DC22 Thoughts - Page 2 — Parallax Forums
DC22 Thoughts
2»
  • ChrisGaddChrisGadd Posts: 311
    edited 2014-08-12 04:31
    Perhaps, but the community's response to the complaint that the Prop doesn't have interrupts is to say that it has eight cogs. Split the transmit and receive functions into separate cogs and suddenly an ultra-low power receiver becomes simple. I typically only use the transmit function of fds anyhow, for debug purposes; I've very rarely done anything with the receive side of it.
  • __red____red__ Posts: 470
    edited 2014-08-12 05:45
    You could, but it would cost you a cog and how much power would you really save?
    The additional cog would take more power, the waitpne would save power. It would certainly make an interesting experiment. For single direction communication it does make sense.
    edited 2014-08-12 05:57
    Agreed, it was simply meant as an example of how cogs can be used to make up for a lack of interrupts. Even the transmit cog could be rewritten to use a waitpne instruction. The Spin handler would prep the transmit buffer and then place a low on the transmit pin, the transmit cog would see the low and assert its own low output, read the buffer, and due to the way the I/O port is constructed, be able to drive the tx pin high for the first bit even if the Spin cog is still outputting a low. Heck, if there's that much concern about cogs and power, then the transmit cog could even be shut down and only restarted when needed.
    edited 2014-08-12 08:28
    Dave Hein wrote: »
    The concerns about interrupts could be addressed if the Prop had both interrupts and multi-core. There are situations where interrupts would be really useful, even with 8 cogs. The multiple-tasks in last year's version of the P2 almost provided interrupt capability. Just a few more transistors would have made it a true interruptible processor.
    +1. There have been times when I really could have used a simple interrupt scheme such as the one suggested by Heater in post 9.
  • GenetixGenetix Posts: 1,771
    edited 2014-08-12 13:47
    Jon, you should be proud for vindicating Chip's choice of Spin on the Propeller. There should be quite a few magazine and new articles about you and Parallax so enjoy the spotlight. Ever since moving to the Propeller I always felt that Spin was an easy language to learn but you proved that point with people who have never used Parallax products before.
    Now when are we going to see some magazine articles or a new book. :P
  • JonnyMacJonnyMac Posts: 9,376
    edited 2014-08-12 14:05
    I am still actively writing for Nuts & Volts, and am in discussions about the latter.
  • Ken GraceyKen Gracey Posts: 7,415
    edited 2014-08-12 14:08
    JonnyMac wrote: »
    Call me at 4:00 pm, JonnyMac.
  • idbruceidbruce Posts: 6,197
    edited 2014-08-16 06:41
    Sounds like it would have been a lot of fun and good promotion for the Propeller.
    Kudos to all those involved with making it happen.
