Propeller backpack--noise in video overlay
Hello all,
I am currently using a Propeller Backpack to and the tv_overlay2 module to embed data from sensors into a video feed during a neuroscience experinment. Basically, I have a rat cage with a camera mounted in it, which transmits NTSC video through the Backpack to into a DVR. The propeller is used to overlay a time stamp and also a representation of all the states of the sensors in the cage. The idea is that specific behavioral events can then be decoded from the video.
Unfortunately, the Backpack seems to be introducing a lot of grainy noise into the signal. The noise seems to be intrinsic to the chip (I've tried using a better power supply and putting it in a shielded box) and is messing up the ability of the program to decode video. I'm also pretty sure that it's not a sync extraction issue (which was happening, but was fixed by adding an appropriate load)
Have any of you had succsess in reducing the amount of noise introduced by this board? I'd love to hear any suggestions you might have.
welcome to the forum.
Phil is the expert for the BackPack. He build this wonderful board. I struggled also with it and found that using a slightly better camera solved all problems I had.
anyways - where is the rat?
Hiding?
And there's no rat because I went down there between training sessions--anytime there are animals in the room we have to wear gloves and that's not ideal for futzing about with electronics.
