Field calibration problem
I have a propeller project nearly completed and I now have the problem of taking it out of the workshop and into the field. I need some means of reading a few sensor outputs and programming some calibration constants. No mains power is available. I guess I could invest in a tablet to do this, (assuming I could run the Prop IDE and a terminal program on it), but does anyone have any better (cheaper!) approach to this?
Thanks for any help.
I like these OLED displays from ITead Studio. They're only $5.
I used one in my aluminum wallet project.
The OLED displays need to be controlled by i2C or SPI but there are lots of displays with a serial interface. Parallax sells several LCD screens with a serial interface.
You could also use a NTSC monitor or a VGTA monitor.
This may not be the most economical in long run or even the short run for that matter, it is just a suggestion, which depends on how close the remote location is to your shop.
Scenario 1: Go to the remote location and take your initial readings, then run back to the shop and rewrite your program with the new constants. Then go back to the remote location and upload the new program with a field programmer. Such as the one suggested here: http://forums.parallax.com/showthread.php/143892-Great-Weekend-Project-For-The-Propeller-DIP-Plus-Kit Note: The schematics have not been tested on a working board, however, I have a previous field programmer that I built that works just fine.
Scenario 2: You could possibly modify the project suggested above to enable on the spot programming.
Combining your two suggestions should give me just what I want.
Thanks to you both,
Larry
ie Do you have to reprogram your prop.?
I presume you will have P30 and P31 available?
With 2 pins free, you can add a ps2 keyboard and composite video with a few resistors.
See my 1 pin tv and keyboard objects in the tools section of the obex. A small car reversing monitor is ~$25 on ebay.
The idea is you make your program capable of a programming mode to change values.
BTW, I don't have to preprogram this "calibration" access in, every aspect of the code and data are at my fingertips, it's all part of running an interactive Forth environment on the Prop itself.
