BeMicro CV shield
Well,
we need a sheild, we need a shield for the BeMicro CV
. EEPROM, VGA connector and SRAM and/or SDRAM. I want it sort of soon
... PS/2 connector too
do you have a few ideas ?, size will be 10x5 cm.
because this will also be used for P2, I would include SO8 lands (maybe 4?) for QuadSPI SRAM and QuadSPI FLASH
I guess there will be room for both SDRAM and SRAM ?
What about HDMI connector ?
Parallax are doing a PCB, maybe their PCB will allow any Cyclone V to be fitted, to cover a broader range ?
Yes, but I prefer USB connectors as all PS/2 compatible keyboards these days are normally USB connector with a bulky gender bender that's not required if we wire the USB socket for PS/2. To minimize the number of I/O required for RAM we should stick to SDRAM plus they come in high capacities and are very cheap.
SDRAM
PS/2 (USB)
SD/microSD
VGA
Audio
EEPROM
Wiznet W5500
USB FT232
Is there any schematic where to connect usb socket to PS2? (or will I have to find a this ps2-usb dongle and check it experimentally?)
This is what I do:
