AHDL to Verilog
Chip, are the files top.tdf and tim.tdf written in AHDL? or are they Altera specific?
I want to port the design to a xilinx XC3S1000 (s3board) ... and to Lattice in the future.
Please, if possible, can you convert them to verilog too?
(What is divide[].d ? the 16 / 5 clock signal? I don't understand this part.)
In Verilog it should be something like this:
reg[12:0] divide
always @(posedge clk) divide<=divide+ (the rest of this thing translated to verilog)
This is 13-bit counter which generates a clock for the Propeller according to its config. If it is rcslow, lowest bit is incremented every 160 MHz input clock tick. RCFAST or PLLx1 increments 8th bit etc. Then 11th bit is used as fake cog PLL clock and 12th bit is used as a cog clock.
So it can be converted to verilog, right?
I mean, this is not a altera/quartus specific file? (like top.qsf who contains pin assignments and compiler instructions)
It could be possible/worthwhile to add comments to the code? Something like this:
// Datasheet 1.4, page 14
divide[].d = divide[].q + (
cfgx[].q == b"11xx111" # res, // ( XINPUT + PLL16X ) or res,
cfgx[].q == b"11xx110" & !res, // (XINPUT + PLL8X ) and !res,
cfgx[].q == b"11xx101" & !res, // (XINPUT + PLL4X ) and !res,
(cfgx[].q == b"11xx100" # cfgx[].q == b"xxxx000") & !res, // ( (XINPUT + PLL2X) or RCFAST ) and !res ),
(cfgx[].q == b"11xx011" # cfgx[].q == b"x1xx010") & !res, // ( (XINPUT + PLL1X) or XTAL1 and !res ),
b"0", // ?
b"0", // ?
b"0", // ?
b"0", // ?
b"0", // ?
b"0", // ?
b"0", // ?
cfgx[].q == b"xxxx001" & !res // RCSLOW and !res
Is this correct?
Only one if can be true here so it always will add a number with only one "1" in it. The higher is this "1", the higher frequency will be outputted from divide[11] and divide[12]
Edit: this was generated by Quartus for my PLL. Removed a bunch of comments at the end. I think PLLs for Xilinx have to be done in its environment.
// megafunction wizard: %ALTPLL% // GENERATION: STANDARD // VERSION: WM1.0 // MODULE: altpll // ============================================================ // File Name: pll2.v // Megafunction Name(s): // altpll // // Simulation Library Files(s): // altera_mf // ============================================================ // ************************************************************ // THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE! // // 14.0.0 Build 200 06/17/2014 SJ Web Edition // ************************************************************ //Copyright (C) 1991-2014 Altera Corporation. All rights reserved. //Your use of Altera Corporation's design tools, logic functions //and other software and tools, and its AMPP partner logic //functions, and any output files from any of the foregoing //(including device programming or simulation files), and any //associated documentation or information are expressly subject //to the terms and conditions of the Altera Program License //Subscription Agreement, the Altera Quartus II License Agreement, //the Altera MegaCore Function License Agreement, or other //applicable license agreement, including, without limitation, //that your use is for the sole purpose of programming logic //devices manufactured by Altera and sold by Altera or its //authorized distributors. Please refer to the applicable //agreement for further details. // synopsys translate_off `timescale 1 ps / 1 ps // synopsys translate_on module pll2 ( inclk0, c0); input inclk0; output c0; wire [0:0] sub_wire2 = 1'h0; wire [4:0] sub_wire3; wire sub_wire0 = inclk0; wire [1:0] sub_wire1 = {sub_wire2, sub_wire0}; wire [0:0] sub_wire4 = sub_wire3[0:0]; wire c0 = sub_wire4; altpll altpll_component ( .inclk (sub_wire1), .clk (sub_wire3), .activeclock (), .areset (1'b0), .clkbad (), .clkena ({6{1'b1}}), .clkloss (), .clkswitch (1'b0), .configupdate (1'b0), .enable0 (), .enable1 (), .extclk (), .extclkena ({4{1'b1}}), .fbin (1'b1), .fbmimicbidir (), .fbout (), .fref (), .icdrclk (), .locked (), .pfdena (1'b1), .phasecounterselect ({4{1'b1}}), .phasedone (), .phasestep (1'b1), .phaseupdown (1'b1), .pllena (1'b1), .scanaclr (1'b0), .scanclk (1'b0), .scanclkena (1'b1), .scandata (1'b0), .scandataout (), .scandone (), .scanread (1'b0), .scanwrite (1'b0), .sclkout0 (), .sclkout1 (), .vcooverrange (), .vcounderrange ()); defparam altpll_component.bandwidth_type = "AUTO", altpll_component.clk0_divide_by = 5, altpll_component.clk0_duty_cycle = 