14 bit 2s complement
CannibalRobotics
On the Freescale Xtrinsic FXOS8700CQ the accelerometer data is presented in the form of a 14 bit 2s complement. Following the "invert and + 1" technique they recommend I can not get SPIN to clear off the bits above the 13th on a negitive number. My feeling is that it's something obvious Im just not picking up.
Some fresh eyes on this would be great.
For Negitive numbers I get:
Why is the routine returning all 1's above the 13th bit after I've ANDed them all off with
Thanks in advance.
Pri FixA(d)| bits '' Returns Signed Long of G force on axis for data d
bits := d & $0000_3FFF ' Reduce to 14 bits to work with
if bits > $0000_1FFF ' Is sign bit (14th) set ?
bits &= $0000_0000_1FFF ' Clear sign off base number
bits :=(! bits) + 1 ' Invert the remainder and add 1
bits := bits & $0000_0000_0000_1FFF ' Clear off upper ones from ! operation
bits := -1 * bits ' Make it negitive (set sign bit)
Return bits
AxC Raw: 00000000000000000011101110111111 14 bits: 00000000000000000011111111111111 FixA out: 11111111111111111111101110111111 = -1089For Positive I get:
AxC Raw: 00000000000000000000010001110100 14 bits: 00000000000000000011111111111111 FixA out: 00000000000000000000010001110100 = 1140
bits := bits & $0000_0000_0000_1FFF ?
Thanks in advance.
The << gets the sign bit into bit 31, and the ~> does a signed right shift back, preserving the sign bit.
Then you should end up with something ranging from 0 to 37267.
So shift left 18 bits, then right 18 bits, to get rid of 'stray' bits on the end, then add 16384 to get rid of the sign.
- edit: Just noticed Phil's response above. I'll shut up.
