New Board Type for PropGCC -- Win8.1 64-bit — Parallax Forums
JonnyMacJonnyMac Posts: 9,556
edited 2014-06-16 19:29 in General Discussion
Okay, save your Windows pot-shots for another time -- it's what I have (64-bit Win8.1, to be specific).
I want to create a custom board type from PropGCC. Easy, right? I copy the next closest .CFG file from the folder, edit, and save it back. After restarting SimpleIDE the new board type is a no-show.
I think this has to do with the Program Files (x86) folder and how it's handled by Windows.
Assistance -- without editorializing -- is highly appreciated. ;)
  • Hal AlbachHal Albach Posts: 747
    edited 2014-06-16 13:22
    did you add your new board file to the boards.txt file?
  • jazzedjazzed Posts: 11,803
    edited 2014-06-16 13:31
    JonnyMac wrote: »
    Two non-editorializing options:
    1. Remove C:\Program Files (x86)\SimpleIDE\propeller-gcc\propeller-load\boards.txt
    2. Add the new board type.cfg to C:\Program Files (x86)\SimpleIDE\propeller-gcc\propeller-load\boards.txt
    # This is a board selection file.
    # To enable a board, all that's needed is the
    # board cfg filename somewhere in the text here
    jonnymacboard.cfg
    activityboard.cfg      # this is the Propeller Activity board type
    eeprom.cfg             # this is the default 64KB EEPROM board type
    rcfast.cfg             # the generic rcfast clock setting
    rcslow.cfg             # the generic rcslow clock setting
    c3.cfg                 # this is the default C3 type
    c3f.cfg                # this is the C3 type where only flash is used for code
    demoboard.cfg          # demoboard type
    hydra.cfg              # hydra type
    propboe.cfg            # propboe type
    propstick.cfg          # propstick type
    quickstart.cfg         # quickstart type
    spinstamp.cfg          # spinstamp type
    synapse.cfg            # synapse type
    Just curious if you followed the SimpleIDE User Guide under "Board Types -> Special Clock Boards" where this is covered.
  • JonnyMacJonnyMac Posts: 9,556
    edited 2014-06-16 14:54
    Missed the boards.txt file -- thanks, guys.
    edited 2014-06-16 15:33
    Got it. Had to run text editor as Administrator to update that folder. Works now. Thanks, again.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-06-16 17:34
    You can run msconfig to change the User Account settings so everything runs as Administrator.
  • whickerwhicker Posts: 749
    NWCCTV wrote: »
    Yeah that's really not recommended in this day and age if it can be avoided.
