H-bridge to power drill motor and controlled by the Prop — Parallax Forums
eagletalontimeagletalontim Posts: 1,399
edited 2014-08-26 05:52 in Propeller 1
And yet another project! The last was a bust, but this one I think I can fully accomplish with very little help :) This project is for a solar tracker to move my solar panels for optimum performance.
Since I have limited knowledge of the mathematical portion of electronics, I need some assistance with an H-Bridge to control a drill motor. This motor will turn on for a maximum of 1 to 2 seconds at a time in one direction, and the same for reverse direction, and will not turn back on for several minutes. If I could find a servo that was strong enough and was a full rotation, I would use it instead as it requires less amperage.
The design of the mechanical parts I am picturing as a frame that holds each panel that will eventually have an "X" and "Y" axis. For now, I plan to just go with one axis and add the other later. The panels will be connected to an all thread rod at the bottom of the frame. A motor will turn the all thread and adjust all the panels at the same time to face one direction. I have no idea how much torque it will take to move these panels and I am sure a hacked drill can handle it.
I have already built an H-Bridge with tip120's and tip125's but the start up current needed for the motor is just too much and any drag on the motor causes the transistors to heat up extremely fast. The drill motor just free spinning makes the transistors a little warm to the touch, but not bad. Using my meter in Amp mode, the free spinning amperage is around 2 amps and under a heavy load is > 10A @ 12V. Should I look for a different motor / gear box or use Mosfets or relays instead (which would make the circuit have a possibility of failing due to mechanical contacts)?
Edit : I just found this motor, but it does not list the load current :(http://www.allelectronics.com/make-a-store/item/dcm-450/rt-angle-gear-head-motor-w/tachometer/1.html
    edited 2014-08-24 19:14
    Here's a quick tip, don't use the TIPxxx darlingtons for heavy loads, though they are rated for the current and a lot of online circuits seem to use them they will always have a very high Vce(sat) of at least 1.2 to 1.8V drop at 2A and over 3V at 10A. Do your maths and you will know that even the running current means the transistor will have to dissipate over 3W running and more than 30W under load. Even 3W needs a good heatsink already. So those online circuits don't show the huge heatsink. Just use MOSFETs and very many different types have been mentioned in these forums suitable for direct drive. Did you have a particular H-bridge circuit you are using? I published a circuit years ago that was very easy to drive form the Propeller in that it followed the I/O pin and would disconnect the driver if the I/O pin floated. The MOSFETs I used were actually dual N+P in a small package, drive them right and you don't need anything big and fancy.
  • eagletalontimeagletalontim Posts: 1,399
    edited 2014-08-24 19:43
    I just bought the above motor in hopes it will work for what I am doing. I will have to see what the load current is so I can properly build my circuit to handle this.
    I have never used a half bridge but I have heard of them. The only time I used an H bridge was on an old project that switched on the water to mist my outside AC unit when it kicked on. The water valve was a small DC motor that just needed to be pulsed in one direction or the other one time to turn the water on or off. It was a small DC motor and the H Bridge was well able to handle it.
    I do have some IRF510 mosfets laying around but they are only 3A. I do have some of these as well, but they are P-Channel : http://www.digikey.com/product-detail/en/DMP3010LK3-13/DMP3010LK3-13DICT-ND/3076574 I don't think I have all the right parts to build a complete unit, so it looks like I may have to order parts :(
    As stated in the first post, I really suck when it comes to the math part of electronics. Most of the time it is a hit or miss if I use the right resistor values. I am learning though!
    edited 2014-08-24 20:12
    Maths? What maths? We are only talking simple functions such as R = V/I therefore V = R*I and I = V/R etc The one applicable to your circuit is W=V*I so knowing V & I you know it's too hot. There is no need to hit and miss with anything so basic. You have an LED which drops 1.8V at 10ma and with a 5V supply that means the resistor must drop 3.2V at 10ma, therefore R = 3.2V/10ma = 320R or 330R to round it.
    The IRF3708s have been mentioned in this forum but you also need to find a suitable more or less matching P channel. Forget Vgs(th) in the datasheet, this can be misleading, always head straight for the graphs and look at Rds(on) at Vgs at an elevated temperature and actual load current. Don't forget stall current too, but you can reduce this by sensing the voltage or current and cutting down on PWM.
    edited 2014-08-24 20:37
    I don't plan on running any PWM with this circuit as it should just turn the motor on briefly and check if the photo sensor is getting a better reading than before. I did just find some IRF1010n MOSFETs that came out of a wheel chair controller. Somehow they used them to control the motors in forward and reverse using all n channel MOSFETs. So far, I have 2 good ones. Trying to get the rest now. There were 4 per motor.
