Elev-8 Battery Life
I'm getting about 6 to 6-1/2 minutes on my Parallax 3200 mAh battery. The battery is a little less than a year old. I'm estimating 100-120 charges on it, using the Tenergy unit that Parallax sells. Running 4 motors, a receiver, led strips and a FlyCamOne camera (sometimes). No servo's or other devices onboard.
Just recently started using a timer on my radio (HiTech Aurora) that triggers off of the throttle and so started paying more attention.
DJI advertises 25mins max on the Phantom 2 Vision +. I have flight time envy. :frown:
Thought about a higher capacity battery like this one:
http://www.ebay.com/itm/FLOUREON-11-1V-5500mAh-3S-35C-Lipo-RC-Battery-for-RC-Helicopter-Airplane-Hobby-/191097206124?pt=Radio_Control_Parts_Accessories&hash=item2c7e47f56c
What's everybody else getting?
-Russ
-Russ
I've read Parallax thinks 4,000mAh is about right capacity for an ELEV-8 pack.
I personally use 5,000mAh packs. I chose 5,000mAh packs since I use 6S 5,000mAh packs with my helicopter and I figured I could double up the 3S I purchased to use with the ELEV-8 and use them with my helicopter.
I got 15 minutes of flight time with the 5Ah packs.
Here's a thread where batteries were discussed a little. In the thread I link to this 5Ah pack. I usually try to find packs at HobbyKing's USA warehouse since the shipping is faster.
With a larger capacity pack, the C rating can be a bit lower than when using smaller packs. I'm not sure if everyone will agree, but I think a 20C 5Ah pack would work fine with the ELEV-8 if the ELEV-8 isn't flown very aggressively.
Wondered about how they handled tx / rx loss. They quote 800m range, which isn't a lot (~ 1/2 mile). 5200 mAh has to be fairly heavy ~ 400-500 grams.
I have a low battery indicator on my radio - just can't remember where it is set right now. It seems to be reasonably accurate because the ESC's start to get soft at that point also.
I'm looking for a good 15 min's of flight under "normal" conditions.
-Russ
I used to fly my airplanes 1/4 mile away so I could take a line of photos over a 1/2 mile stretch (I'd fly 1/4 mile the other direction). It was awfully hard to see my 8' wingspan airplane that far away. I sure wouldn't want to try to fly a quadcopter that far.
I suppose with a FPV setup, the range issue becomes more important. I'd think they'd have a return to home feature with a lose of radio signal. Lots of control boards will log transmission losses so you can get a better idea of a safe distance.
Yeah, I understand the visibility issue. I have a hard enough time at 100' elev and 100 yards downrange. I was thinking about FPV in the context of the fireworks guy - 800m just doesn't seem like a lot of margin in that case. Of course, if it just gracefully flies back home I suppose it's ok. Somewhere I've seen a 7mile range reported for my radio setup. That sounds plenty safe.
