Pascal Compiler P4 — Parallax Forums
Pascal Compiler P4
PowersoftPowersoft Posts: 72
edited 2014-08-04 06:16 in Propeller 1
Hello,
On the propeller.wikispace I found something of my interest.
It discribes the P4 Pascal compiler Development Tools, see text below.
The links of the zip files are not valid any more.
How can I get these two zip files?
Thanks for any help.
Jan Kromhout
Hellevoetsluis-NL
Pascal to P4 P-Code Compiler
This is the command line compiler which takes Pascal source code and emits the P4 p-code. The compiler works under Windows XP but not under Windows 98SE.
Executable and Source download from Scott A Moore's site : here
Linker
Executable and Source are included in the AiChip_P4_XXX.zip download available from the Parallax Forum.
Bytecode Interpreter
Source code is included in the AiChip_P4_XXX.zip download available from the Parallax Forum.
  • AribaAriba Posts: 2,697
    edited 2014-08-03 10:53
    Try it here
    Andy
  • PowersoftPowersoft Posts: 72
    edited 2014-08-03 23:27
    Thanks for the response.
    I have try it, get this message when I try to download the zip file.
    Not Found
    The requested URL /forums/default.aspx was not found on this server.
    I have no problem to download the ZIP and the EXE file from post #14 in the previously linked thread.
    Perhaps somebody with edit rights for the Propeller Wiki can edit the links in the Pascal P4 article.
    Andy
