PING Servo with ActivityBot
Hi All;
Not sure if this is the correct forum for this post, so apologies if it is not.
I've been experimenting with the ActivityBot & PropC and have run into a of a road block. I have a PING sensor mounted on the PING Servo and am trying move the servo in 5 degree increments from extreme right (0 degrees) through extreme left (180 degrees). Once the sweep is complete, the servo needs to move the PING sensor to 90 degrees (centre). The code below works fine I execute it in a project from main. However, when I move this code into a sub function the then the results are erratic and the servo never centres. I have added pause statements after the "servo_angle(17, 900)" statement but it does not correct the erratic behaviour.
Any Suggestions would be appreciated.
Dean
#include "simpletools.h" // Include simple tools
#include "servo.h"
#include "ping.h"
int main() // Main function
int arDist[36], PINGangle = 0, i = -1, MaxDist = 0, Heading = 0;
print("Start FindLongestRun\n");
servo_angle(17,PINGangle); // P17 servo to 0 degrees Extreme Right 0 + 3 degrees
pause(500); //wait for Chirp return
print("Ready to begin Scanning\n");
while(PINGangle <=1800)
{//Start
arDist[PINGangle/50] = ping_cm(16),PINGangle/50; // Get cm distance from Ping)))
pause(100); // wait for Chirp return
PINGangle = PINGangle + 50;
servo_angle(17,PINGangle); // move PING 5 degrees
}//End While
servo_angle(17,900);
print("Scaninng COMPLETE\n");
Dean
Have you tried putting a piezospeaker on your board, and adding a simple beep to the start of the program? It might let you know in the future if the erratic behavior you are seeing is caused by the Propeller resetting as servo movements pull the last bit of juice out of tired batteries.
Thanks for the feedback. The Piezo is a good idea. At this point I'm concentrating on core functions, but a power indicator of some sort is definitely on the top of the list for future enhancements.