50, altpll_component.clk0_multiply_by = 14, altpll_component.clk0_phase_shift = "0", altpll_component.compensate_clock = "CLK0", altpll_component.inclk0_input_frequency = 20000, altpll_component.intended_device_family = "Cyclone IV E", altpll_component.lpm_hint = "CBX_MODULE_PREFIX=pll2", altpll_component.lpm_type = "altpll", altpll_component.operation_mode = "NORMAL", altpll_component.pll_type = "AUTO", altpll_component.port_activeclock = "PORT_UNUSED", altpll_component.port_areset = "PORT_UNUSED", altpll_component.port_clkbad0 = "PORT_UNUSED", altpll_component.port_clkbad1 = "PORT_UNUSED", altpll_component.port_clkloss = "PORT_UNUSED", altpll_component.port_clkswitch = "PORT_UNUSED", altpll_component.port_configupdate = "PORT_UNUSED", altpll_component.port_fbin = "PORT_UNUSED", altpll_component.port_inclk0 = "PORT_USED", altpll_component.port_inclk1 = "PORT_UNUSED", altpll_component.port_locked = "PORT_UNUSED", altpll_component.port_pfdena = "PORT_UNUSED", altpll_component.port_phasecounterselect = "PORT_UNUSED", altpll_component.port_phasedone = "PORT_UNUSED", altpll_component.port_phasestep = "PORT_UNUSED", altpll_component.port_phaseupdown = "PORT_UNUSED", altpll_component.port_pllena = "PORT_UNUSED", altpll_component.port_scanaclr = "PORT_UNUSED", altpll_component.port_scanclk = "PORT_UNUSED", altpll_component.port_scanclkena = "PORT_UNUSED", altpll_component.port_scandata = "PORT_UNUSED", altpll_component.port_scandataout = "PORT_UNUSED", altpll_component.port_scandone = "PORT_UNUSED", altpll_component.port_scanread = "PORT_UNUSED", altpll_component.port_scanwrite = "PORT_UNUSED", altpll_component.port_clk0 = "PORT_USED", altpll_component.port_clk1 = "PORT_UNUSED", altpll_component.port_clk2 = "PORT_UNUSED", altpll_component.port_clk3 = "PORT_UNUSED", altpll_component.port_clk4 = "PORT_UNUSED", altpll_component.port_clk5 = "PORT_UNUSED", altpll_component.port_clkena0 = "PORT_UNUSED", altpll_component.port_clkena1 = "PORT_UNUSED", altpll_component.port_clkena2 = "PORT_UNUSED", altpll_component.port_clkena3 = "PORT_UNUSED", altpll_component.port_clkena4 = "PORT_UNUSED", altpll_component.port_clkena5 = "PORT_UNUSED", altpll_component.port_extclk0 = "PORT_UNUSED", altpll_component.port_extclk1 = "PORT_UNUSED", altpll_component.port_extclk2 = "PORT_UNUSED", altpll_component.port_extclk3 = "PORT_UNUSED", altpll_component.width_clock = 5; endmoduleI just looked and, yes, Altera supports $readmemh.
Then we throw out PLL and "altpll.inc" from top.tdf, rewrite both AHDL files to Verilog, and just feed clock input with external clock (the same way as XINPUT mode : DC-80 MHz )
Lattice has some small devices that even do not have a PLL. Is this is a double-edged sword for parallax business? Risk of P1 being replaced by small cplds or fpgas? or risk of links broken between Terasic and/or Altera?
You don't need a pll. You only need a clock which is 2x the Propeller clock. You have 50 MHz input clock in Altera boards, which, without PLL, gives you 25 MHz clocked Propeller. The pll is used only for making 160 MHz clock for the simulated chip.
I want now to get rid of this pll inside the Propeller and feed it from outside, which can give me an option to make a variable frequency generator switched via for example SWxx on DE2-115. This will give me oprion to have the Propeller running @ std 80 MHz or 100, or 120, or 140 MHz without reprogramming the FPGA.
You can run them both off the same clock.
The only reason the clk_pll was twice as fast as clk_cog was to reduce jitter. 4x or 8x would have been even better.
I tried this, but it needs some changes. When I run the Propeller clock and PLL clock from the same 140 MHz source, the output frequency for the video was 2x too slow and in spin code I had to set _clkfreq to 70 MHz
You'll need to go into ctr.v and alter this line:
wire [7:0] pll_taps = pll_fake[35:28];
to be like this:
wire [7:0] pll_taps = pll_fake[34:27];
There may be a problem without at least a 2x clock for the pll_fake registers, where some larger FRQ values won't work because they can't accumulate fast enough.
I will post the new ROM file(s) and the spin program that produces these shortly - unscrambled and $00 for the unused parts. Everything is here on this thread
http://forums.parallax.com/showthread.php/156866-Question-for-Chip-re-ROM-code
I will look at the link you posted in more detail once I have completed this part.
