Solar Rechargable Robot Battery Pack
This looks like an interesting hackable power supply for a Robot. I'm thinking the robot could be very "cat like" when it isn't busy, it cold wander off to find a sunny spot, enable the solar charger (currently a button push) and switch to low power mode while it sits charging in the sun.
The $20 price tag doesn't seem too terrible for a 5000mah LiPo with a solar charger.
'Sleeping' 20Hours/day or more...
I doubt that panel gets you more than 1W at 5V.
The only reason I mentioned that was because it has a "push button" and it sounded like that needed to be pushed to enable the charger as if the solar panels aren't feeding the charger at all times - needs to be investigated further.
There is an inherent design conflict --- you leave it in direct sun (like the dashboard in your car) to charge and the battery cells are getting exposed to excessive heat damage while charging.
Seems like another day at the offcie where the marketing department and the engineering department are not on speaking terms. Do I add on a Pelteir Cooling Module and have that rob all the charging ability? Or do I just forget the solar cells? Or do I just not tell the customers that it won't last?
Are we attracting bees to honey? Or flies to that other stuff?
The real value -- At $20, just buy it and never use the solar charger.
$16, solar, 12000+ verified mAH, US seller, flashlight. He admits the 30000 mAH rating is bogus.
http://www.ebay.com/itm/30000mAh-Dual-USB-Portable-Solar-Battery-Charger-Power-Bank-For-Cell-Phone-Red-/251543819512?pt=US_Cell_Phone_PDA_Chargers&hash=item3a912e14f8#ht_6713wt_932
Or non-solar (USB charge) 50,000 rated (assume 20,000) for $20, another US seller. In pink!
http://www.ebay.com/itm/NEW-50000-mAh-UNIVERSAL-Portable-Power-Bank-Battery-charger-for-mobile-devices-/261520802969?pt=US_Cell_Phone_PDA_Batteries&var=&hash=item3ce3dac499#ht_3531wt_1661
Certainly the 5V boost circuitry has some losses. If you drew power directly from the internal 3.7v LiPo battery, you could improve efficiency.
Thanks! My work here is done!!
Dual USB sounds better. Plus a headlight....I mean flashlight!
The solar cells need to be on top to collect sunlight, so they can also provide shade to the batteries and other robot parts.
The robot has a microcontroller so it can monitor the battery state and stop charging them when they are full. With a solar cell that provides less current than the robot draws when running even that not necessary. Just have the robot start up.
