Common Capacitor Values — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2014-07-05 09:52 in General Discussion
Several years ago I purchased a Capacitor kit that I thought would come in handy. I have not used a single one of them since buying it. So, What are the most common Capacitors that might be used In various Propeller projects? I do not need to be specific but rather than buying a few at a time I would like to buy another kit but with values I will actually use.
    edited 2014-07-03 20:21
    The same thing happens if you buy a 'full assortment' of 1/4 or 1/2 watt resistors... a lot of values get left behind.
    The full range kitted values tend to be a waste of money.
    For capacitors, it is a bit more difficult as there are a wide variety of kinds with different attributes. You might have the right value and the right voltage capacity, but desire something that has more ideal qualities for the frequency that you are targeting.
    Having said that
    Having a lot of 0.1mfd to 0.33mfd capacitors for by-pass in the 25 volts or less range is optimal.
    Having some 10mfd to 33 mfd might be useful for filtering linear voltage regulators.
    In the world of resistors, I find that most I need pull-up resistors, LED current limiters, and i/o pin protection
    For pull-up resistors, 10K ohms is generally acceptible and maybe 3.3K to 20K will work
    For LED current limiters - different values for 3.3v and 5.0v. But between 220 and 470 ohms are useful.
    For i/o pin protection - ON the Propeller, jumps from 5 to 3.3 volts are best protected by 3.3K ohms.
    and general i/o current limiting by 120 to 220 ohms for things like the base of the transistors.
    I'd say the main thing is to avoid the extremes in values that you might rarely use.
    In capacitors, you won't be using 500V capacitors unless you are working with tube amps and motor starters. These get big. And you won't like be needing 50,000mfd and above unless you are building power supply filters.
    In resistors, you won't be using a lot of 1 watt, 2 watt, or 5 watt resistors. And you really won't need mega-ohm values unless you are dealing with op amp designs. Even then, high mega-ohm resistors are almost never needed.
    In other areas
    Basic transistors can be limited as well. I usually have 2n2222 and 2n2907 for almost everything.
    MOSfets have changed rapidly to get smaller and better, so it is harder to say what one should keep on hand. I do have a few 2n7000 for general stuff.
    Of course there are items for the curious...
    SuperBeta transistors, super capacitors, big power darlingtons, and I have dummy resistor loads for 20 watts at 8 ohms for audio work.
    It gets silly to stock all and everything. You usually use up the most popular values and have the odd ones sitting around forever.
    And then there are diodes.....
    edited 2014-07-03 20:31
    Parallel for value as necessary, it's allowed.
    (Just trying to keep things ON TOPIC).
    Once you have a junk box of components you can start filling a junk closet and work your way up to a junk room.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-07-03 21:55
    junk room
    Way beyond that. On the verge of having junk house!!!! Thanks for the input. I got on EBay and ordered some a kit that has several of the values that I see referenced here often. I have enough resistors to probably last myself, my son, ((Future) my grandson and my great grandson) a lifetime!!! Same goes for 50V Ceramic Caps!!!
  • DmashekDmashek Posts: 49
    edited 2014-07-03 21:59
    NWCCTV wrote: »
    Your wish is Parallax's command!
    http://www.parallax.com/product/751-00012
    edited 2014-07-03 22:12
    Not in stock yet. Also, quite pricey. I paid under $4.00 for 210 Caps. Thanks for the link though.
  • whickerwhicker Posts: 749
    edited 2014-07-03 22:22
    ceramic (max 50V):
    picofarad values like 6 pF, 22 pF, 33 pF, and 0.1 uF
    get a ton of 0.1 uF ceramics for bypassing chips, 0.1 inch lead spacing to fit in two adjacent rows on a solderless breadboard.
    Aluminum electrolytic (50V or even bettter 100V):
    microfarad values of 1 uF, 10 uF, and 100 uF
    yes these guys wear out but are super cheap, Nichicon are the best (watch out for knockoffs)
    Beyond this are the RF and extreme voltage spike abuse tolerant kind of capacitors, but again you'll probably never use them.
    (things like epoxy dipped mica capacitors, max 2000V, and other kinds of film capacitors)
    I haven't seen a need for tantalum in hobby circuits: they're expensive and don't ever dare reverse their polarity or exceed the max voltage even once.
    If you're scared about aluminum electrolytic capacitors (going to have a circuit powered constantly on for years and years) then the new guys on the block are Aluminum Organic Polymer capacitors. High values like 220 uF, but low max voltage though... 10V, 16V, 6.3V etc... But great in switching power supplies and general ripple reduction. Most are going to be surface mount, but versions with leads do exist.
    edited 2014-07-03 22:37
    Great, Thanks for all the pointers all.
    edited 2014-07-04 00:42
    NWCCTV wrote: »
    Socking up can be fraught with dangers...
    At one point, I decided to stock up on 10K, 5K, and 1K resistors. When I got home, I found that someone at the store had stocked these with 10M, 5M, and 1M respectively. Of course, it wasn't worth a trip back to return them, so they will likely sit in my Megaohm baggie for all eternity, unless I get into some high volt applications.
    Often, buy 5V-10V rated capacitors might leave you short. I try to buy at least 25V ratings unless I am sure about what I need less for.
    Why so? Well, not all ICs are 5V, 10V or less. For instance, I bought come ML339 comparitors intended for 3.3V and 5V use, but they can operate up to 36VDC. Now I see that I can use one for LED indicators for my gel cell charger and it will be operating at 13.8VDC and maybe a bit higher. I guess that being an IC, it needs a by-pass capacitor between power and ground regardless of the higher voltage.
