Inline PASM
I am on a mission to optimize a bit of code. Is the following the same as writing a section of inline assembly with PROPGCC C++ code?
__builtin_propeller_waitcnt((waitTime+CNT), 0)
If yes, can this be optimized to complete any faster? Making "waitTime" a constant does not fit my needs.
If no, what header/library is this making a function call to?
__attribute__((fcache)) static void _outbyte(int bitcycles, int txmask, int value) { int j = 10; int waitcycles; waitcycles = CNT + bitcycles; while(j-- > 0) { /* C code is too big and not fast enough for all memory models. // waitcycles = waitcnt2(waitcycles, bitcycles); */ __asm__ volatile("waitcnt %[_waitcycles], %[_bitcycles]" : [_waitcycles] "+r" (waitcycles) : [_bitcycles] "r" (bitcycles)); /* if (value & 1) OUTA |= txmask else OUTA &= ~txmask; value = value >> 1; */ __asm__ volatile("shr %[_value],#1 wc \n\t" "muxc outa, %[_mask]" : [_value] "+r" (value) : [_mask] "r" (txmask)); } }I'm not sure exactly what they are doing there, but, looking at that code gave me an epiphany! I was trying to use "rdbyte" or "rdlong" to pass a C++ variable's value to PASM and that is what I have been screwing up this entire time. I'm sure this is documented somewhere but I must have skimmed over it in my assembly language crash course.
Thank you Good Sir! You just helped me solve a week long headache!
As long as the function is less than 64 bytes, it will run at near PASM speeds.
The whole loop could be written in in-line pasm for better performance and size.
Wasting a COG is not necessary for half-duplex operation.
Solved no? Edit the first post "Go Advanced" and select Solved from the combo-box.
Yes, the __builtin_propeller_waitcnt function maps directly to the waitcnt instruction. It waits until the cycle counter matches the first parameter, and returns the sum of the first and second parameters. So for example:
#include <propeller.h> void toggle(unsigned delay) { unsigned int target = CNT + delay; for(;;) { // wait for "delay" ticks, and update target to be target + delay target = __builtin_propeller_waitcnt(target, delay); // toggle pin 0 _OUTA ^= 1; } }compiled with "propeller-elf-gcc -mcog -Os -S -o foo.s foo.c" produces:.text .balign 4 .global _toggle _toggle mov r7, CNT add r7, r0 .L2 waitcnt r7,r0 xor OUTA,#1 jmp #.L2which is about as good as I can get, as far as I can see.All of the __builtin_propeller_x functions are implemented directly in the compiler and map to the corresponding propeller instruction, where "x" can be "clkset", "cogid", "coginit", "cogstop", "rev", "waitcnt", "waitpeq", "waitpne", "waitvid", "locknew", "lockret", "lockset", "lockclr". (Some of the "lock" functions have an extra instruction to capture the value of the carry flag.)
(So jazzed, I think the commented out waitcnt2() line in your example will produce the same result as the inline PASM, since waitcnt2 is just a #define for __builtin_propeller_waitcnt.)
Eric
I pretty much came to that conclusion last night. I thought I was saving a butt load of clock cycles, but, I had misconfigured something. The inline assembly I had written was not waiting the same amount (a lot less) of clock ticks as the waitcnt() C++ function.
I did however save myself about 7k clock ticks from changing the variable containing the wait time to an unsigned int instead of a float.
Thank you for the thorough explanation. It puts my mind at ease knowing what I have is about as good as it gets.
