Active High Button with 5V
Duane Degn
Normally when I want to use a button with a Propeller it use this sort of circuit.
I have some encoders which include a push button and when the button is pressed it shorts the button pin of the encoder to the 5V line to the encoder.
For this button, I figure I'll pull the line low and use a series resistor to protect the Prop from the 5V. But with both a pull-down resistor and a series resistor, I end up with a voltage divider. This isn't necessarily a bad thing since I'm starting with 5V.
Now I'm trying to figure out where the two resistors should be placed with respect to each other.
My first choice is to use this circuit.
I'll probably just use 10k ohm resistors for both R1 and R2 since this should give 2.5V at the Prop and register as logic high.
As I was thinking about this I wondered if this sort of circuit would change much.
The version B circuit pulls the line low through both R1 and R2 so I assume this would increase the recovery time between button presses (though I doubt this will be an issue).
My (frequently wrong) gut tells me version A is the better choice but is there a rule to this sort of thing?
Will the voltage at the Prop pin be closer to 5V with version B than with version A? It seems like voltage at the Prop pin will probably be 3.3V plus the clamping diode voltage drop.
I'm pretty sure either version would work but is one version more "correct"?
Am I correct in thinking as long as R1 is at least 3k ohm and R2 has the same or greater resistance as R1, then I'm okay with all sorts of resistor combinations?
I originally planned to use version A but version B would be a bit easier to solder with the way things are physically laid out. There's a ground connection on the encoder/button so I'm tempted to just add the pull-down resistor on the button itself and then add a series resistor between the button and the Propeller.
I'm curious if there's a reason to use one circuit rather than the other?
I'll hold off on the soldering until I get some feedback on this issue.
Push Button Schematic 3.3V Active Low
3.3V
 button
 10KΩ ─┻─
Prop Pin ─────┻────────┘ └─┐
Push Button Schematic 5V Active High
Version A
5V
button 
R1 ─┻─ │
Prop Pin ─────┳────────┘ └────┘
R2 
Version B
5V
button 
R1 ─┻─ │
Prop Pin ─────┳─────┘ └─────┘
 R2
I would definetly used version A to get sure about that the prop-pin mever got more than 3,3v. As you say, this is a voltage divider. If the R1 and R2 is equal, you`ll get about 2,5v into the prop pin.
In version B, you will only get a current flow through R2. This because the high Z input of the pin. Said in another way; R1 will not cause any voltage drop because there`s no current flowing through it. That means the voltage is nearly 5v at the both side of it.
So, Go for version A is my suggestion, even when the layout does it more tricky. Think thas the safest way..
It uses no power when the switch is open (same for both)
A will use less power than B (~0.5mA with 3K3)
The internal protection diodes are not sinking current when switch activated as in circuit B.
Use a ratio of 1:2 for R1:R2 as this will give 3v3 when switch is active eg 5K and 10K (4K7 or 4K99 are standard values)
Explains it all
As the frida's link explains, as long as the current across the clamping diodes is less than 500uA, the Prop should be safe.
Circuit B was a lot easier to solder with my no PCB free form circuit. I'm using a cardboard box as an enclosure so this really isn't a professional installation. In this case circuit B made more sense, since the version B design provides less opportunity for my tangle of wires to short circuit.
Thanks for the input everyone.
So circuit B is better (coz it's wetter) where R2 = 4K7 and R1 = 1M (or 100K).
@LA6WNA - If you run 5V through a resistor into an LED does that mean that you measure 5V across the LED? Of course not, neither does the Prop see 5V when current limited.
