...
Microsoft screwed up this time.
When the Update fails, it gets nasty.
You can manually download updates from the Catalog here: http://catalog.update.microsoft.com/v7/site/home.aspx - Just enter the KB????? number and make sure you get the right version for your operating system.
Another article:
Microsoft republishes pulled Windows update, but still recommends a registry hack
http://www.pcworld.com/article/2599591/microsoft-republishes-pulled-windows-update-but-still-recommends-a-registry-hack.html
A comment from the article - wish I had found this earlier!
Also: http://www.pcworld.com/article/2465631/microsoft-pulls-august-windows-update-after-crashes.html
Ray
They pulled the "bad" update(s) and reissued one as KB2993651. Timing might come into play. It doesn't sound like the exact cause is clear either...
One comment indicated it only affected 64-bit systems but who knows?!?
With regard to Windows Update failing, another comment indicated that MS servers changed it that DNS servers did reflect the change
It survived without issue and is running fine....well, it's running like Windows, anyway.
I have Update set to "Check for updates but let me chose whether to download and install them". I've never had it attempt to update on it's own.
New article:
What went wrong with Microsoft's August updates?
http://www.zdnet.com/what-went-wrong-with-microsofts-august-updates-7000033089/
Sounds like your firewall should at least block any connections to MS update sites:)
Something like this is relatively rare but MS needs to do a better job of informing the public.
It would be interesting to know how many computers were affected.
Same with the JP Morgan Bank hack: http://finance.yahoo.com/news/jpmorgan-hack-spanned-months-via-090000032.html;_ylt=AwrBEiJdggBUaE8AkkaTmYlQ
I went into the router and changed my DNS addresses from OpenDns to Google (8.8.8.8 and 8.8.4.4).
Did an ipconfig release and renew.
The Update worked OK. Seems there is some sort of DNS issue.
Or your ISP DNS servers got refreshed. Nah, probably magic
Devine intervention. I prayed real hard that night.
http://www.pcworld.com/article/2599316/having-problems-updating-windows-7-try-changing-dns-settings.html
...Or you can actually address the root cause and install Mint 17 MATE, and get for free what you paid for, and are waiting on.
But that's just me, I'm a bit biased, and expect stuff to work in some useable fashion.
