Another Backyard Shop Tip: Drilling Fairly Accurate Shaft Centers With A Drill Press — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2014-08-14 04:01 in General Discussion
I am currently in the process of drilling out several shaft centers and I thought I would share my method of aligning shaft centers on the drill press. Over the years, I have attempted to drill many shaft centers, which almost always ended up in disappointment. However, during the course of the last year, I have developed a new method of centering my shafts on the drill press.
Please keep in mind, I am only advising this for imperial units of measure and for shafts that "mic" out to the nearest 1/16", such as 1/4", 5/16", 3/8", 7/16", and 1/2" (+- 0.000).
First off, you will need a small scrap piece of shaft, which is equal in diameter to the shaft you intend to drill. Secondly, you will need a small piece (approximately 2" long, however longer pieces will increase the accuracy) of seamless brass tubing 1/32" larger in diameter to the shaft you intend to drill and having a 0.014" wall thickness. In the United States, this tubing can be found at many hardware and hobby stores. Many stores stock a K&S Engineering metal rack. For an example of the tubing found in such a rack, visit this link: http://www.ksmetals.com/26.html.
Anyhow, chuck up the scrap shafting and slide the brass sleeve over the scrap. With the workpiece positioned under the scrap and in close proximity to the scrap, adjust the workpiece until the brass sleeve easily slides from the scrap to the work piece. When this occurs, the drill press should be centered with the shaft to approximately 0.00325", but probably closer.
Remove the scrap and brass, then drill your starter hole (I use a tile cutter bit for this purpose). Finish the shaft, by drilling with the intended drill bit.
It works good enough for my needs.
    edited 2014-08-13 17:57
    Sure, that's a good backyard shop tip! I like it and I think it's probably close enough to be entirely useful for most projects I do.
    Way to go, Bruce.
    edited 2014-08-13 18:04
    Ona few occasions when I was building rough breadboards up to the very last second before a presentation, I would drill a hole though several carefully lined-up parts, then just leave the drill bit in place as my axle. Always worked fine.
    Not pretty and danged expensive, but quick and dirty and you know it's a perfect fit. :)
  • idbruceidbruce Posts: 6,197
    edited 2014-08-13 19:52
    Glad you like it Ken.
    However be forewarned, depending upon the fixturing and drill press alignment, it can be a bit tedious to get that brass to slide smoothly from the scrap to the shaft, but when it does, you should be in the ballpark.
    edited 2014-08-13 21:05
    Yeah, and it depends on having a pretty good chuck without a lot of runout, too. But it's a lot faster and more convenient than putting it in a milling machine and using an edge finder twice.
    I always like to choose the right process for the job. One of my favorite tools is my Servo drill press - a simple, precision drill with an 1/8" Albrecht keyless chuck. I've been really fortunate to collect some nice tools for my Parallax work. My most favorite tool is my Wilton band saw.
    edited 2014-08-13 22:02
    That's pretty dang clever, Bruce!
    Definitely. For those contemplating a drill press purchase, it's perfectly fine to buy a cheap one from Harbor Frieght. Save your money for a good chuck. When the Harbor Freeight unit arrives, chuck the chuck and install a precision Albrect chuck in its place. It will probably cost more than the drill press. You won't be disappointed.
    edited 2014-08-13 22:10
    Ken Gracey wrote: »
    I've said it before and I'll say it again. My favorite tool in the metal shop is our Rotex punch. Punches a variety of hole sizes (even a square or two) thru sheet metal, sheet plastic. etc. Rapidly makes holes or wheels/cams, rings, etc. Leaves a center dimple in the circle cutout so you can easily line up center if you want to punch a smaller center hole.
    http://www.rotexpunch.com/2652.html
    Thanks Phil
    I just got tired of drilling off center, then one day, I pulled up a stool in front of the press and thought about a solution.
    chuck the chuck
    Say it isn't so :)
    I save all my chucks for fixturing, threading with small taps, holding round pieces for solder, heating, welding, etc.... Don't throw them away, just put them in a drawer with other useful garbage :)