  • ErNaErNa Posts: 1,849
    edited 2014-08-25 00:04
    why you don't take a wiper motor from an old car, or the window pane actuator`?
    edited 2014-08-25 04:18
    I have several wiper motor assemblies but they all draw lots of power. Worse than the drill motor.
  • Mark_TMark_T Posts: 1,981
    edited 2014-08-25 10:42
    Use 4 n-channel MOSFETs (non-logic-level) and two high-low MOSFET drivers (or a single H-bridge driver like the HIP4081A),
    you need 12V for the drivers, the inputs are 3 or 5V logic compatible, and dead-time handling and shoot-through prevention
    can all be handled with the drivers (they vary in their support). The motor supply can be any voltage independent of the
    driver supply BTW, 0.1V to 600V (with the right drivers)
    You really need shoot-through prevention in hardware for an easy life, and for 10A handling go for 10 milliohm or less
    MOSFETs
    Read the datasheet of some of these driver chips like the HIP4081A, IRS2004, FAN7380...
  • LA6WNALA6WNA Posts: 138
    edited 2014-08-25 13:17
    Hi.
    Here is the circuit I am using for controlling the valve at my hydro power station, and that`s a windshield wiper motor.
    It uses 2N3055 and MJ2955 transistors. (complementary pair) Can handle up to 15A.
    Controls the motor connected to J601, via signal from Prop-pins at J602. One pin for each direction.
    The "flyback" diodes over the transistors, is 1N5408. Without them you`ll burn the transistors momentary. (I`ve tried...:lol:)
    J603 and J604 are for control LED`s to see if there is a control signal present.
    Hope it could be a tip. Works fine for me.
    God luck with your interesting project.
    edited 2014-08-25 15:53
    LA6WNA wrote: »
    Hi.
    You Norwegians are mad! Looks like a circuit from the 70's when the 3055 and it's buddy were power kings.
    With this circuit you could easily produce magic smoke by putting a high on both inputs! Also if there is motor stall there is nothing to prevent excess current through the small drive transistors as the emitters of the power stage would effectively be connected to ground/supply. A valve is somewhat different though and doesn't stall :) Although it has worked for you I think that in the past few decades much better solutions have become available that are far more compact and robust.
    edited 2014-08-25 16:46
    But its simply a darlington circuit in disguise, the output devices should be common-emitter, not emitter-followers.
    3055's and 2955's had their day, its a no-brainer to use MOSFETs for an H-bridge.
    For instance I've got a 3-phase MOSFET bridge I've designed that handles upto 5A and 100V without
    any heatsinking, and its surface mount taking a couple of sq in of PCB. Add heatsinks and it'll do
    10A at a few watts dissipation. Using 3 2n3055's and 3 2n2955's plus driver transistors would take
    up lots of space and dissipate more heat in the driver transistors than my entire bridge!
    edited 2014-08-25 19:09
    Thank you everyone for the replies! I have gotten a motor properly working in both directions and actually don't need a heatsink since it is only drawing 1A (1.5A Max). I really like the HIP4081A and may have to order a few of those for playing with.
    Since the circuit I am using can fail if both inputs are active, I have added a 2 second delay in my code that turns both pins off before it is allowed to turn on another one. This is a peace of mind for me, but there is always a chance it can still fail. I will be adding a fuse to the H-Bridge to prevent damage in case of a short.
    For a future build, I will more than likely be going with a 4 channel mosfet h-bridge driver like the HIP4081A. Thanks again guys for the great information. I feel like I am starting to understand the Mosfet world a little better!
  • edited 2014-08-25 23:18
    I always thought that the earth rotated at a constant rate and was surprised to learn that the earth's rotation isn't constant throughout the year because the earth's orbit isn't circular. Some bright spark sat down and wrote a mathematical formula and called it 'the equation of time'. Google "equation of time" and read up a bit. There is an object in the OBEX that calculates the position of the sun for a given location / date / time but I haven't tried it.
    Using predictive method will work better on cloudy days when optical trackers start becoming inaccurate. There is benefit to having the panels pointed directly at the sun even on cloudy days.
    Sandy
    I did see the tracker in the Obex and was thinking of trying it out. I am still trying to come up with the metal to build the stand. I am worried about wind in my area causing problems to a cheaply made solar panel mount....especially with the panels sitting out like a kite :p
