Building the MIKE with a BASIC Stamp and what motor?
So after a couple of weeks of leaning I have decided to move forward with Tod Loofbourrow's MIKE using a BASIC stamp rather than the KIM-1! I think I can free up enough pins to make it work!
But a big problem I am having is finding out what motors to use...
The book requires three drive motors and one directional motor. I plan on using two drive motors and spinning them for turning, like with the BOE Bot. Rather than 8 sides, I am going to build mine with only 6.
But what motors do I use for the drive wheels?!?! The original plans called for Herbach & Rademan TM20K370 motors. But not only does this company not make these wheels any more, they refuse to give me any hints to the details about them.
I need two drive wheels/servos that will move maybe around 200 lbs of robot. I doubt that MIKE will ever be that heavy, but who knows!
Any ideas of servos or motors that I could use with the BASIC stamp that will fit my needs?
THANKS!
Aaron
THANKS!
Aaron
How much do you want to spend?
Todd in his book says that the robot will be around 200 lbs. But the more I play with the BOE bot, the more I think I could build it much, much lighter. What gearmotor are you talking about?
The repop of the KIM-1 I bought ends up not being what the original was. Something about the reproduction 6530's are not like the originals and old programs do not work on the re-pos. That is why I think I need to commit to the BOE Bot board (or something Parallax based), without just rebuilding the BOE-Bot kit...
