Cross compiling propeller-load, success and problems.
Heater.
I have been cross-compiling the loader from proogcc for targets such as the MIPS based router boxed running OpenWRT, the Raspberry Pi and Emscripten (I'd really like to see a Chrome App programming a Propeller!).
So far these compiles work although I have not tested the resulting loaders yet.
Here is my procedure:
There are couple of issues with this:
1) The Makefile contains "CC=gcc" which I have to remove in order to get the cross-compiler used.
2) Without some modifications the build fails with:
Of course, the ./bin/linux/bin2c has just been built for the MIPS and so does not run.
Currently I get around that by building for x86, copying bin2c to /usr/bin, and removing the $BINDIR from in front of the bin2C commands in the Makefile. Or some variant of that.
No urgency but it would be nice if this worked out of the box.
$ export PATH=$PATH:/home/heater/openwrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/bin $ OS=linux CC=mipsel-openwrt-linux-gcc make
binary obj/propeller/p2loader.bin
./bin/linux/bin2c: 1: ./bin/linux/bin2c: Syntax error: "(" unexpected
Makefile:278: recipe for target 'obj/linux/p2loader.c' failed
make: *** [obj/linux/p2loader.c] Error 2
I'm using the default branch. It already has some changes in it for using the UART's, together with a GPIO on ARM and other SoCs like the Raspi.
In the top level make file there is:
$(BUILD)/loader/loader-built: $(BUILD)/loader/loader-created @$(ECHO) Building propeller-load @$(MAKE) -C loader TARGET=$(PREFIX) BUILDROOT=$(BUILD)/loader TOOLCC=$(CROSSCC)I take that as meaning that in the loader directory I can do: However that produces a x86 loader executable not a MIPS one.In the loader Makefile we have: So I don't see how my build can ever work out of the box.
Brilliant! That is just the little make detail I needed.
$ make OS=linux TOOLCC=mipsel-openwrt-linux-uclibc-gcc
Does indeed create a MIPS executable.
It is possible I did once get confused because we end up with a bin directory with both x86 and MIPS binaries in it: Never mind all is good now.
