Introduction and retirement dates for the Parallax Stingray robot platform.
RobotWorkshop
I am working on an article that uses the Stingray base and I wanted to get the correct dates for when the Stringray was initially introduced and also the date when it was retired. If anyone can help confirm those dates I would appreciate it.
Thank You!
Robert
Thank You!
Robert
For the end of life date, I think it was in summer 2013. As of 6/5/13 they only had 7 in stock and it was the last of them.
Chris' last ditch effort to find replacement motors to keep it alive was in August: http://forums.parallax.com/showthread.php/149643
For the Stingray files,check out this thread: http://forums.parallax.com/showthread.php/149814
Andrew,
That is exactly what I was looking for. Thank You!
Robert
Robert - Glad you got the info - I look forward to your article.
Lastly, while updating the post with that, I remembered one of the main reasons for its demise, the motors, and so Chris' thread on that was an easy find.
I thought the main problem was the controller board: http://forums.parallax.com/showthread.php/136743-MSR1-Board
Interestingly, they're not on our distributor list. Hmmm...
There was a laundry list of things that could not be resolved within a reasonable time frame.
Have you ever thought to make slightly different the stingray Robot?
You can make it a litle bigger in order to be compatible with ARLO Robot motors , HB-25, and the rest Parallax products!
Have you seen my design on Artist Robot?
It is almost a Stingray Robot...
