Propeller Video Capability
Genetix
The Propeller Manual is vague on how to program video with the Propeller. I understand the Propeller can do VGA along with 2 and 4 color TV.
I am thinking of having the Propeller control several screens of just text and maybe a few with simple X-Y plots. The displayed data would come from several sensors.
What video resolutions are available and how many video signals can 1 Propeller realistically generate at the same time?
Most of what it contains (especially the TV and VGA stuff) is applicable to many other platforms:
Ross.
The Propeller Tool Library has a bunch of video drivers and demo. I use the "VGA_1280x1024_Tile_Driver_With_Cursor" with a 19" screen and I can display a lot of data. I used this in my chemistry lab and it has been amazingly helpful.
The "VGA_1280x1024_Tile_Driver_With_Cursor" object uses three cogs.
I second the suggestion by Ross to use the Hydra manual (it hasn't always been a free download I purchased a Hydra system to get mine (the manual by itself was out of stock)). I sure learned a lot from the manual.
Rayman has a bunch of information about VGA stuff on his website.
An example of part of what is possible can be found in this video. The screen is being controlled by the Propeller.
The Hydra suggestion isn't bad, but some of that material is becomming a bit dated.
Jeff
The Hydra manual has a very nice explanation of the Propeller Video hardware but the software is geared mostly for games.
The driver used in graphics_demo.spin contains all you need, and I've added some info on how colors and tiles are handled in my signature. Rayman has also done some nice work.
For graphics, any serious resolution will eat up your HUB memory quickly. If your plots do not occupy an entire screen, you could size a region of graphics, say something like 128x96 pixels, smaller than the screen and place it somewhere on the screen, using the text for labels, etc.. You might also want to consider single buffer graphics to maximize RAM.
The parallax TV.spin driver is a tile driver. Each tile, or pair of tiles can represent a text character, or some graphics. (16x16 or 16x32) The key thing to understand, detailed in the HYDRA book, is how the tiles, colors and overall memory map work. Once you understand that, you can map out your displays, tiles, location of things in HUB memory, etc... Remember to use blank tiles where you can to save on overall resources for the graphics screens.
