New Gripper
This arm on Ebay shows a slick-looking new gripper in the top 2 photos: http://www.ebay.com/itm/New-6-DOF-Manipulator-Aluminum-Robot-Arm-Kits-for-Smart-Car-Base-not-assembled-/331173360823
Looks nice, but other photos below show the same heavy aluminum one we've been seeing for years, probably what actually comes in that kit.
Anybody know anything about the new gripper? Gotta be available somewhere. Might be plastic or nylon.
That plastic gripper looks good - let's hope they start selling it by itself.
The photo below is from the link above.
http://www.ebay.com/itm/Robot-Clamp-Robotic-Hand-Kit-Form-for-robot-builders-and-projects-/221263142796?pt=LH_DefaultDomain_0&var=&hash=item33844f9f8c
My cool Smart Arm with a bunch of nice Dynamixel AX-12+ servos can just barely pick up an empty soda can. I wouldn't have a chance picking up a full can.
It uses ordinary servos, but has good payload capacity because its design gives them a fair amount of leverage.
Edit: I have to wonder what they are using for air.
It arrived today, and it's the traditional gripper. I heard a rumor that there was a new gripper that uses all 180 degrees of servo movement and was hoping that I had found it but I guess not. Should be easy enough to switch out...
I was under the impression the servos were digital. I booted one up and it doesn't act digital. I'm reading conflicting info online some sites say they're digital and the mfg www site doesn't mention the type.
I hope to start building it this evening. I seem to have misplaced the metal servo horns I found on eBay. If I can't find them soon I'll just use the plastic.
Which axis would you use the stronger servos on? I'm guessing closer to the base where more weight is on them?
Thanks.
I used this pic as a guide, with the exception of the base which you can't really see. I just drilled a couple holes in it and "made it work".
Here is the one I built
I had been using a Vin of 7vdc on a protoboard to power the servos, and they seemed to have no strength at all. I would help the elbow by taking weight off it with my hand to get it to move. I connected it to an RC rx and powered it with a five amp BEC and it worked great.
I assumed there were a problem with my Prop setup like a code issue. I swapped out the arm for some smaller servos and they worked fine. Back to the arm itself... After an hour or so I managed to accidentally use the 5v instead of Vin to power three of the servos and they all worked well.
I connected all six to the 5v regulator (keeping an eye on current) and it worked great. Since then I added a separate 5v supply for just the servos.
In some cases I've managed to draw up to 3 amps (gripper closed tight while moving). In most cases resting was around .25 amps and movement with a small object was around 1 amp.
The repeatability is as good as the frame I put it on. I left it running overnight picking up and putting down a dual relay board. Didn't seem to have any problems with that. I'd have to say for $95 it's a good deal.
Looks like fun!
I may have to order one. I have a couple of grippers like that, but not the base & all the brackets.
Also, disregard my comments on working voltage with my servos. One of my servos (wrist rotator) was drawing a lot of current over 5 volts causing the entire arm to be weak. Investigation is underway, will report back soon.
No, Only one located at the wrist/gripper. I actually meant that I want the gripper to rotate 360, not the wrist.
Yea, me too!!!! I was hoping to get to it again this week but as usual, real work is getting in the way. ( That and the sun is shining, which up here we enjoy while we can!!!!!)
If you want 360+ degrees of travel, you'd want a CR servo. I don't see how a slip ring will help unless it's inside of the wrist servo output shaft, wouldn't it need to be on the axis that is rotating?
I'm wondering if I should get more of the MG996 to replace the bad servos. Does anyone know of some decent quality metal gear servos that might be a better choice for an arm?
Bill Henning concurs from his Hexapod thread.
MG995 servo=boat anchor.
I will get them working
