USB Rechargeable soldering iron?
Found this gizmo on Kickstarter...
https://www.kickstarter.com/projects/249225636/solderdoodle-pro-700of-usb-rechargeable-soldering
Not certain how good it is, but if it works...
It is all about Watts, watts, watts. At 5VDC and 500ma (USB nominal output), you can only realize 2.5 watts. Are 2.5 watt soldering irons really all that useful?
I do admit, it may actually be a 20-40 watt rechargeable with the advantage of being cordless. But that is about the only advantage.
I also used to have a gas-powered iron, actually I had two - I still have one of them somewhere. A gas-powered iron was very useful back when I was on the road, setting up and fixing equipment here and there, with no need to find somewhere to connect the iron (and as I was moving between countries, finding the right socket or even voltage).
I don't know or remember the cost - I got them through work a very long time ago. They probably weren't in the expensive price range as those Weller Pyropen irons though. Mine could be refilled with ordinary lighter gas, available everywhere (back then at least. Are people still using refillable lighters? I wouldn't know.) The problem (and the reason I don't use the one I still have anymore) was that after some years of use they started to leak gas and would always be empty when I wanted to use one. But until then I used them extensively.
-Tor
Awesome, lukewarm coffee and dead laptop batteries never get old.
I use this one - http://www.radioshack.com/product/index.jsp?productId=2062753
Never had a problem with leaking gas, doubles as a torch and maintains a constant temp. Has a flint style ignition, but I've had it for almost 10 years and still going strong.
Ten years ago, the Shack was solvent and they probably still had Battery of the Month cards!
Do the maths, it's going take tens of hours to charge a battery enough to power a soldering iron for use for any reasonable about of time.
You could probably charge a Tesla via USB given long enough but who would want to?
If you want a portable soldering iron for use in places where electric power is a problem get a gas powered iron: http://www.antex.co.uk/soldering/gas-powered-irons/ from 20 Euro and up.
How many Watts are needed for a Soldering iron?
That depends on what you want to solder, right?
This one is for AWG24 and smaller.
But when you start using a USB port to power all and everything when there is a perfectly good mains outlet nearby, it all begins to seem a bit mental to me.
I can't help but wonder when engineers crossed the Rubicon and decided that the USB was a utility power outlet.
In my youth, I thought electronics was all about Ohm's Law, and I ignored Watt's. How silly of me. There is real power in understanding power and how to use a tiny bit of it to control a lot.
Seriously??? People won't know what to use this on unless you tell them "Arduino Type Projects" - I really don't want to put a 700 degree pointy tool in those people's hands!!
Does this mean that electronics is not a hobby any more unless it is an "Arduino Type Project"?
I'm starting to think you could fund anything on KickStarter if you mention Arduino and USB.
And USB power banks are also getting ubiquous these days.
(I have one that doubles as a flashlight that I bring on hikes. It even came with a 5W solar panel that happens to have a USB output)
I've wanted one of the gas-powered soldering irons, but frankly, i'm a bit worried about leakage.
They may not be allowed in some locations. (Not an issue for me these days. And I never did any soldering work when visiting that kind of locations when I served in the RNoAF. but still... )
We'll see if it's any good or not. If not, it's not that big a loss.
(It's fully financed by now. I guess everyone else here can sit back and wait for me to get hold of one for testing before buying one)
Arduino...
Frankly, this is beginning to annoy me, too.
Also, the way that searching doesn't work on Kickstarter, the best way of finding interesting stuff is to go to Clicktraq.com and searching for Arduino...
My deesktop computer all ready has a snazzy retractable 'coffee cup tray', it pops out at the push of a button. It's made by a company called 'DVD'
So what actually is the self discharge of a Tesla battery pack? Maybe we can parallel up some USB's like my old USB hard drive did.
Yes, the power required depends on what you want to do. I'm guessing a USB powered soldering iron is basically useless for anything normal people want to do. Or really annoying with the constant demand for long recharging periods from USB.
All batteries self-discharge. How fast depends on the chemistry.
Multiply with the number of cells in a aTesla battery pack, and it probably amounts to something.
It's quite possible that the soldering iron is useless...
It's still a cool gadget...
Here's a video of it in operation:
https://www.youtube.com/watch?v=kCZ9JCNU464&feature=youtu.be
It's a cool gadget for sure. Probably even useful in situations where you might otherwise be using a gas iron.
I can't see myself wanting to use it much:
The handle looks too "fat".
Having to hold that button all the time might get annoying.
Having to wait 30 seconds to get up to temperature might be a drag when hacking around on a prototype and only soldering intermittently.
In the above scenario most of the battery charge will be used just getting the thing up to temperature so you might not get many joints out of it.
What would make it really cool would be to have temperature control built in. Then instead of the temperature ramping from 880 degrees down to useless it would stay at a constant 700 for as long as possible and allow longer working on the charge available.
If you are in for one we look forward to hearing how you get on with it.
Weller makes (rather made) the WSM1C. It addresses all your concerns and is a pleasure to use. The price is totally outrageous, however: http://www.all-spec.com/products/WSM1C.html?gclid=CIuzq9eurcACFVQV7Aodmw0A_A
They discontinued this in the US market but i believe make a nearly identical version for the European market. If you can find one of these on a closeout sale I highly recommend it. Aside from being portable (powered by 3 internal 18650 cells) , it's by far the best soldering iron I've ever used -- incredibly comfortable to hold (I have small hands), nearly instant heatup (a few seconds) and extremely precise control.
I quite like the look of the battery powered Hakko for those remote, emergency soldering jobs: http://www.tequipment.net/HakkoFX901.html It's cheap and we trust in Hakko.
I can feel a project coming on. A LiPo powered soldering station in the style of the Weller. Using a 24v iron form Antex: http://www.antex.co.uk/soldering/soldering-stations/tc50/
It's okay, but does take a while to heat up and the tip is pretty large. I've tried a few of these types of battery powered irons and the 4-AA powered ones are the best, but all about equal.
I like it!
For 'comparison' of course...
Anyone got a link to a 4x AA model that's not too expensive?
Weller makes a bunch of these that are apparently nearly identical:
http://www.newark.com/weller/bp860mp/battery-powered-soldering-iron/dp/31M1193?mckv=sda3NnMj5|pcrid|41566056141|plid|&CMP=KNC-GPLA
http://www.mcmelectronics.com/product/96-2275
http://www.mcmelectronics.com/product/96-3495
http://www.mcmelectronics.com/product/96-3500
