If you want to see the crazy chat I had with MS to activate XP, they refuse. — Parallax Forums
whiteoxewhiteoxe Posts: 794
edited 2014-07-25 05:44 in General Discussion
I wanted to put XP onto a laptop. The XP disk was bought and paid for and given to me by the owner. The owner has asked me to keep it safe as its his genuine own disk but has lost the cover with sticker for activation code.
I thought I could call Microsoft and get some help. I used their CHAT system. It was extremely frustrating because they , the customer help person was pretty evasive and even dishonest.
They would not help at all to activate a genuine paid for XP disk but would not say so outright, kept sending me to links that 'would help activate' but I read the links while still chatting and the links did not do anything I needed.
In the very end she admitted that they will not activate XP but I could upgrade to the new OS. Geez, I wish she had just said that at the get-go !!!
What do you think of this policy ?
ok....here is the chat if you really want to read it.
    edited 2014-07-24 17:58
    Here is the brutal truth:
    Microsoft isn't the only vendor who will not help with lost license codes after support has ended. Getting help with lost codes is support. If you had the codes, using the activation server would be an option, but you don't have them. Really, all they can do is refer you to a new OS, and if that OS is a Pro OS, you can downgrade and activate an XP install that way, which is supported for Pro and greater licenses.
    Without the sticker, you just have a disk. Could be any disk. And on the documentation that came with that sticker, it will have said something to the effect of, "keep this information secure" as it's what the owner paid for to secure their right to use and authenticate XP.
    Now, whether or not you think that's a good policy may depend on a lot of things. How old is XP? When was that license purchased? This stuff isn't permanent. When closed software goes off the support road map, it goes off, and little things like software tools, servers and other bits needed for it go away too, and then it's just done.
    Personally, I wouldn't expect lost license code type support after such a long time. It's amazing that activation is still an option after such a long time too. License authentication devices and the information associated with them go away. Fact of life, and when they go away, they really do just go away. Virtualizing these things before one gets outside the window is a very smart move, if the intent is to keep using it. They did sell the owner a right to use, and it's not up to them to insure the owner has a right to use when the owner didn't maintain their record of said right to use. Brutal, but true. I've seen this kind of thing happen with software way more expensive than a copy of Windows Pro would be. 5 figures. Still got told "no", and "sorry"
    Now is a great time to consider software that doesn't require those things to operate properly. No Joke. It's a great time, because this will happen again and again. And it's happened a ton of times to date. The support is what it is. Those who paid in, got what they got, and when it's over, it's really over.
    I think it's a bummer, but I also think Microsoft went well above and beyond with XP. Now that they've said they are done, they really do get to be done. You know Linux doesn't have that pesky little problem, and it runs virtual machines very nicely. Go and find some XP virtual image somewhere and get setup on that. Then you can preserve it for the longer haul. Or just step up and buy a new license.
    Given people can run their Windows license for 10 years or so, the license is a steal. No brainer to get another one. Win 8 Professional is $200, for a grand total of $20 / year for a 10 year run. And you can downgrade that to run XP, or Windows 7, etc...
    edited 2014-07-24 18:31
    Seems like there are tools "out there" to help you crack such codes or else give you alternative codes that will work. Considering that it's a legit copy, and that MS doesn't support it any more, I would not have ethical qualms about using such help. No doubt there are some who would.
  • whiteoxewhiteoxe Posts: 794
    edited 2014-07-24 19:04
    The truth is very brutal. Its as annoying as the great lengths the representative went to not be upfront. I made it clear I was busy and didn't want to go in circles clicking on links but she kept to her training until finally I almost forced her to come clean.. I can download a copy illegally that is cracked. I won't feel bad at all if I choose to. or as you say a crack for the legit disk.
    errr.... I can't find the SOLVED button ?
    the support to get activation only ended a couple of months ago
    edited 2014-07-24 19:07
    I have a good friend that went through a similar thing trying to install his purchased MS Office on his new computer. The HD died in his old system and he bought a new computer. He had the original media, etc for MS Office but the paper with the license key couldn't be found. He called MS and they wouldn't help at all even though he had proof of purchase right from Microsoft (not a reseller). Luckily some of the data on his old drive could still be read. I think he used a utility called the magical jelly bean to help recover the key from his failed system. Once he had that it is now in a safe place with the media so he can re-install easily if ever needed. Many people don't know all those codes are important and I tell them to keep them safe....
    edited 2014-07-24 19:23
    Do you think Open Office or Libre has replaced MS Office in lots of businesses ?
    or at least had a major effect on the pricing ?
    edited 2014-07-24 19:39
    Retail? No.
    But, there always seems to be a way to get Office for a very sweet price. Yes, having good alternatives out there has and does impact this.
    edited 2014-07-24 19:49
    She said you had two options.
    1: use XP unprotected.
    2: use Windows 8.1
    I read your chat thread, How do you figure in dishonesty? What circles are you referring to? the choice was made very clear.
    "We don't support XP anymore." and "Try this link for your options" are very clear to me.
    You called them, they didn't call you.
