Erasing 18 old 100MB Zip Disks?
xanatos
I have a stack of 18 old iomega 100MB Zip Disks that I want to sell on ebay (unless someone on here wants 'em!) but I want to erase the living he** out of them first - they've got client passwords, account info, etc., on them.
I do not have a way of erasing them on any system I own now.
Is there an easy, failsafe way, other than physically destroying them - to completely erase them and make them usable/sale-able with confidence that none of the data could be read unless the NSA wants them
I also have an external Zip Drive that uses a PCM/CIA card port... which, of course, none of my systems support any more...
Thanks for the info,
Dave
Dave
The only way to really erasing them is to run a proper erasing utility that overwrites each sector with random patterns several times.
(5 is generally more than enough. Being able to 'lift' data from a disk that has been overwritten more than one is really a myth. )
Are they really valuable enough that people will pay enough for them to cover your expenses to erase them?
I'm looking for bulk erasure... like, if I plant them on top of a fat transformer for a few hours, will that do it?
I have no way to actually erase them using a utility. Gotta be bulk erasure.
All 18 plus the drive I figure might net me $30. Not so much about the $$ as I just think it'd be a shame to let them rot in a landfill. They do sell on ebay, so I know there are some folks who still use them, for what reason I can't fathom, but...
Dave
They are still useful for some older audio gear.For instance, I have a Roland G-1000 keyboard that uses them:
http://www.rolandus.com/products/details/439
Plus some older samplers.
I have an IDE zip drive that I will dig out. I have needed to copy some of the Roland samples to my hard drive. Once I do that I will send you the drive. Standard IDE so should be Plug-N-Play.
Jim
Maybe I should send them to Steve, (jazzed).
Cool! But... I have only laptops & tablets - not sure IDE will work, isn't IDE a slot configuration for a standard tower-style motherboard?
You can use these things then, I'm guessing?
Dave
IDE as in old style Hard Drives.
I only need 2. My original Roland disk and a backup before I sell the keyboard, so I'm good.
BTW, you saw the BS2px are still on sale?
http://www.parallax.com/product/bs2px24
Jim
Probably nothing I can do with that...
I did, thanks very much. I'm on a project that needs six of them!
Jim
100MB Zip Disks?! Lol. I still use a few of those. Mostly for my Mac boxes and one old gaming PC. Not sure it would be cost effective to send ya one of those to erase them tho'. =:-|
These kinds of discs have a very high coercivity, making it a chore to bulk erase. You gotta go over them lots of time to really wipe them.
I usually drill a hole and recycle or use this fine utility - http://sourceforge.net/projects/eraser/
This is essentially what you'd get recovering meta from overwriting with pseudorandom data once, can you read it?
xanatos doesn't have access to a functioning Zip drive though.
It's really a SCSI-based drive. Hd50 connector, I think.
So, a USB-SCSI adapter should work, if you can find one...
I see you're using eBay's Global Shipping Program on that Z80 auction...
you should be aware that a lot of international buyers(me included) doesn't like that, and will choose an other seller if he has a similar product.
(eBay tends to collect MVA and customs fees even on goods that are not subject to that. Also, tracking is a pain in the ... for the buyer )
I already have a heap of good/unused 100 and 250 Zip disks(and drives), so I'm not interested.
(Maybe if it was a 750)
Thanks for the advice everyone. I just hate to see old tech go to the recycle bin. I'll just sell the old PCM-CIA zip drive and dump the disks after "hard coding" the erasure, ie., mangling the disk substrate
Dave
Nah, why not just pull the data off and sell it like Google, Facebook and everyone else does ?
Then those historical relics don't have to go into the land fill
I thought there were more than one kind of connector?
I seem to recall using a parallel port connector on my Zip drive. The Jazz drive used a SCSI connector IIRC.
Probably not. Any transformer worth it's salt will do a good job of minimizing magnetic fields outside the core.
What you need is one of these:
http://www.radiomuseum.org/r/radio_shac_realistic_bulk_tape_eras_2.html
DJ
http://www.iomega.com/zip/which_zip.html
http://en.wikipedia.org/wiki/Iomega_Zip_drive
I had one Zip disk that went bad on me.
Yes, there were more than one connector type on them.
Parallel port (these were actually SCSI internally, and have a parallel-to-scsi adapter built-in)
IDE
SCSI
USB
The 'PCMCIA version' is a normal SCSI model with a short cable and a PCMCIA SCSI-adapter.
And yes, the Jaz is SCSI. At least the two I have are...
(All right, I collect stuff... )
that wrote the disc and the edge of the track won't be reliably obliterated.
I'm not saying its a reliable way to retrieve data, just that it can be done.
The only way to reliably erase is bring the magnetic medium substantially above its Curie point,
which can't be done for most media without cooking, warping or shattering them. The correct
way to erase really sensitive data is grind-down or melt the platters. That works even against
the NSA!
Bulk erase won't come close, BTW.
BTW all of this is moot if you don't have a threat-model...
[Oh, one thing I forgot, modern spintronic read heads can be used to map the magnetism in 3D I believe
for the ultimate in forensic recovery - the depth of penetration of write head flux can vary
between drives... Again this is NSA territory really.]
Hello!
In actuality partner then yes I will take them. I still have a system here who uses them. I installed a zip drive on it for its first birthday, its a Dell, now its fifteen years old, and doing splendidly.
The tools for older Windows, contain a deep format function, instead of 10 seconds format, its a 10 minute one. I sometimes use it when I'm transferring software from the batch I have to a different storage medium, and the disk then gets that long function format to start all over again.
I now grok that these disks of yours contain very private information. Not a problem. PM me off list, and I'll explain the details. You can also include any electronics you have and do not need.
