MC33660 Supply Voltage
Hello,
Just curious if I'm understanding this correctly. If I supply the MC33660 with 3.3v, does that mean I don't need a current limiting resistor between tx and the prop?
Datasheet: http://cache.freescale.com/files/analog/doc/data_sheet/MC33660.pdf
Bryan
Bryan
Logic is spec'd: high > 0.7 * VDD; low < 0.3 * VDD.
CS high = > 0.7 * VDD; low =< 0.3 VDD.
Yes, it's a bit ambiguous, but I'd hazard the guess and assume that if the datasheet does not explicitly say it will work with 3v3 levels, which it does not say, it won't work properly without level translation proper.
So this calls for an experiment. See if it operates from the 3.3v supply.
If it does, you are in luck. Else it looks like you need to arrange for a 5V supply for it and use that current limiting resistor on Tx.
I'm curious, I have never heard of "ISO K Line". Do you really need that? Perhaps there are other ways to get a similar interface for the Propeller than use that chip.
Also I have never seen the expression "battery level logic" before. Reminds me of the time as a kid I was running my 74 series TTL experiments off of a 12v motor cycle battery. It even worked...for a while.
Bryan
However, there's the chance that the 33660 might just work with the Prop's outputs.