    At one point, I thought that tantalum were the best for all and everything, but I soon found that they are polarized. There are times that this doesn't matter, and there are times that this does and you blow up the capacitor if it is reversed. Electrolitics tend to be polarized as well, but there are non-polarized ones as well.
    Like I said above... it is hard to stock exactly what you want in capacifors. But non-polarized and between 25 and 100VDC might be the most handy.
    edited 2014-07-04 13:30
    I needed a monitor for one of my Prop projects (On Topic - CHECK)
    Found a dead LCD monitor and decided to bring it back from the dead.
    Turns out 25 volt 1000 mF and 25V 470 mF electrolytic capacitors are used quick a lot on LCD monitor pwer supplies.
    They say the electrolytic capacitors dry out when they get hot, and the monitor dies. Appearantly if we replace the non-105c caps with 105c versions, the monitor works again, and is less likely to die from heatstroke.
    And it turns out that buying 10 costs the same as buying 1, when buying from ebay. So i got 10 each of the 105c 25volt 1000 mF and 470 mF electrolytic capacitors for like $8. Which would be enough for two monitors.
    I have not completed this experiment yet, I chose cheapest shipping from china, to keep the cost below the prince of a new monitor.
  • GenetixGenetix Posts: 1,770
    edited 2014-07-04 14:02
    The worst thing you can do is ruin something because you chose the cheapest component you can get your hands on. Spend a little more a quality part made by a reputable company such as Panasonic or if you must have those Chinese made parts play it safe and get parts with double or triple the voltage rating,
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-07-04 14:11
    Buying capacitors from China on eBay is generally considered a bad idea and some brands are to be avoided completely. CapXon is probably the worst. Considering the effort it takes to do a cap replacement (and you don't want to have to do it again any time soon), it's probably best to stick with good brands (Nichicon, Panasonic, etc) from reliable suppliers such as Mouser and Digi-Key. They really don't cost that much. A Nichicon 105F 25v 1000uF is about 35 cents if you want cheap, or under a buck for a 10,000 hour rated Panasonic of the same specifications.
    edited 2014-07-04 14:55
    RDL2004 wrote: »
    Man, too bad this topic didn't come up three days earlier. The capacitors in the monitor that went bad are in fact CapXon. I thought the issue was the heat (the circuit board is visibly golden brown in the area of the bulging capacitors), I didn't even think that the caps themselves would be shoddy. I thought the bad caps thing was solved years ago. I guess some gifts keep giving.
    What about brand SAMXON? Are they worth trying? That's whats on the way, the 105C version to replace the regular version.
    edited 2014-07-04 17:44
    I think the era of caps with the bad electrolyte formula is pretty much over. However, as long as there are bean counters there will be cheaply constructed, poor quality, falsely specified capacitors. I don't know about SamXon in particular but they are not one of the best brands. Aluminum electrolytic capacitors have always been a problem with respect to durability/longevity. Even the better manufacturers have problems with them at times.
    edited 2014-07-05 07:55
    Could electrolytic capacitors be replaced with solid capacitors? In particular,
    1000 mF 25V
    and
    470 mF 25V
    would 10 @ 47 mF = 470 mF ?
    Jameco has tantalum caps 4.7 mF 35volt. for $0.59. Could I put 100 of these on a board and have it work? It would look silly, but it would still cost less than a new monitor.
    edited 2014-07-05 07:58
    These say they are solid aluminum. Does this mean they have no electrolyte to dry out?
    http://www.ebay.com/itm/10-25V-470uF-10x10mm-SMD-Aluminum-Solid-Capacitor-SANYO-/351097100294?pt=LH_DefaultDomain_0&hash=item51bf049806
    They are the wrong physical size, but I don't mind modifying the case.
    edited 2014-07-05 08:44
    Yes, but these types are only available in a restricted range of capacitance and voltages. And you're still looking on eBay. You may find those "solid aluminum" caps in reality have a regular wet electrolytic cap on the inside. I'd buy some extras to cut up for inspection if you go that route.
    If you're concerned about life, I'd just go with a good quality, regular aluminum electrolytic with a decently long working life rating. I've been using the Panasonic FR series.
    http://www.mouser.com/ProductDetail/Panasonic/EEU-FR1E102/?qs=sGAEpiMZZMtZ1n0r9vR22eOLaseCUKTaHMz177co6pA%3d
  • David BDavid B Posts: 592
    edited 2014-07-05 08:57
    Whenever you're working on a project where you have to buy some capacitors (or any component), when you make up each order, why not buy a few more of the components than that one project needs.
    That way, over time, you'll build up an inventory of the exact values that you've used in the past, which in my experience is a pretty good indicator of what you'll need in the future.
    When replacing power filter capacitors that are bloated or burned, I usually try to up the specification if I can fit them in the same foot print.
    So for a 1000mfd at 25vdc, I would try to get something like a 1500mfd at 35vdc. I suspect that might run a bit cooler and longer.
    I did have a TV tuner for my monitor that went bad due to bad filter caps. The replacements lasted another 3 years and then the whole thing went seriously haywire.
    Sometimes though, it is too late to just replace the capacitors and the device has down stream damage from the power not being clean.
    When you see some that are bad, you really should replace all of them. The remaining ones may look good and even test good, but they have aged and been stressed.
    Fake capacitors are a reality in the audio world and they do come out of Asia. I wanted some 2N3055 transistors for an audio project and even those can be phoney. My fakes have the logo 90 degrees out from the real Motorola devices and the M is certainly not the true Motorola logo. These could be anything... not even transistors, but broken voltage regulators that have been relabled.
