Need help picking a new soldering iron
Hello, I have an old Ungar iron that I paid about $600 for in the mid '90s. I like the iron but it is approaching old age and I am looking to replace it now.
I'm somewhat interested in Hakko's FX-951, but I would like to see one before I commit.
Anybody here have any suggestions?
Thanks, Bryan
Thanks, Bryan
If you have time you might like to wade through an ongoing thread about soldering, soldering irons, soldering stations etc: http://forums.parallax.com/showthread.php/156620-Need-tips-on-soldering
But as we are here...WTF?! Six hundred dollars for a soldering iron?!
I do hope you mean a soldering station. Even then that is a lot of money. Are you doing this commercially or just for a hobby?
For light professional and heavy hobby use I really want a Hakko FX888D like so: http://www.adafruit.com/products/1204
Sadly it seems impossible to get the analogue version and almost impossible to get a Hakko in Europe at all.
Next up I want this an Antex 660A like so : http://www.antex.co.uk/soldering/soldering-stations/660a/ or the digital version http://www.antex.co.uk/soldering/soldering-stations/690d/
Certainly anything more than 100 dollars for a soldering station has be thinking very hard.
On the other hand, having watched a bunch of teardown videos and reviews on the utubes I'm really loath to buy any cheap station from China.
I haven't seen any that I like, but I'm big on 'feel'. I just really like the way it felt while using it, and it was nice being able to go from IC pins to copper planes with the same iron.
Get a good 24v iron like this: http://www.antex.co.uk/soldering/soldering-stations/tc50/
Then build your own controller like the one made by Vitaly K here: http://www.youtube.com/watch?v=9dbI8-c7ROE
Do watch the video, it's awe inspiring. A soldering station should not be boring.
Of course it should be managed by a Propeller:)
http://gokimco.com/hakko-fx888d-esd-safe-digital-soldering-station.html
Perhaps you could report back here on your experience with it after a bit of use.
I have a like new, never used FX888. It's the non-D model with the nice analog knob to set the temperature. I only opened the box one time to look at it. All the parts still have all the original factory clear plastic wrappings in place. Now that they are no longer made, I think I'll just leave it unused and new in the box. Maybe someday it'll be worth a fortune on eBay.
How right you are. I have been searching high and low for the old analogue HAKKO. Not one to be had anywhere. Not that it's easy to find a HAKKO in Europe at all.
Just now I thought I'd found one, from a place in the UK that has only the analogue version in it's catalogue. But no, not available any more, only the digital one. And they quoted me a hundred GBP for that which is 168 dollars! Grrr...
So now I don't know if I want to go with that HAKKO or the very nice looking Antex 660A analogue station which is even more expensive at 150 GBP. More grrr...
Looks like me and my old Weller will have to get along together for a bit longer.
I thought JBC and Ersa were two of the big names for soldering tools in Europe (well, and Metcal if you have the money). Have you looked at either of those? I've heard Hakko is hard to get over there, probably some kind of conspiracy.
As far as I remember....
When I used to be in environments where there was a lot of soldering going on, for production or development, it was all Weller and Antex.
One thing is for sure. For my current projects soldered up on my kitchen table or in our office I don't want any big, ugly, crude, expensive station. I can make one of those for myself if need be.
No, for that kind of money it had better look and perform like some one cares about what they design.
Funnily enough, when I'm in Japan I use an old Weller-style (well it's kinda blue at least) soldering iron without temperature control and I don't miss it. Not sure about its wattage, probably not more than 30. I rescued the old soldering iron from where it had been stored for more than ten years, removed the rust and got it working. I don't miss the temperature control at all. I simply hold the tip a moment on the wet sponge and the temperature is "just right": I momentarily move the tip near my face now and then (maybe 10 cm away) and I feel the heat somewhere between my nose and my upper lip, and I know when it's right. Been happily soldering together lots of through-hole parts with it. Presumably all those years of soldering subconsciously taught me about temperature. The only thing I miss is that because it's not a "soldering station" there's also no metal spiral holder or anything to hold the soldering iron when I'm not actively soldering, so I have to be a bit careful about where I put it when I'm busy looking for the next capacitor or IC socket.
Tor, I agree with you, I prefer Weller but I will use something else if that's all there is. Everyone has their preference but I have always seen at least 1 Weller even if it's been stuck over in a corner.
I guess you are right. I should save the space and the money for that Rigol oscilloscope I have been promising myself for ages.
Tor, You are far more "in tune" with your tools than I can ever aspire to be.
I have noticed that despite the high technology and automation available today when it comes down to serious high precision work it still requires the "feel" of a human to achieve it. I first noticed this in a factory where they were building lathes and it was down to the humans to decide if the bearings were true enough.
Now you can see it in the building of the "Worlds Most Spherical Object" : https://www.youtube.com/watch?v=ZMByI4s-D-Y Mostly ground by hand!
Oh yeah, this is soldering we are talking about. Perhaps not so critical...
I am amazed at skilled assemblers especially with SMT parts which I suck at.
It's that "make do" thing that is bugging me now. I started out playing, literally, with electronics before I was 10 years old. I have been "making do" with soldering irons since soon after that. That is more decades ago than I like to think about.
I've decided I'm done with welding through hole components too strip boards. I'm going SMT. I just discovered that soldering SMT parts is not much harder than through hole. It's so cheap and easy to get boards made now. It's time to catch up with 1980's technology at home:)
The scope is another thing. Always making do. I've had a few scopes in my time. Mostly old tube scopes rescued from the trash. I wish I still had that big old 1960's Tektronix all tube monster I salvaged in the 1980's. Mostly "making do" meant not having a scope. It's amazing how you can get buy with an LED "logic probe". Or listening to your circuit via a capacitor and head phones. Or putting a transistor radio near your creation.
Mostly I did not worry about the lack of a scope because there was always some very nice scopes in places I worked at. Since we seem to have stopped making anything in the western world that is more and more rare.
But now, I find you can buy some really amazing scope technology from a couple of hundred dollars up. I mean really, a 100MHz bandwidth and two giga samples per second for 600 euros or so. Incredible.
I'm really looking to up my whole game here. Without going totally crazy with the cash of course.
I left my smt station in Vegas so I'm in the market for a new one. Considering another X-tronic as the last one served me so well. Also looking at solderwerks and the possibility one with a built-in PCB pre-heater.
That is all :-)
So far so good.
That's a "lot of stuff" for a cheap price.
Keep us up to date on how it works.
One of my hesitations was that they'd moved the air-pump from the box to the actual hand-held nozzle. I was concerned that that was going to compromise power or something. If anything, the opposite.
The only "down" is the pre-heater is incredibly slow to get to temperature but, it's a pre-heater so it's not meant to be rapid.
In just over a week I'll have the prototypes back for the SkyDogCon 2014 badges and will be assembling a few of them for testing. I'll put together some video showing the pre-heater and hot-air in use to add to this thread.
Red
