Simplest way to monitor current with a Prop?
I have an electromagnet clutch and I want to know if it is engaged or not. The only thing I can think of is to put a .5ohm on the 24VDC path to the clutch, use a diff amp on both sides of the shunt and amplify the gain to a comparator to provide ample signal. Then set a threshold on the other input of the comparator with the Prop DAC. If the clutch is engaged it will be pulling around an amp. 24VDC 28W. This method requires a differential amp plus a comparator, but I am trying to look for a simpler solution(less cost, less parts). The Prop needs to watch for clutch engagement after it is told to engage before continuing. Any ideas?
I can likely remove the comparator out of the circuit, and program the gain of the diff amp so the output falls clearly away from 3v3/2 in either state(on or off). This will save one part and a few passives. The ideal is no extra IC's but that may too much to ask for the Prop alone.
Jonathan
So, maybe a current transformer to an opto? With the right resistors you get a prop pin to read a 1 if enough current was drawn and 0 if not. Current sensor to a sigma delta pseudo ADC? Allegro makes some good ones.
Jonathan
Jonathan