    I don't always like the answers I am given either. but I don't tend to shoot the messenger because of the wrong answer... but that's just me..
    edited 2014-07-24 20:20
    whiteoxe wrote: »
    I won't and don't need MSO and I've been a keen user of Open/LibreOffice for years. Not only can I produce great datasheets and manuals but I can use Draw for creating precise labels as well, plus not to mention Calc, Impress, Maths, Base, and Charts etc. The fact that it is free is not the reason I use it, the fact that it's not bogged down in MS licenses is part of the reason I'm happy to use it, but the main reason is that LibreOffice is so good I don't need any of the other stuff.
    Mind you my wife's a science teacher and the schools get MS "free" and the students can get MS "cheaper" but she tells the kids to download LibreOffice and many have never heard about it, they're happy, but surprised plus it's is MS "compatible" (that'll be the day when MS is compatible with other software!). So like Linux all these OSSs do not and cannot go advertising nor could you expect your retailer to be promoting them either (even if they were using it themselves).
    edited 2014-07-24 20:21
    I think the thing to worry about are some of there products (Like MS Office) when they need to be re-installed due to a HW failure or move to a newer PC. With a lot of their new software it has to be activated after installing even if you purchased it and have your key. What happens when they decide to retire the authorization server or no longer want to activate a product because they no longer support it.
    It isn't like your actually asking for support and how to use a feature. You just want to use the product you've already purchased which may work fine for you. You just want to re-install it and can't because of some silly activation process that they decided to implement. I personally dislike the whole activation thing and ran into issues during early DR exercises. We always called in the activations and made sure we wrote down the codes so we could do future DR's without calling.
    I think that "Activations" is outside the scope of normal support and they should keep that open indefinitely or at that point give someone an authorization that will just keep working for them so they don't need to call back.
    edited 2014-07-24 20:59
    Agree 100%. Been using and recommending Open Office for many years. Only reason I have not switched to all open software is that so much of the proprietary software I need for the equipment I work with only runs on Windows. Waiting for the day when all of it will run in a browser.
    edited 2014-07-24 21:17
    whiteoxe wrote: »
    errr.... I can't find the SOLVED button?
    whiteoxe - go back to your original post, open in the advanced editor and you'll see a pull-down menu at the top of the display. In that pull-down will be the "Solved" selection.
  • GenetixGenetix Posts: 1,774
    edited 2014-07-24 22:21
    What brand laptop do you have? You might be able to get a replacement CD from the manufacturer.
    edited 2014-07-24 23:00
    Ttailspin wrote: »
    2: use Windows 8.1
    Steady eddie ! One of us is mistaken but hold back on the hostility for a second. I dont know you and you dont know me. But if I have made an error I am listening. I made it ptretty clear that I just wanted to activate the XP OS. I was reading the links in tabs as I was aslso tabbing back to her. She was not being very helpful in that she was really pushing for the upgrade or new OS. Thats how I felt during the chat. What I was reading seemed to be about being able to activate if it was in upgrade or repair. I couldnt find a simple way to just activate it. I didnt read every single paragraph of every single link. I thought it was reasonable for me to get straight answers from a microsoft rep. And she told me herself that was exactly what she was doing. She TOLD me it could not be activated. So I didnt go back to the tabs and links. BECAUSE SHE TOLD ME I COULD NOT ACTIVATE MY XP DISK. So please underdstand there is no need for your ...whatever it is your feeling. And I can understand it is probably just You !
    edited 2014-07-24 23:20
    User Name,
    That is certainly the way I would go if I found I had a dire need to use XP for some feature tor other I cannot get elsewhere.
    Ethical qualms, no.
    However people should be aware that without the license key one has no proof of the right to use the software on that disk. Thanks to the current ferocity of copyright laws following your suggestion makes one a criminal.
    edited 2014-07-24 23:30
    I was trying to make sense of the Title of your post, I get it now...
    I don't blame them for refusing to chat with you.
    Me first, gimme, gimme, mine, mine!, is not okay..
    -Tommy
    edited 2014-07-24 23:37
    whiteoxe has a way with words. If you read it forwards and backwards and inside out a few times you can generally make a good guess at what he is trying to say:)
    Sorry, whiteoxe, just a bit of playful ribbing.
    edited 2014-07-25 00:37
    Its alright Heater, I started therapy the same day I re-joined the forum
    and Ive had a visit by the monkey god moderator who watches over us :)
    edited 2014-07-25 00:51
    All hail the Monkey God Moderator!
    Honestly the moderators around here do a fine job.
    I have used libre or open office to write weekly notes to hand out to people wanting to learn Gimp. It was very good. ,no trouble putting text around or beside pics, great control of keeping the formatting and placement just where you wanted it. but when I visit and stay with relatives on farming properties, two have win 7 with mso and one has mac with mso, some bought it despite my letting them know of the alternative, I end up fixing up formula in the spreadsheets for cattle, purchase dates, tags, weight , totals of different numbers, try to show them how simple it is but they don't want to know so I do the same kind of things next visit :)
    if im just writing for myself I'm very happy to use any simple text editor.
