Are you smarter than a Chimpanzee ? how's your logic.
just a bit of fun....in the movie 'Rise of the Planet of the Apes the genetically modified chimp completed the Hanoi puzzle in the minimum 15 moves using 4 disks.
I will be honest I did it in 43 my first attempt before getting the idea. Second go was easy in 15 moves. What's your score on your first attempt ? I'm going to regret posting my first attempt.
http://www.daftlogic.com/projects-towers-of-hanoi.htm
if that's too simple try 5 disks..... but it does not count your moves !
http://zylla.wipos.p.lodz.pl/games/hanoi5e.html
No.
A poster on the website indicated over 580 billion years!
Mankind is now free from the oppressive labor of Tower of Hanoi or Rubik's Cube solving.
That is just gorgeous.
Seems you don't need Chimps to solve this, ants will do:
In 2010, researchers published the results of an experiment that found that the ant species Linepithema humile were successfully able to solve the Tower of Hanoi problem through non-linear dynamics and pheromone signals.
From wikipedia some place.
you would be caged and electric prodded for that if you were a chimp.
that's a little hard to believe, but why don't you do a little experiment and build the puzzle with just 32 disks, then post back to us here soon as you finish the puzzle ?
No, no that's the wrong way around. If you don't believe it then the onus is on you to do the experiment in order to convince yourself one way or the other.
Catch you later.
Ants? Better yet, how about some Physarum polycephalum (slime mold)?
http://jeb.biologists.org/content/216/9/1546.full.pdf
If accepting your challenge would grant me the time to do it, it might be a tempting offer except that living for millions or billions of years just to move some disks around and nothing else, well.....
Here's a link to a Wiki page that sums it up rather nicely, and quickly, to boot!
http://en.wikipedia.org/wiki/Tower_of_Hanoi
The section under Origins
The servant just asked for a grain of rice on the first square of the new board and double it for the next square and so on until the 64 squares were finished. It ended up being more grain than in all the world. Hang on I'll google, OK it was 2 ^63 grains. which is unbelievably larger than if the board only had half the number of squares. You just might get the Hanoi puzzle done with only 32 disks
My bad! Misread the formula, # of moves = 2^n - 1.
32 discs will take 136 years, sorry, I'll be too dead to do any toasting. (33 discs will take a little over 272 years.)
Arthritis, fibromyalgia, carpal tunnel, boredom, mark my words, that poor little arm will call in sick one day.
The most interesting application of the Hanoi Tower Puzzle is its application to backing up your hard disk. It seems to work pretty well at doing a cycle of backups that require less space than other backup schemes.
I believe it may also work with Rsynch to alternate between partial and full backups to save time. But the primary purpose is to have a longer backup history with less storage involved.
http://en.wikipedia.org/wiki/Backup_rotation_scheme
