Propeller and xbee
Hi all,
Been reading the docs on the xbees. I want to have two or more xbees but is it possible to directly access the status of the io pins on the master xbee that is connected to the prop. All the docs talk about remote io sending. It seems a little vague about direct access. I want to connect a couple sensors to the xbee that is directly connected to the prop. What would the command be for that?
